Hi, how can I apply classic geometric transformations (rotation, scaling, reflection, etc.) to an imported photo? For example, with this image
The document block (copied from a larger document) in the attached file could be executed with Maple 2022 (in the larger document).
Maple 2023 evaluates... that I have to interrupt.
On my installation I cannot convert the block to 1d input to investigate for hidden characters. This works in 2022.
Trying to manipulate (splitting, cutting, ...) the block lead several times to the 2023 GUI not responding normally which required Maple restart.
What I found with Maple 2022 and lprint: There is a ndash character here
Ein Bild, das Text, Schrift, Reihe enthält.
Automatisch generierte BeschreibungEin Bild, das Schrift, Reihe, Handschrift, weiß enthält.
which must be deleted in the attached file. The larger document does not lprint a ndash. So this might be a copy/paste artefact and is perhaps unrelated to the evaluation problem with 2023.
With Maple 2023 there is no ndash but the output looks differentEin Bild, das Schrift, Diagramm, Reihe, Design enthält.
The whole thing is perhaps related to this
Can someone reproduce and/or help?
interface(version)
`Standard Worksheet Interface, Maple 2023.1, Windows 10, July 7 2023 Build ID 1723669`
exp(`–`((1/2)*x^2)-(1/2)*y^2)/(2*Pi)
(1/2)*exp(-(1/2)*x^2-(1/2)*y^2)/Pi
`if`(evalf((1/2)*exp(-(1/2)*x^2-(1/2)*y^2)/Pi) < 0.7957747150e-1, (1/2)*exp(-(1/2)*x^2-(1/2)*y^2)/Pi, NONE); p3 := plot3d(%, x = -3 .. 3, y = -3 .. 3, color = blue); `if`(evalf((1/2)*exp(-(1/2)*x^2-(1/2)*y^2)/Pi) < 0.2153927929e-1, (1/2)*exp(-(1/2)*x^2-(1/2)*y^2)/Pi, NONE); p4 := plot3d(%+0.1e-3, x = -3 .. 3, y = -3 .. 3, color = red)
Download plot3d_in_2023_not_working.mw
I'm scratching my head to understand this behaviour of MultiSeries. If I type
MultiSeries[series](diff(ln(GAMMA(1/x)), x), x)
Maple 2022.2 answers
But as is known (and maple confirms)
diff(ln(GAMMA(x)), x)=Psi(x)
But prompting in maple
MultiSeries[series](Psi(1/x), x)
It answers
that is off by a x^2 factor with the former answer, while one expects to obtain the same answer as before. Why is this? (I tried assuming positivity, same discrepancy results).
For several hours I experience difficulties to upload a mw file (file LaneEmdenNumeric.mw to answer this question).
Given the error message I get
I thought it was a general technical problem.
But then I realized that this file ColumnSorting_4.mw , for instance, could be uploaded.
Nevertheless, as soon as I try to upload LaneEmdenNumeric.mw I get the error displayed above and it becomes impossible to upload any other file, even ColumnSorting_4.mw.
Does someone has any idea about what's going on?
TIA
For the record, LaneEmdenNumeric.mw contains nothing special that could prevent its uploading.
This file can be uploaded here  DropBox  (replace the txt extension by mw before opening it with Maple).
The (Induced) Subgraph Isomorphism computational problem is, given H and G, determine whether there is a (induced) subgraph isomorphism from H to G. See https://en.wikipedia.org/wiki/Induced_subgraph_isomorphism_problem
In Maple, IsSubgraphIsomorphic(G1,G2)  returns true if G1 is isomorphic to some subgraph of G2. However, it does not provide options for induced subgraphs. For example,
with(GraphTheory):
claw:=CompleteGraph(1,3);
g:=CompleteGraph(2,2,2,2):
DrawGraph(g);
IsSubgraphIsomorphic(claw,g) #true
So the graph g contains a claw as a subgraph. But every claw in graph g  is non-induced. So g does not contain any induced claw. Maple does not appear to have this feature to determine if a graph contains a induced subgraph isomorphic to another graph. It is unclear whether we can modify some code in IsSubgraphIsomorphic  to achieve this goal.
