I'm having trouble evaluating an expression with an infinite sum of bessel functions. The expression is:
or, in mathematical notation:
The program doesn't seem to be able to solve the expression and return a value. I only get the answer
When I try to evaluate a simple infinite sum like
the answer is a value. Breaking up the expression in components and evaluating each one works in some cases, e.g. the expression
which returns a value. However, the expression
fails, and returns
Is there a trick to evaluating infinite sums with indices appearing inside a function in the summation expression? Or am I doing something wrong?
For example:
[2,4,9,15,20]
I want the output be 2491520.
Any command can solve the problem? Thank you.
>message:=`67A`;
67A
>P:=convert(message, bytes);
[54, 55, 65]
>with(Bits):
>bitP1:=Split(P1);
[0, 1, 1, 0, 1, 1]
>bitP2:=Split(P2);
[1, 1, 1, 0, 1, 1]
>bitP3:=Split(P3);
[1, 0, 0, 0, 0, 0, 1]
>with(Statistics):
>b1:=Count(bitP1);
6
>b2:=Count(bitP2);
6
>b3:=Count(bitP3);
7
>totalBits=b1+b2+b3;
19
Hi, how i need to modify my command so when i write any message with any lenght, i can get the totalBits directly..
Thank you~=]]
Hello..  I want to know if there is anny command to show the matrix of linear system.  I recently entred a 64 equations and i solved it by command solve,  but i want to show the matrix of system..  So plz. Help
Sorry for boring you my friends. I am haunted by a problem of how to omit the undesired term.
For example, in the following equation, the a(t) , b(t), c(t), u(t), v(t), w(t), psi(t), phi(t), theta(t), varsigma(t), tau(t) and upsilon(t) and their first and second direvative to time t are considered as first order small variables. How could I omit the term greater than second order of small variables?
If we omit the undesired by hand, the omitted equation takes the form of:
R^2*rho*h*(diff(w(t), t, t))*Pi+R^2*rho*h*(diff(c(t), t, t))*Pi = 0;
The original equation is given as:
-R^2*rho*h*cos(Omega*t)*(diff(tau(t), t, t))*a(t)*Pi+tau(t)*R^2*rho*h*(diff(tau(t), t))^2*a(t)*cos(Omega*t)*Pi-tau(t)*R^2*rho*h*(diff(tau(t), t))^2*b(t)*sin(Omega*t)*Pi+tau(t)*a(t)*Pi*cos(Omega*t)*(diff(varsigma(t), t))^2*R^2*h*rho+tau(t)*R^2*rho*h*a(t)*Omega^2*cos(Omega*t)*Pi-tau(t)*sin(Omega*t)*Pi*(diff(varsigma(t), t))^2*b(t)*R^2*h*rho-tau(t)*R^2*rho*h*b(t)*Omega^2*sin(Omega*t)*Pi+2*tau(t)*R^2*rho*h*(diff(a(t), t))*Omega*sin(Omega*t)*Pi+2*tau(t)*R^2*rho*h*(diff(b(t), t))*Omega*cos(Omega*t)*Pi-varsigma(t)*a(t)*sin(Omega*t)*Pi*(diff(varsigma(t), t))^2*R^2*h*rho-varsigma(t)*a(t)*sin(Omega*t)*Pi*Omega^2*R^2*h*rho-varsigma(t)*Pi*cos(Omega*t)*(diff(varsigma(t), t))^2*b(t)*R^2*h*rho-varsigma(t)*Pi*cos(Omega*t)*b(t)*Omega^2*R^2*h*rho-2*varsigma(t)*sin(Omega*t)*Pi*(diff(b(t), t))*Omega*R^2*h*rho+2*varsigma(t)*Pi*cos(Omega*t)*(diff(a(t), t))*Omega*R^2*h*rho+2*a(t)*Pi*cos(Omega*t)*(diff(varsigma(t), t))*Omega*R^2*h*rho-2*sin(Omega*t)*Pi*(diff(varsigma(t), t))*b(t)*Omega*R^2*h*rho+R^2*rho*h*(diff(tau(t), t, t))*sin(Omega*t)*b(t)*Pi+R^2*rho*h*(diff(w(t), t, t))*Pi+R^2*rho*h*(diff(c(t), t, t))*Pi-R^2*rho*h*(diff(tau(t), t))^2*c(t)*Pi+2*varsigma(t)*(diff(tau(t), t))*a(t)*Pi*cos(Omega*t)*(diff(varsigma(t), t))*R^2*h*rho-2*varsigma(t)*(diff(tau(t), t))*sin(Omega*t)*Pi*(diff(varsigma(t), t))*b(t)*R^2*h*rho+a(t)*sin(Omega*t)*Pi*(diff(varsigma(t), t, t))*R^2*h*rho+Pi*cos(Omega*t)*b(t)*(diff(varsigma(t), t, t))*R^2*h*rho-varsigma(t)*Pi*c(t)*(diff(varsigma(t), t, t))*R^2*h*rho-2*tau(t)*R^2*rho*h*(diff(tau(t), t))*(diff(c(t), t))*Pi-2*varsigma(t)*Pi*(diff(varsigma(t), t))*(diff(c(t), t))*R^2*h*rho+2*sin(Omega*t)*Pi*(diff(varsigma(t), t))*(diff(a(t), t))*R^2*h*rho+2*Pi*cos(Omega*t)*(diff(varsigma(t), t))*(diff(b(t), t))*R^2*h*rho-Pi*(diff(varsigma(t), t))^2*c(t)*R^2*h*rho-2*R^2*rho*h*cos(Omega*t)*(diff(tau(t), t))*(diff(a(t), t))*Pi+2*R^2*rho*h*(diff(tau(t), t))*sin(Omega*t)*(diff(b(t), t))*Pi+tau(t)*R^2*rho*h*(diff(b(t), t, t))*sin(Omega*t)*Pi-tau(t)*R^2*rho*h*(diff(a(t), t, t))*cos(Omega*t)*Pi-tau(t)*R^2*rho*h*(diff(tau(t), t, t))*c(t)*Pi+2*R^2*rho*h*Omega*sin(Omega*t)*(diff(tau(t), t))*a(t)*Pi+2*R^2*rho*h*(diff(tau(t), t))*Omega*cos(Omega*t)*b(t)*Pi+varsigma(t)*sin(Omega*t)*Pi*(diff(a(t), t, t))*R^2*h*rho+varsigma(t)*Pi*cos(Omega*t)*(diff(b(t), t, t))*R^2*h*rho = 0;
Thank you in advance for taking a look ;)
Suppose that I have a plot:
plot(sin((1/180)*Pi*x), x = -180 .. 180)
I want to add a degree symbol after the tickmarks on the x-axis.  One approach which seem promising is to add a plot option for the x-axis:
axis[1] = [tickmarks = [90 = typeset("90", degree)]]
where "degree" is replaced by a code for the degree symbol. Maple is helpful here because I can point and click using the Common Symbols palette and insert a degree symbol. However this does not work delivering an error "Error, invalid neutral operator". This error is undocumented.
I can insert a Pi or an infinity symbol. If I want to I can put a degree sysmbol into ther title, but apparently not on the axes.
I've got the following:
Integral_over_region.mw
M_Iwaniuk
I should be able to use F3 to break into a multline nested loop and insert a new line of code, and then F4 to close it up again before execution.  The F4 works for closing things up.  But the F3 does NOT work.  Is this a known problem?  Is there another way to do it short of a lot of cutting and pasting?
I created a regular 2D without specifying the number of points. I tried to change its style from "line" to "point", but i cannot see the symbols because there are too many points and so all i see is a thick black line. Is replotting with less points the only way, or can I interactively reduce the number of points?
I just bought 2016 Maple. For a few days, everything was fine.
The increase of the speed calculations is very significant.
Then copy and paste gave unexpected results: impossible to keep the symbols, systematic conversion in text,in mode MathML,, appearance of ASCII characters in the texts, etc ..
all attempts to change the settings have failed
I spend more time correcting the changes that occur in the copy and paste that to take care of my equations.
Do you have an explanation ?
Hello everyone!
Is this a bug that the following two commands work differently?:
densityplot(sin(x*y), x = -5 .. 5, y = -5 .. 5, colorscheme = ["zgradient", ["blue", "green", "yellow", "red"], zrange = -5 .. 5], style = surface)
plot3d(sin(x*y), x = -5 .. 5, y = -5 .. 5, view = -10 .. 10, colorscheme = ["zgradient", ["blue", "green", "yellow", "red"], zrange = -5 .. 5], style = surface)
The second one works fine in that if you increase the magnitude of sin(x*y) (e.g. 3sin(x*y)) the coloring changes accordingly. But the first one plots sin(x*y) or 5sin(x*y), etc. just the same!
