Perhaps a stupid question but I fail to convert 21/4a1/4/pi1/4 (a result of a calculation performed by maple) into (2a/pi)1/4.
I tried simplify, combine, collect, ... with options. None of them work.
Could you please help me to solve this error.
my code is here.
CR-C.mw
This question is an expansion of my previous reply.
There exist sixty kinds of statements in Maple, whose major ​​​​portion can be used as an expression or within an expression (e.g., assignment, loop, and condition). But why is use an exception?
Moreover, since it is reasonable to think of use as a (partial) generalization (see below) of the subs function, shouldn't the behaviour of use be consistent with do/if?
Compare: "seq((…;…;…), x in x__0):" (not allowed) vs. "for x in x__0 do …;…;… od:" (allowed); "subs(x = x__0, (…;…;…)):" (not allowed) vs. "use x = x__0 in …;…;… od:" (Not allowed! Why?).)
Edit. Besides that, is there some workaround to do something like
  # If use can be used as an expression or within an expression,
use x = 2 + y in 'use y = 4 in x + y end' end;
  # should return “use y~ = 4 in (2 + y) + y~ end use;” and
(use y = 2 + x in x -> x + y end);
  # should output “x~ -> x~ + (2 + x);”.
  # Unfortunately, I cannot find a workaround to stimulate them.
 at present? Note that the `subs` function is unable to do so, so in my opinion, only when the use of `use` is no longer limited to statements will it become a sweeping generalization of `subs`.
The procedure below returns the plots of 3 matrices whose eigenvalues are given and fixed (but chosen randomly). Plots are returned simultaneously via the command display. When I run the procedure 2-3 times, I realize that the drawings are not directly comparable. I have to say that I have naively used the command (three times, i.e. for each plot):
implicitplot("function", -2 .. 2, -2 .. 2, axes = boxed, color = blue, gridrefine = 3, scaling = constrained, resolution = 1000);
Is there a way to "force" maple to return -- each time I run the procedure -- plots of the same size, same scaling and so on ? I would like also to put names on the axis with consistent writings and fonts. Is it possible ?
Many thanks,
Best,
Rachid
with(LinearAlgebra);
P0 := proc(n, epsilon)
local m, N, D1, Modu, fs, f1, f2, f, q, s, r, t, eps, pp, k;
eps := epsilon;
m := n;
N := eval(RandomMatrix(m, m));
N := N/evalf(Norm(evalf(N), 2));
D1 := DiagonalMatrix(Eigenvalues(N));
pp := pointplot({seq([Re(D1[k, k]), Im(D1[k, k])], k = 1 .. m)});
f := (i, j) -> if i = j then D1[i, i]; elif i = j + 1 then (1 - abs(D1[i, i])^2)^(1/2)*(1 - abs(D1[j, j])^2)^(1/2); elif j + 1 < i then (1 - abs(D1[i, i])^2)^(1/2)*(1 - abs(D1[j, j])^2)^(1/2)*mul(-conjugate(D1[t, t]), t = j + 1 .. i - 1); else 0; end if;
Modu := Matrix(m, (i, j) -> f(i, j)); fs := (x, y) -> Norm(1/((x + y*I)*IdentityMatrix(m) - N), 2) - 1/eps;
f1 := (x, y) -> Norm(1/((x + y*I)*IdentityMatrix(m) - D1), 2) - 1/eps;
f2 := (x, y) -> Norm(1/((x + y*I)*IdentityMatrix(m) - Modu), 2) - 1/eps;
s := implicitplot(fs, -2 .. 2, -2 .. 2, axes = boxed, color = blue, gridrefine = 3, scaling = constrained, resolution = 1000);
q := implicitplot(f1, -2 .. 2, -2 .. 2, axes = boxed, gridrefine = 3, scaling = constrained, resolution = 1000);
r := implicitplot(f2, -2 .. 2, -2 .. 2, axes = boxed, color = green, gridrefine = 3, scaling = constrained, resolution = 1000); RETURN(display({q, s, r, pp}));
I make a function
myf := (a, b, c) -> [a*x^2 + b*x + c = 0, solve(a*x^2 + b*x + c = 0, {x})];
I tried
myf(1, 2, -3);
and get
[x^2 + 2*x - 3 = 0, {x = 1}, {x = -3}]
With list mylist := [[1, 2, -3], [3, 2, -1]];
How can I map myf  onto mylist?
I tried
map(myf, mylist);
I can not get the result.
Apparently max and max[index] don't work with tables.
I'd like to put that on a wish list for future development.
Right now the workaround for the first one would be max(entries(atable)) I think.
Haven't solved max[index] yet.
I was wondering whether the rendering of bars
looks also dot like on other computers
Looks like Newtonian notation
When the Fourier transform to the heat equation for example it is useful to represent the Fourier transform of a derivative as the derivative of the transform.  Thus
        FT{d(U(x, t)/dt}  = d(FT{U(t))} / dt,
Where FT => Fourier transform wrt the variable x.
How do I get Maple to obtain the above.
Joe Salacuse
l*`ℏ`*t*sqrt(4*`ℏ`^2*a^2*t^2 + m^2)/(sqrt(2*I*`ℏ`*t*a + m)*sqrt(-2*I*`ℏ`*t*a + m)*m) can be simplified :l *h*t/m
How can I ask Maple to do this.