n := 1
ode1 := (diff(xi^2*(diff(`&theta;__0`(xi), xi)), xi))/xi^2 = -`&theta;__0`(xi)^n
(2*xi*(diff(theta__0(xi), xi))+xi^2*(diff(diff(theta__0(xi), xi), xi)))/xi^2 = -theta__0(xi)
Emden_solution := dsolve({ode1, `&theta;__0`(0) = 1, (D(`&theta;__0`))(0) = 0}, `&theta;__0`(xi))
theta__0(xi) = sin(xi)/xi
`&xi;__1` := Pi
Pi
alpha := 2.356
2.356
ode2 := diff(gamma(xi), xi, xi)-2*gamma(xi)/xi^2+alpha^2*gamma(xi) = -`&theta;__0`(xi)^n*xi^2
diff(diff(gamma(xi), xi), xi)-2*gamma(xi)/xi^2+5.550736*gamma(xi) = -theta__0(xi)*xi^2
ode2_substituted := subs(Emden_solution, ode2)
diff(diff(gamma(xi), xi), xi)-2*gamma(xi)/xi^2+5.550736*gamma(xi) = -xi*sin(xi)
ode2_substituted_solution := dsolve({ode2_substituted, gamma(`&xi;__1`)+`&xi;__1`*(D(gamma))(`&xi;__1`) = 0, gamma(0) = 0, (D(gamma))(0) = 0}, gamma(xi))[1]
gamma(xi) = (1/80895305241)*(-17776312500*xi^2*sin(xi)+4601562500000*cos((589/250)*xi)*xi*Pi/(589*cos((89/250)*Pi)*Pi-250*sin((89/250)*Pi))+7812500000*xi*cos(xi)-1953125000000*sin((589/250)*xi)*Pi/(589*cos((89/250)*Pi)*Pi-250*sin((89/250)*Pi))-7812500000*sin(xi))/xi
ode2_diff := diff(ode2_substituted_solution, xi)
diff(gamma(xi), xi) = (1/80895305241)*(-43365125000*xi*sin(xi)-17776312500*xi^2*cos(xi)-10841281250000*sin((589/250)*xi)*xi*Pi/(589*cos((89/250)*Pi)*Pi-250*sin((89/250)*Pi)))/xi-(1/80895305241)*(-17776312500*xi^2*sin(xi)+4601562500000*cos((589/250)*xi)*xi*Pi/(589*cos((89/250)*Pi)*Pi-250*sin((89/250)*Pi))+7812500000*xi*cos(xi)-1953125000000*sin((589/250)*xi)*Pi/(589*cos((89/250)*Pi)*Pi-250*sin((89/250)*Pi))-7812500000*sin(xi))/xi^2
diff_at_pi := evalf[5](subs(xi = Pi, rhs(ode2_diff)))
0.41947e-1
If i solve
"Emden_solution using type=numeric, then how to proceed to get the same diff_at_pi or close with some tolerance"?""