Many thanks for you comments in advance!
For the last 24hrs or so I have found it almost impossible to upload worksheet files in response to questions.
My usual approach is
Big green up-arrow:
(uploader pop-up appears)
Browse files
(this still works)
Upload file
This is the problem step - I generally just get "waiting for Mapleprimes" in my browser's annunciator box: and I wait, and wait, (as in >5 minutes) and still this step does not complete. Just to be annoying, every once in a while the file will upload as normal, such but success is now the exception
I'm seeing the same issue in Firefox 45.0.2 and Chrome 50.0.2661.75mon Win 7, 64-bit.
Anyone else seeing the same issue?
Dear Maple researchers
I have a problem in solving a system of odes that resulted from discretizing, in space variable, method of lines (MOL).
The basic idea of this code is constructed from the following paper:
http://www.sciencedirect.com/science/article/pii/S0096300313008060
If kindly is possible, please tell me whas the solution of this problem.
With kin dregards,
Emran Tohidi.
My codes is here:
> restart;
> with(orthopoly);
> N := 4; Digits := 20;
> A := -1; B := 1; rho := 3/4;
> g1 := proc (t) options operator, arrow; 1/2+(1/2)*tanh((1/2)*(A-(2*rho-1)*t/sqrt(2))/sqrt(2)) end proc; g2 := proc (t) options operator, arrow; 1/2+(1/2)*tanh((1/2)*(B-(2*rho-1)*t/sqrt(2))/sqrt(2)) end proc;
> f := proc (x) options operator, arrow; 1/2+(1/2)*tanh((1/2)*x/sqrt(2)) end proc;
> uexact := proc (x, t) options operator, arrow; 1/2+(1/2)*tanh((1/2)*(x-(2*rho-1)*t/sqrt(2))/sqrt(2)) end proc;
> basiceq := simplify(diff(uexact(x, t), `$`(t, 1))-(diff(uexact(x, t), `$`(x, 2)))+uexact(x, t)*(1-uexact(x, t))*(rho-uexact(x, t)));
> alpha := 0; beta := 0; pol := P(N-1, alpha+1, beta+1, x); pol := unapply(pol, x); dpol := simplify(diff(pol(x), x)); dpol := unapply(dpol, x);
> nodes := fsolve(P(N-1, alpha+1, beta+1, x));
> xx[0] := -1;
> for i to N-1 do xx[i] := nodes[i] end do;
> xx[N] := 1;
> for k from 0 to N do h[k] := 2^(alpha+beta+1)*GAMMA(k+alpha+1)*GAMMA(k+beta+1)/((2*k+alpha+beta+1)*GAMMA(k+1)*GAMMA(k+alpha+beta+1)) end do;
> w[0] := 2^(alpha+beta+1)*(beta+1)*GAMMA(beta+1)^2*GAMMA(N)*GAMMA(N+alpha+1)/(GAMMA(N+beta+1)*GAMMA(N+alpha+beta+2));
> for jj to N-1 do w[jj] := 2^(alpha+beta+3)*GAMMA(N+alpha+1)*GAMMA(N+beta+1)/((1-xx[jj]^2)^2*dpol(xx[jj])^2*factorial(N-1)*GAMMA(N+alpha+beta+2)) end do;
> w[N] := 2^(alpha+beta+1)*(alpha+1)*GAMMA(alpha+1)^2*GAMMA(N)*GAMMA(N+beta+1)/(GAMMA(N+alpha+1)*GAMMA(N+alpha+beta+2));
> for j from 0 to N do dpoly1[j] := simplify(diff(P(j, alpha, beta, x), `$`(x, 1))); dpoly1[j] := unapply(dpoly1[j], x); dpoly2[j] := simplify(diff(P(j, alpha, beta, x), `$`(x, 2))); dpoly2[j] := unapply(dpoly2[j], x) end do;
print(??); # input placeholder
> for n to N-1 do for i from 0 to N do BB[n, i] := sum(P(jjj, alpha, beta, xx[jjj])*dpoly2[jjj](xx[n])*w[i]/h[jjj], jjj = 0 .. N) end do end do;
> for n to N-1 do d[n] := BB[n, 0]*g1(t)+BB[n, N]*g2(t); d[n] := unapply(d[n], t) end do;
> for nn to N-1 do F[nn] := simplify(sum(BB[nn, ii]*u[ii](t), ii = 1 .. N-1)+u[nn](t)*(1-u[nn](t))*(rho-u[nn](t))+d[nn](t)); F[nn] := unapply(F[nn], t) end do;
> sys1 := [seq(d*u[q](t)/dt = F[q](t), q = 1 .. N-1)];
[d u[1](t)
[--------- = 40.708333333333333334 u[1](t) + 52.190476190476190476 u[2](t)