Given
expr:=  (x^(-(44 + 12*sqrt(69))^(1/3)/6 + 10/(3*(44 + 12*sqrt(69))^(1/3)) + 2/3)) - (x^(sqrt(69)*2^(1/3)*((11 + 3*sqrt(69))^2)^(1/3)/100 - (11*(44 + 12*sqrt(69))^(2/3))/600 - (44 + 12*sqrt(69))^(1/3)/6 + 2/3))
could someone come with a trick to show this is zero using simplification and other methods? I know I can use is and coulditbe but I do not trust these too much due to false positives I've seen from them in some places.
Here is my attempts
expr:=  (x^(-(44 + 12*sqrt(69))^(1/3)/6 + 10/(3*(44 + 12*sqrt(69))^(1/3)) + 2/3)) - (x^(sqrt(69)*2^(1/3)*((11 + 3*sqrt(69))^2)^(1/3)/100 - (11*(44 + 12*sqrt(69))^(2/3))/600 - (44 + 12*sqrt(69))^(1/3)/6 + 2/3));
simplify(expr);
simplify(expr,size);
simplify(expr,symbolic);
simplify(normal(expr));
simplify(normal(expr),symbolic);
simplify(expr) assuming real;
simplify(expr) assuming positive;
is(expr=0);
coulditbe(expr=0);
evalb(expr=0);
Gives
This is for reference, the Mathematica attempt
long time ago I asked about automatic spacing to improve latex for sqrt. A nice solution was provided in https://www.mapleprimes.com/questions/231062-Adding-Space-After-Sqrt-To-Improve-The-Latex
The above is activatived using spaceaftersqrt = true option for latex:-Settings
There is a similar issue for inert integration where a space is typically added before the final dx This is done similar to the above fix using \, See for example this Latex web site giving many examples.
But there is no option I could see to tell Maple to do this automatically for integration.
So all my inert integrals now look not too good as the dx is too close to the integrand. Here are 2 examples with the settings I am using
latex:-Settings(useimaginaryunit=i,
      usecolor = false,
      powersoftrigonometricfunctions= mixed, ## computernotation,
      leavespaceafterfunctionname = true,
      cacheresults = false,
      spaceaftersqrt = true,
      usetypesettingcurrentsettings=true,
      linelength=10000
sol:=sqrt(4*y^3-a*y-b)*a;
Intat( subs(y=a,1/sol),a=y(x));
latex(%);
Int(sol,y);
latex(%);
I copied the latex and compiled it, and this is the result
\documentclass[12pt]{book}
\usepackage{amsmath}
\begin{document}
\int_{}^{y \left(x \right)}\frac{1}{\sqrt{4 a^{3}-a^{2}-b}\, a}d a
\int \sqrt{4 y^{3}-a y -b}\, a d y
\end{document}
Which gives
Compare the output when adding \, by hand to the latex
\begin{document}
\int_{}^{y \left(x \right)}\frac{1}{\sqrt{4 a^{3}-a^{2}-b}\, a}\, d a
\int \sqrt{4 y^{3}-a y -b}\, a \, d y
\end{document}
Which now gives much better result
Actually, what would be nice if the "d" in "dx" was mathrm which becomes
\begin{document}
\int_{}^{y \left(x \right)}\frac{1}{\sqrt{4 a^{3}-a^{2}-b}\, a}\, \mathrm{d} a
\int \sqrt{4 y^{3}-a y -b}\, a \, \mathrm{d} y
\end{document}
But may be I am asking for too much here. But having an option to add \, only for inert integration will be good to have.
Does there exist an option to do this that may be I overlooked?
Maple 2023.2
I have the function: 2*sin(x)+1/2x-1
I want the x-intercepts, but Maple only provides one answer with fsolve.
plot(2*sin(x)+1/2*x-1)
I am trying to find the integer numbers a, b, c, d, t so that the equation sqrt(a x^2 + b x + c) = d x + t have two integer solutions. My code
First I solve
solve(a*x^2 + b*x + c = (d*x + t)^2, x);
I get
(2*d*t - b + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2))/(2*(-d^2 + a)), -(-2*d*t + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2) + b)/(2*(-d^2 + a))
And then, I solve
n := 0;
for a to 10 do
for b to 10 do
for c to 10 do
for d to 10 do
for t to 10 do
mydelta := 4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2;
if 0 < mydelta and type(mydelta, integer) then
x1 := (2*d*t - b + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2))/(2*(-d^2 + a));
x2 := -(-2*d*t + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2) + b)/(2*(-d^2 + a));
if 0 < d*x1 + t and 0 < d*x2 + t and type(x1, integer) and type(x2, integer) and nops({a, b, c, d, t}) = 5 and c <> t^2 and -d^2 + a <> 0 and nops({x1, x2}) = 2 then n := n + 1; L[n] := [a, b, c, d, t]; end if; end if; end do; end do; end do; end do;
L := convert(L, list);
nops(L);
I don't get any solutions. But, when I  solve(sqrt(2*x^2 + 3*x + 5) = x + 9, x); I get two solutions 19, -4.
Where is wrong in my code?
S := [1, 2];
                          S := [1, 2]
T := [1, 2];
                          T := [1, 2]
is(S = T);
Sv := Vector([1, 2]);
Tv := Vector([1, 2]);
is(Sv = Tv);
is(convert(Sv, list) = convert(Tv, list));
how to solve tis type of pdefirst_order_pde.mw
First 153 154 155 156 157 158 159 Last Page 155 of 2427
