If I set up
DGsetup([t, r, theta, phi, psi], M1, verbose)
then the frame-name M1 is displayed with every new execution group prompt as "M1 >"
How do I switch off the frame-name to be displayed at the prompt, so I only get ">" ?
It is irritating as heck !
The only way around this is to restart the kernel, then I can add new execution groups without frame-names displayed.
I am new to Maple Flow and am constantly having issues like the one shown below. A cell will become corrupted somehow, and the kernel will crash or freeze. I can save and quit, but if I re-open the file, the crash will happen again before I can diable evaluation. My questions:
  1. Has anyone else had this issue? Was it solvable?
  2. Can evaluation be disabled by default? Its possible in Maple but I don't see how in Flow.
  3. Can the kernel be restarted and reconnected (like Jupyter Lab)?
I cant expand the cell in question because of the crash, but this cell isn't the issue. This is happening all the time.
 is there anything to get hypergeo function to get algebric expression?
2*hypergeom([1/2, -k/2], [1 - k/2], csc(omega*T)^2)
how ca i change this expression to some function form?...i'm new to hypergeom functions..it somehow come to my thesis?
I have a simple tank design worksheet that calculates dimensions of a tank that I need to build to hold a given amount of liquid.  My question is this - when I include a "with(Units);" statement, the volume function gets rendered in operator prefix notation.  Why is this?  Is there a setting to prevent this from happening?  Thanks.
Without "with(Units);"...
With "with(Units);"...
I've included a worksheet that shows the function both with and without the inclusion of "with(Units);".
Tank_Design_Calculation_-_Units_Question_(v00).mw
Does Maple have built-in Finite Fourier Sine/Cosine Transformation which is defined as below?
2/L*int(f(x)*sin(n*Pi/L*x),x=0..L);
How can I get the finite Fourier transform for the derivatives of a function in terms of its own Fourier transform?
I know that the fouriersin/fouriercos commands of the inttrans package have the Fourier sine/cosine transformation for the interval from x=0 to infinity?
Best wishes
I am facing a kind of strange problem.  y'=y/x-5^y/x ,   y(0)=5 Cauche equation  it gives empty round brackets () . If I restart Maple engine and perform the same. Kindly help, what is this?
with(DEtools);
de1 := diff(y(x), x) = y(x)/x - 5^(-y(x)/x)
an := dsolve({de1, y(0) = 5}, y(x))
an := ()
I have two expressions, wo_theta and with_theta, which depend on multiple variables.
I would need your help to:
  1. Verify, as formally as possible, that wo_theta > with_theta always, i.e., for any value of theta different from zero (and regardless of the values taken up by the other variables)
  2. Show the above in a way that is easy and immediate to interpret (perhaps using some type of plot?)
In other words, I want to verify that as soon as I introduce any theta in my expression such expression becomes smaller:
local gamma;
gamma
assume(0 < gamma, 0 < nu__02, 0 < nu__01, 0 <= sigma__v, delta__1::real, delta__2::real, delta__3::real, theta::real);
interface(showassumed=0);
wo_theta := X__3*(-X__3*lambda__3 - delta__3*lambda__3 + DEV) + X__2*(-X__2*lambda__2 - delta__2*lambda__2 - nu__02) + X__1*(-X__1*lambda__1 - delta__1*lambda__1 - nu__01) + X__2*(nu__02 + DEV/2) + X__1*(nu__01 + DEV/2) - gamma*X__2^2*sigma__v^2/4 - gamma*X__1^2*sigma__v^2/4 + gamma*X__2*X__1*sigma__v^2/2;
X__3*(-X__3*lambda__3-delta__3*lambda__3+DEV)+X__2*(-X__2*lambda__2-delta__2*lambda__2-nu__02)+X__1*(-X__1*lambda__1-delta__1*lambda__1-nu__01)+X__2*(nu__02+(1/2)*DEV)+X__1*(nu__01+(1/2)*DEV)-(1/4)*gamma*X__2^2*sigma__v^2-(1/4)*gamma*X__1^2*sigma__v^2+(1/2)*gamma*X__2*X__1*sigma__v^2
with_theta := X__3*(-X__3*lambda__3 - theta*lambda__3 - delta__3*lambda__3 + DEV) + X__2*(-X__2*lambda__2 + theta*lambda__2 - delta__2*lambda__2 - nu__02) + X__1*(-X__1*lambda__1 + theta*lambda__1 - delta__1*lambda__1 - nu__01) + X__2*(nu__02 + DEV/2) + X__1*(nu__01 + DEV/2) - gamma*X__2^2*sigma__v^2/4 - gamma*X__1^2*sigma__v^2/4 + gamma*X__2*X__1*sigma__v^2/2 + theta*(lambda__1*(X__1 + delta__1 - theta) + lambda__2*(X__2 + delta__2 - theta) - lambda__3*(X__3 + delta__3 + theta));
X__3*(-X__3*lambda__3-theta*lambda__3-delta__3*lambda__3+DEV)+X__2*(-X__2*lambda__2+theta*lambda__2-delta__2*lambda__2-nu__02)+X__1*(-X__1*lambda__1+theta*lambda__1-delta__1*lambda__1-nu__01)+X__2*(nu__02+(1/2)*DEV)+X__1*(nu__01+(1/2)*DEV)-(1/4)*gamma*X__2^2*sigma__v^2-(1/4)*gamma*X__1^2*sigma__v^2+(1/2)*gamma*X__2*X__1*sigma__v^2+theta*(lambda__1*(X__1+delta__1-theta)+lambda__2*(X__2+delta__2-theta)-lambda__3*(X__3+delta__3+theta))
