Consider the following simple procedure:
p:=proc(x::{realcons,{set,list}(realcons)} ) x end proc;
p(8);
p({8,9});
p([7,8]);
I would like to be able to do something like this instead:
q:=proc(x::{ID,set,list}(realcons) ) x end proc;
## ID(realcons) should just be realcons.
q(8); ## Obviously we get an error.
q({8,9}); #OK
q([7,8]); #OK
In Q below ID is simply s->s, but that won't work in q.
Q works because the type check evaluates its arguments first.
Q:=proc(x)
    if type(x,{s->s,list,set}(realcons)) then
      x
      error "%1 expects its first argument to be of type %2", procname,{s->s,list,set}(realcons)
    end if
Q(8);
Q({8,9});
Q([7,8]);
I believe that Carl Love had a solution on MaplePrimes some years ago, but I can't find it.
I am looking to integrate this LaTeX code into Maple...Any ideas? Thanks
\begin{tikzpicture} \tkzTabInit{$x$ / 1 , $f(x)$ / 2}{$-\infty$, $-5$, $-3$, 0, $+\infty$} \tkzTabVar{-/ $-\infty$, +CD-/ $0$/ $2$, +D+/ $0$ /$0$, -V-/ $-2$ / $3$, +/ $+\infty$} \end{tikzpicture}
The Maple 2023 System Requirements    shows the fact , that only older MATLAB versions (2021b, 2021a, 2020b) are supported. Does it mean that the latest versions of MATLAB (2022ab, 2023ab) are not supported anymore?
Good day everyone,
I am writing a numerical code using dsolve which works fine but I have a challenge in inputting the previous answers in the subsequent ones. For example, how can I substitute the solutions in S1 into equ11, equ22, equ33, and equ44 in the link below?
Thank you very much as I will be expecting responses from you soon.
New.mw
Code:
Graph := NULL; for i from 0 to N-1 do for j from 0 to 10 do if j <= finite_element_xi[i] and finite_element_xi[i] <= j+1 then finite_element_sigma[i] := evalf(finite_element_epsilon[i]*R(j)); p := plot(finite_element_sigma[i](x), x = finite_element_xi[i] .. finite_element_xi[i+1]); Graph := display(Graph, p) end if end do end do;
Error, (in plot) illegal use of an object as a name
I don't understand how to draw a graph for sigma
I wanted to debug some code from worksheet A.  So added DEBUG(); command in the code where I want to start the GUI debugger from, and then run the command from the worksheet. All is working OK. the debugger GUI comes up and I can step in.
Now I wanted to debug some other code from worksheet B. But without closing the currect debugger which is open and running.
It turned out this is not possible.  When running debugger from worksheet B, it uses the same debugger GUI that was up and running. I think it closed that session automtically also.
So basically using same Maple process, one can't open two debgging sessions at same time? Is there a way around this.
I run each worksheet using its own math engine. So each is separated from each other.
But this is first time I wanted to debug two things at same time, i.e. side by side, thinking I will be able to open two GUI debuggers at same time.
I know ofcourse I can open two separate Maple processes and then I will be able to do this. I think I am allowed to have two Maple's open at same time. Will try that next.
But it will be better if one is able to open two debuggers from same Maple at same time. I do not see why this should not be possible.
Any suggestions if there is a workaround? May be some hidden setting that allows this?
Maple 2023.2.1 on windows 10
Good day.
I am working on a time series problem that uses 107 data sets (historic) and I wish to obtain a forecast for the next successive 12 events. I have obtained the time series plot for the predicted values and the associated dates separately (see attached), however - I am looking to get the solution in a more user-friendly format and was hoping someone could help me out.
Can someone tell me how to
1. Express the data values only as whole number values (decimal-free)
2. Construct a table of data values and dates for the average forecast as well as the 2nd and 98th percentile forecasts?
Thanks for reading!
MaplePrimes_TS_Example.mw
Here is the layout challenge: Whenever the value of a physical quantity is one as in
mass = 1* Unit('kg')
automatic simplification removes the one and the output displays
Desired would be which reads better (in particular when used inline in text passages).
Using the Empty Symbol
mass = ``(1)*Unit('kg')
an expression with parenthesis is obtained (that can be removed in subsequent calculations with the expand command) which looks worse than my current workaround of using floats
(Introducing floats in expressions is not always acceptable)
So the idea would be to use the empty symbol for initial parameter definition in textbook style layout and remove it with expand in subsequent calculations.
Any other symbol that prints as "1" that can be removed in later calculations by Maple commands is welcome as well. It should be better than
mass=`#mrow(mo("1"));`*Unit('kg');
subs(`#mrow(mo("1"));` = 1, %);
I wrote a little simple minded procedure for finding the sum of divisors for a positive integer.  I thought I would share.
sum_of_proper_divisors.mw
sum_of_proper_divisors.pdf
Has someone written better code for this task?
Matt
When there are print commands in a loop their content is printed as soon as this command is executed.
This is not the case with printf whose displays are delayed (buffered?).
Is there a way to force the display of printf when the command is executed?
TIA
Motivation: I want to display intermediate execution times in a prettier way than print offers.
Is it possible to enlarge the sliders in Explore(plot(...), ...) and increase their "resolution" (meaning to have a higher precision when the slider is moved)?
If Maple does offer this option, could you tell me from what version this is the case
TIA
For a project I need to construct a large symbolic adjoint matrix, hoping it can be factored afterward into nice expressions.
In the worksheet, I present an adjoint matrix using permuted Hadamard products. What puzzles me is that only for even dimensions, I need to multiply it (elementwise) with a parity matrix. Okay, not a specific Maple question, but maybe someone can help me out.
Download Adjoint.mw
The attached worksheet shows that Maple 2023 produces an incomplete plot of a function.  Maple 2021, however, produces the full graph.  I wonder if Maple 2023's behavior is due to a bad setting in my environment or a plotting bug in Maple.
kernelopts(version);
`Maple 2023.2, X86 64 LINUX, Oct 25 2023, Build ID 1753458`
y := -cos(sqrt(x))*x^3/(-x^2 + 24*cos(sqrt(x)) + 12*x - 24);
-cos(x^(1/2))*x^3/(-x^2+24*cos(x^(1/2))+12*x-24)
plot(y, x=0..1);
Here is the graph of the same function plotted correctly in Maple 2021:
Download cannot-plot.mw
I would like to plot graph of 2d function f(x, y) = (-ax/(1+y^2), x+by) where x from -5 to 5 and y from -5 to 5 and parameter bar of a and b. Thank you
First 145 146 147 148 149 150 151 Last Page 147 of 2427