[   dt
        2          3
   + 39.958333333333333334 u[3](t) - 1.7500000000000000000 u[1](t)  + u[1](t)
   + 7.3392857142857142858
   - 3.6696428571428571429 tanh(0.35355339059327376220
   + 0.12500000000000000000 t) - 3.6696428571428571429 tanh(
                                                     d u[2](t)
-0.35355339059327376220 + 0.12500000000000000000 t), --------- =
                                                        dt
-20.416666666666666667 u[1](t) - 25.916666666666666667 u[2](t)
        2          3
   - 20.416666666666666667 u[3](t) - 1.7500000000000000000 u[2](t)  + u[2](t)
   - 3.7500000000000000000
   + 1.8750000000000000000 tanh(0.35355339059327376220
   + 0.12500000000000000000 t) + 1.8750000000000000000 tanh(
                                                     d u[3](t)
-0.35355339059327376220 + 0.12500000000000000000 t), --------- = 29.458333333\
                                                        dt
  333333333 u[1](t) + 38.476190476190476190 u[2](t)
        2          3
   + 30.208333333333333333 u[3](t) - 1.7500000000000000000 u[3](t)  + u[3](t)
   + 5.4107142857142857144
   - 2.7053571428571428572 tanh(0.35355339059327376220
   + 0.12500000000000000000 t) - 2.7053571428571428572 tanh(
-0.35355339059327376220 + 0.12500000000000000000 t)]
> ics := seq(u[qq](0) = evalf(f(xx[qq])), qq = 1 .. N-1);
    u[1](0) = 0.38629570659055483825, u[2](0) = 0.50000000000000000000,
      u[3](0) = 0.61370429340944516175
> dsolve([sys1, ics], numeic);
Error, (in dsolve) invalid input: `PDEtools/sdsolve` expects its 1st argument, SYS, to be of type {set({`<>`, `=`, algebraic}), list({`<>`, `=`, algebraic})}, but received [[d*u[1](t)/dt = (20354166666666666667/500000000000000000)*u[1](t)+(13047619047619047619/250000000000000000)*u[2](t)+(19979166666666666667/500000000000000000)*u[3](t)-(7/4)*u[1](t)^2+u[1](t)^3+36696428571428571429/5000000000000000000-(36696428571428571429/10000000000000000000)*tanh(1767766952966368811/5000000000000000000+(1/8)*t)-(36696428571428571429/10000000000000000000)*tanh(-1767766952966368811/5000000000000000000+(1/8)*t), d*u[2](t)/dt = -(20416666666666666667/1000000...
I am currently working on FDM ,i have 2 coupled nonlinear pde ,i need help in solving these equation using maple code.
> restart:
> alias(f=f(tau,eta), theta=theta(tau,eta));
> PDE1:=S*diff(f,tau,eta)=eta^2*diff(f,eta)^2+(6*eta^2-2*f*eta)*diff(f,eta)+(6*eta^3-f*eta)*diff(f,eta,eta)-eta^4*diff(f,eta,eta,eta);
> PDE2:=eta^4*diff(theta,eta,eta)+2*eta^3*diff(theta,eta)-Pr*(f*eta^2*diff(theta,eta)+S*diff(theta,tau))=0;
The code I write is properly indented.  The operation of pasting it here strips the white space and makes it hard for the reader to comprehend the structure. Manually restoring the appropriate indentation is doable but tedious, made more so because the characters we see here are in a variable width font.  The rationale might be that, given a variable width font the indentation is going to be inconsistent, but that isn't the case if the preformatted style is used, which I do, for code.
Is there any way to turn off the white space stripping?  Presumably this is some ridiculous xml-based processing feature.
First 1169 1170 1171 1172 1173 1174 1175 Last Page 1171 of 2463