Emden_solution := dsolve({ode1, `&theta;__0`(0) = 1, (D(`&theta;__0`))(0) = 0}, `&theta;__0`(xi), type = numeric)
proc (x_rkf45) local _res, _dat, _vars, _solnproc, _xout, _ndsol, _pars, _n, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x_rkf45) else _xout := evalf(x_rkf45) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _dtbl, _dat, _vmap, _x0, _y0, _val, _dig, _n, _ne, _nd, _nv, _pars, _ini, _par, _i, _j, _k, _src; option `Copyright (c) 2002 by Waterloo Maple Inc. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _pars := []; _dtbl := array( 1 .. 4, [( 1 ) = (array( 1 .. 28, [( 1 ) = (datatype = float[8], order = C_order, storage = rectangular), ( 2 ) = (datatype = float[8], order = C_order, storage = rectangular), ( 3 ) = ([0, 0, 0, Array(1..0, 1..2, {}, datatype = float[8], order = C_order)]), ( 4 ) = (Array(1..65, {(1) = 2, (2) = 2, (3) = 0, (4) = 0, (5) = 0, (6) = 0, (7) = 1, (8) = 0, (9) = 0, (10) = 0, (11) = 0, (12) = 0, (13) = 0, (14) = 0, (15) = 0, (16) = 0, (17) = 0, (18) = 1, (19) = 30000, (20) = 0, (21) = 0, (22) = 1, (23) = 4, (24) = 0, (25) = 1, (26) = 15, (27) = 1, (28) = 0, (29) = 1, (30) = 3, (31) = 3, (32) = 0, (33) = 1, (34) = 0, (35) = 0, (36) = 0, (37) = 0, (38) = 0, (39) = 0, (40) = 0, (41) = 0, (42) = 0, (43) = 1, (44) = 0, (45) = 0, (46) = 0, (47) = 0, (48) = 0, (49) = 0, (50) = 50, (51) = 1, (52) = 0, (53) = 0, (54) = 0, (55) = 0, (56) = 0, (57) = 0, (58) = 0, (59) = 10000, (60) = 0, (61) = 1000, (62) = 0, (63) = 0, (64) = -1, (65) = 0}, datatype = integer[8])), ( 5 ) = (Array(1..28, {(1) = .0, (2) = 0.10e-5, (3) = .0, (4) = 0.500001e-14, (5) = .0, (6) = 0.15142976267524639e-1, (7) = .0, (8) = 0.10e-5, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = 1.0, (14) = .0, (15) = .49999999999999, (16) = .0, (17) = 1.0, (18) = 1.0, (19) = .0, (20) = .0, (21) = 1.0, (22) = 1.0, (23) = .0, (24) = .0, (25) = 0.10e-14, (26) = .0, (27) = .0, (28) = .0}, datatype = float[8], order = C_order)), ( 6 ) = (Array(1..2, {(1) = 1.0, (2) = .0}, datatype = float[8], order = C_order)), ( 7 ) = ([Array(1..4, 1..7, {(1, 1) = .0, (1, 2) = .203125, (1, 3) = .3046875, (1, 4) = .75, (1, 5) = .8125, (1, 6) = .40625, (1, 7) = .8125, (2, 1) = 0.6378173828125e-1, (2, 2) = .0, (2, 3) = .279296875, (2, 4) = .27237892150878906, (2, 5) = -0.9686851501464844e-1, (2, 6) = 0.1956939697265625e-1, (2, 7) = .5381584167480469, (3, 1) = 0.31890869140625e-1, (3, 2) = .0, (3, 3) = -.34375, (3, 4) = -.335235595703125, (3, 5) = .2296142578125, (3, 6) = .41748046875, (3, 7) = 11.480712890625, (4, 1) = 0.9710520505905151e-1, (4, 2) = .0, (4, 3) = .40350341796875, (4, 4) = 0.20297467708587646e-1, (4, 5) = -0.6054282188415527e-2, (4, 6) = -0.4770040512084961e-1, (4, 7) = .77858567237854}, datatype = float[8], order = C_order), Array(1..6, 1..6, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = 1.0, (2, 1) = .25, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = 1.0, (3, 1) = .1875, (3, 2) = .5625, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = 2.0, (4, 1) = .23583984375, (4, 2) = -.87890625, (4, 3) = .890625, (4, 4) = .0, (4, 5) = .0, (4, 6) = .2681884765625, (5, 1) = .1272735595703125, (5, 2) = -.5009765625, (5, 3) = .44921875, (5, 4) = -0.128936767578125e-1, (5, 5) = .0, (5, 6) = 0.626220703125e-1, (6, 1) = -0.927734375e-1, (6, 2) = .626220703125, (6, 