collect(with_theta, theta);
(-lambda__1-lambda__2-lambda__3)*theta^2+(-X__3*lambda__3+X__2*lambda__2+X__1*lambda__1+lambda__1*(X__1+delta__1)+lambda__2*(X__2+delta__2)-lambda__3*(X__3+delta__3))*theta+X__3*(-X__3*lambda__3-delta__3*lambda__3+DEV)+X__2*(-X__2*lambda__2-delta__2*lambda__2-nu__02)+X__1*(-X__1*lambda__1-delta__1*lambda__1-nu__01)+X__2*(nu__02+(1/2)*DEV)+X__1*(nu__01+(1/2)*DEV)-(1/4)*gamma*X__2^2*sigma__v^2-(1/4)*gamma*X__1^2*sigma__v^2+(1/2)*gamma*X__2*X__1*sigma__v^2
solve(wo_theta > with_theta, theta) assuming 0 < gamma, 0 < nu__02, 0 < nu__01, 0 < sigma__v, delta__1::real, delta__2::real, delta__3::real, theta::real;
solve(with_theta < wo_theta, theta);
Warning, solve may be ignoring assumptions on the input variables.
difference_term := (-lambda__1 - lambda__2 - lambda__3)*theta^2 + (X__1*lambda__1 + X__2*lambda__2 - X__3*lambda__3 + lambda__1*(X__1 + delta__1) + lambda__2*(X__2 + delta__2) - lambda__3*(X__3 + delta__3))*theta;
# I would expect such difference_term in theta to be always < 0, i.e., for any theta different from 0)
# (Note that lambda_1, lambda_2, and lambda_3 are always > 0, while theta, the three X and the three delta can be positive or negative. In other words, it suffices to show that the linear term in theta is always negative...)
solve(difference_term<0);
{X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__2 < 0, lambda__3 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2, theta < 0, lambda__2 < 0, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, theta < 0, lambda__2 < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__3 < 0}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, theta < 0, lambda__3 < 0, -(1/2)*delta__3-(1/2)*theta < X__3}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < lambda__1, theta < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__3 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < lambda__2, theta < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, 0 < lambda__2, theta < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1, theta < 0, lambda__1 < 0, lambda__2 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, X__2 < -(1/2)*delta__2+(1/2)*theta, theta < 0, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < lambda__1, theta < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, X__1 < -(1/2)*delta__1+(1/2)*theta, theta < 0, lambda__1 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, 0 < lambda__1, theta < 0, -(1/2)*delta__1+(1/2)*theta < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1, theta < 0, lambda__1 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, 0 < lambda__2, theta < 0, -(1/2)*delta__2+(1/2)*theta < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < lambda__1, 0 < lambda__2, theta < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__2 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < lambda__3, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2, theta < 0, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, 0 < lambda__3, theta < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < lambda__3, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, 0 < lambda__3, X__3 < -(1/2)*delta__3-(1/2)*theta, theta < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < lambda__1, 0 < lambda__3, theta < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__2, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < lambda__2, 0 < lambda__3, theta < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, 0 < lambda__2, 0 < lambda__3, theta < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, lambda__1 < 0, lambda__2 < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, lambda__2 < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, lambda__2 < 0, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, lambda__1 < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, 0 < theta, X__3 < -(1/2)*delta__3-(1/2)*theta, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, 0 < lambda__1, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__2, lambda__1 < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, 0 < lambda__2, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, lambda__1 < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, 0 < theta, lambda__2 < 0, -(1/2)*delta__2+(1/2)*theta < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, 0 < lambda__1, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, 0 < theta, lambda__1 < 0, -(1/2)*delta__1+(1/2)*theta < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, 0 < theta, 0 < lambda__1, X__1 < -(1/2)*delta__1+(1/2)*theta}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, 0 < lambda__2, lambda__1 < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, 0 < theta, 0 < lambda__2, X__2 < -(1/2)*delta__2+(1/2)*theta}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, 0 < lambda__1, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__3, lambda__1 < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, 0 < lambda__3, lambda__2 < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, 0 < lambda__3, lambda__1 < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, 0 < theta, 0 < lambda__3, -(1/2)*delta__3-(1/2)*theta < X__3}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, 0 < lambda__1, 0 < lambda__3, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__2, 0 < lambda__3, lambda__1 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, 0 < lambda__2, 0 < lambda__3, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, 0 < lambda__2, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1}
Download inequality.mw
When I annotate a MapleFlow worksheet, I would like to typset some text as a superscript or a subscript for clarity, and to match the math expression. Is there a method to format text using superscripts and subscripts?
Does the Premium version of Maple Calculator for Android Smartphones come with Maple 2023 or does it have to be purchased separately. Thanking you in advance.
I want to simplify the following trigonometric expression, considering that m is an integer number. For this, I use the following command:
expr:= 4*cos(Pi*m)/(Pi*(2*m + 1));
simplify(%, assume=integer);
factor(%);
However, if I want to simplify the following trigonometric expression, m is an integer number, and alpha is a real number, using the following command will lead to the wrong answer because alpha is also considered an integer number. Please guide me.
4*cos(Pi*m+2*alpha*Pi)/(Pi*(2*m + 1));
factor(%);
Best wishes
I have noticed over a few questions I have asked recently.
I ask a question.                   It goes to top of active converstaions
Some  one answers                                            "
I Reply        *
A bit of time passes  so slides  of the top six/seven that show
Another Reply/Answer from someone                possibly does not show in active conversations.  I catch this by the orange flag or email notification
I reply                                 Does not appear in active conversations..
       This can kill the conversation chain.
I have even tried changing one of me replys to an answer but did not go to top active conversations again.
Has anyone else expperienced this?
If a type is not known, an error is thrown
type([],foo)
Error, type `foo` does not exist
Since no error is thrown, these types are known
type({},'{}');# why that output?
type([],'[]')
I would have expceted {} and [] to be listed as subtypes of set and list since their counterparts (nonemptylist and nonemptyset) exist. Technically the types {} and [] are not needed since negating
not(type([],nonemptylist));
not(type({},nonemptyset));
works.  However, the types exist, hence my question
How can I make a legend for this plot?
plot([17.85*(2.65*t^2 + 1 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 47 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 97 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 147 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 197 + 3*t)^2/t^2], t = 0 .. 25, labels = ['t', 'x'], labelfont = [Times, 12])
 I got the following figure.
Now I want to put a legend box in this plot for each color line. How can I do it?
I need help trying to remove some null elements from a listlist, that i converted from an Array.
Example: I have a list of coordinates r:=[[1,2],[1,3]], which i converted to an array, and nulled the first element.
r:=convert(r,Array):
r[1]:=NULL:
r:=convert(r,listlist):
I now have r=[[],[1,3]] after converting it back to a listlist. How do i remove the first element, which is an empty entry, such that i end up with r=[[1,3]]
Hi guys!
I'm looking for a way to type in the same "calculation" in Maple instead of the Word-package WordMat.
This is a screenshot from Word of the calculation I wanna do in Maple. But I can't figure out how to type it correct. Maybe you guys could post a screenshot of the same entered in Maple.
Note: (I'm a Maple-rookie, it might be a simple "trick")
I know how to assign/define fx IP, U and ZP. It's about calculating with the angle symbol in line, and getting a "readable" result.
Looking forward to hear from all of you...
First 114 115 116 117 118 119 120 Last Page 116 of 2426