3) = -.4326171875, (6, 4) = .1418304443359375, (6, 5) = -0.861053466796875e-1, (6, 6) = .3131103515625}, datatype = float[8], order = C_order), Array(1..6, {(1) = .0, (2) = .386, (3) = .21, (4) = .63, (5) = 1.0, (6) = 1.0}, datatype = float[8], order = C_order), Array(1..6, {(1) = .25, (2) = -.1043, (3) = .1035, (4) = -0.362e-1, (5) = .0, (6) = .0}, datatype = float[8], order = C_order), Array(1..6, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = 1.544, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (3, 1) = .9466785280815533, (3, 2) = .25570116989825814, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (4, 1) = 3.3148251870684886, (4, 2) = 2.896124015972123, (4, 3) = .9986419139977808, (4, 4) = .0, (4, 5) = .0, (5, 1) = 1.2212245092262748, (5, 2) = 6.019134481287752, (5, 3) = 12.537083329320874, (5, 4) = -.687886036105895, (5, 5) = .0, (6, 1) = 1.2212245092262748, (6, 2) = 6.019134481287752, (6, 3) = 12.537083329320874, (6, 4) = -.687886036105895, (6, 5) = 1.0}, datatype = float[8], order = C_order), Array(1..6, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = -5.6688, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (3, 1) = -2.4300933568337584, (3, 2) = -.20635991570891224, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (4, 1) = -.10735290581452621, (4, 2) = -9.594562251021896, (4, 3) = -20.470286148096154, (4, 4) = .0, (4, 5) = .0, (5, 1) = 7.496443313968615, (5, 2) = -10.246804314641219, (5, 3) = -33.99990352819906, (5, 4) = 11.708908932061595, (5, 5) = .0, (6, 1) = 8.083246795922411, (6, 2) = -7.981132988062785, (6, 3) = -31.52159432874373, (6, 4) = 16.319305431231363, (6, 5) = -6.0588182388340535}, datatype = float[8], order = C_order), Array(1..3, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = 10.126235083446911, (2, 2) = -7.487995877607633, (2, 3) = -34.800918615557414, (2, 4) = -7.9927717075687275, (2, 5) = 1.0251377232956207, (3, 1) = -.6762803392806898, (3, 2) = 6.087714651678606, (3, 3) = 16.43084320892463, (3, 4) = 24.767225114183653, (3, 5) = -6.5943891257167815}, datatype = float[8], order = C_order)]), ( 9 ) = ([Array(1..2, {(1) = .1, (2) = .1}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, 1..2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0}, datatype = float[8], order = C_order), Array(1..2, 1..2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, 1..2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0}, datatype = float[8], order = C_order), Array(1..2, 1..6, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = 0, (2) = 0}, datatype = integer[8]), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..4, {(1) = .0, (2) = .0, (3) = .0, (4) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = 0, (2) = 0}, datatype = integer[8])]), ( 8 ) = ([Array(1..2, {(1) = 1.0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = .0}, datatype = float[8], order = C_order), Array(1..2, {(1) = .0, (2) = -.3333333333333333}, datatype = float[8], order = C_order), 0, 0]), ( 11 ) = (Array(1..6, 0..2, {(1, 1) = .0, (1, 2) = .0, (2, 0) = .0, (2, 1) = .0, (2, 2) = .0, (3, 0) = .0, (3, 1) = .0, (3, 2) = .0, (4, 0) = .0, (4, 1) = .0, (4, 2) = .0, (5, 0) = .0, (5, 1) = .0, (5, 2) = .0, (6, 0) = .0, (6, 1) = .0, (6, 2) = .0}, datatype = float[8], order = C_order)), ( 10 ) = ([proc (N, xi, Y, YP) option `[Y[1] = theta__0(xi), Y[2] = diff(theta__0(xi),xi)]`; if xi = 0 then if abs(Y[2]) <= 0. then YP[1] := 0; YP[2] := -(1/3)*Y[1] else error "system with provided initial conditions is singular" end if else YP[1] := Y[2]; YP[2] := -Y[1]-2*Y[2]/xi end if; 0 end proc, -1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), ( 13 ) = (), ( 12 ) = (), ( 15 ) = ("rkf45"), ( 14 ) = ([0, 0]), ( 18 ) = ([]), ( 19 ) = (0), ( 16 ) = ([0, 0, 0, 0, 0, []]), ( 17 ) = ([proc (N, xi, Y, YP) option `[Y[1] = theta__0(xi), Y[2] = diff(theta__0(xi),xi)]`; if xi = 0 then if abs(Y[2]) <= 0. then YP[1] := 0; YP[2] := -(1/3)*Y[1] else error "system with provided initial conditions is singular" end if else YP[1] := Y[2]; YP[2] := -Y[1]-2*Y[2]/xi end if; 0 end proc, -1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = ([]), ( 21 ) = (0), ( 27 ) = (""), ( 26 ) = (Array(1..0, {})), ( 25 ) = (Array(1..0, {})), ( 24 ) = (0), ( 28 ) = (0)  ] ))  ] ); _y0 := Array(0..2, {(1) = 0., (2) = 1.}); _vmap := array( 1 .. 2, [( 1 ) = (1), ( 2 ) = (2)  ] ); _x0 := _dtbl[1][5][5]; _n := _dtbl[1][4][1]; _ne := _dtbl[1][4][3]; _nd := _dtbl[1][4][4]; _nv := _dtbl[1][4][16]; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then if _Env_smart_dsolve_numeric = true or _dtbl[1][4][10] = 1 then if _xout = "left" then if type(_dtbl[2], 'table') then return _dtbl[2][5][1] end if elif _xout = "right" then if type(_dtbl[3], 'table') then return _dtbl[3][5][1] end if end if end if; return _dtbl[1][5][5] elif _xout = "method" then return _dtbl[1][15] elif _xout = "storage" then return evalb(_dtbl[1][4][10] = 1) elif _xout = "leftdata" then if not type(_dtbl[2], 'array') then return NULL else return eval(_dtbl[2]) end if elif _xout = "rightdata" then if not type(_dtbl[3], 'array') then return NULL else return eval(_dtbl[3]) end if elif _xout = "enginedata" then return eval(_dtbl[1]) elif _xout = "enginereset" then _dtbl[2] := evaln(_dtbl[2]); _dtbl[3] := evaln(_dtbl[3]); return NULL elif _xout = "initial" then return procname(_y0[0]) elif _xout = "laxtol" then return _dtbl[`if`(member(_dtbl[4], {2, 3}), _dtbl[4], 1)][5][18] elif _xout = "numfun" then return `if`(member(_dtbl[4], {2, 3}), _dtbl[_dtbl[4]][4][18], 0) elif _xout = "parameters" then return [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return procname(_y0[0]), [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _dtbl[4] <> 2 and _dtbl[4] <> 3 or _x0-_dtbl[_dtbl[4]][5][1] = 0. then error "no information is available on last computed point" else _xout := _dtbl[_dtbl[4]][5][1] end if elif _xout = "function" then if _dtbl[1][4][33]-2. = 0 then return eval(_dtbl[1][10], 1) else return eval(_dtbl[1][10][1], 1) end if elif _xout = "map" then return copy(_vmap) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then if true then error "initial conditions cannot be changed for systems with removable singularities" end if; _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); _i := false; if _par <> [] then _i := `dsolve/numeric/process_parameters`(_n, _pars, _par, _y0) end if; if _ini <> [] then _i := `dsolve/numeric/process_initial`(_n-_ne, _ini, _y0, _pars, _vmap) or _i end if; if _i then `dsolve/numeric/SC/reinitialize`(_dtbl, _y0, _n, procname, _pars); if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') and _dtbl[1][4][10] <> 1 then procname("right") := _y0[0]; procname("left") := _y0[0] end if end if; if _xout = "initial" then return [_y0[0], seq(_y0[_vmap[_i]], _i = 1 .. _n-_ne)] elif _xout = "parameters" then return [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] else return [_y0[0], seq(_y0[_vmap[_i]], _i = 1 .. _n-_ne)], [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] end if elif _xin = "eventstop" then if _nv = 0 then error "this solution has no events" end if; _i := _dtbl[4]; if _i <> 2 and _i <> 3 then return 0 end if; if _dtbl[_i][4][10] = 1 and assigned(_dtbl[5-_i]) and _dtbl[_i][4][9] < 100 and 100 <= _dtbl[5-_i][4][9] then _i := 5-_i; _dtbl[4] := _i; _j := round(_dtbl[_i][4][17]); return round(_dtbl[_i][3][1][_j, 1]) elif 100 <= _dtbl[_i][4][9] then _j := round(_dtbl[_i][4][17]); return round(_dtbl[_i][3][1][_j, 1]) else return 0 end if elif _xin = "eventstatus" then if _nv = 0 then error "this solution has no events" end if; _i := [selectremove(proc (a) options operator, arrow; _dtbl[1][3][1][a, 7] = 1 end proc, {seq(_j, _j = 1 .. round(_dtbl[1][3][1][_nv+1, 1]))})]; return ':-enabled' = _i[1], ':-disabled' = _i[2] elif _xin = "eventclear" then if _nv = 0 then error "this solution has no events" end if; _i := _dtbl[4]; if _i <> 2 and _i <> 3 then error "no events to clear" end if; if _dtbl[_i][4][10] = 1 and assigned(_dtbl[5-_i]) and _dtbl[_i][4][9] < 100 and 100 < _dtbl[5-_i][4][9] then _dtbl[4] := 5-_i; _i := 5-_i end if; if _dtbl[_i][4][9] < 100 then error "no events to clear" elif _nv < _dtbl[_i][4][9]-100 then error "event error condition cannot be cleared" else _j := _dtbl[_i][4][9]-100; if irem(round(_dtbl[_i][3][1][_j, 4]), 2) = 1 then error "retriggerable events cannot be cleared" end if; _j := round(_dtbl[_i][3][1][_j, 1]); for _k to _nv do if _dtbl[_i][3][1][_k, 1] = _j then if _dtbl[_i][3][1][_k, 2] = 3 then error "range events cannot be cleared" end if; _dtbl[_i][3][1][_k, 8] := _dtbl[_i][3][1][_nv+1, 8] end if end do; _dtbl[_i][4][17] := 0; _dtbl[_i][4][9] := 0; if _dtbl[1][4][10] = 1 then if _i = 2 then try procname(procname("left")) catch:  end try else try procname(procname("right")) catch:  end try end if end if end if; return  elif type(_xin, `=`) and member(lhs(_xin), {"eventdisable", "eventenable"}) then if _nv = 0 then error "this solution has no events" end if; if type(rhs(_xin), {('list')('posint'), ('set')('posint')}) then _i := {op(rhs(_xin))} elif type(rhs(_xin), 'posint') then _i := {rhs(_xin)} else error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; if select(proc (a) options operator, arrow; _nv < a end proc, _i) <> {} then error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; _k := {}; for _j to _nv do if member(round(_dtbl[1][3][1][_j, 1]), _i) then _k := `union`(_k, {_j}) end if end do; _i := _k; if lhs(_xin) = "eventdisable" then _dtbl[4] := 0; _j := [evalb(assigned(_dtbl[2]) and member(_dtbl[2][4][17], _i)), evalb(assigned(_dtbl[3]) and member(_dtbl[3][4][17], _i))]; for _k in _i do _dtbl[1][3][1][_k, 7] := 0; if assigned(_dtbl[2]) then _dtbl[2][3][1][_k, 7] := 0 end if; if assigned(_dtbl[3]) then _dtbl[3][3][1][_k, 7] := 0 end if end do; if _j[1] then for _k to _nv+1 do if _k <= _nv and not type(_dtbl[2][3][4][_k, 1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to defined init `, _dtbl[2][3][4][_k, 1]); _dtbl[2][3][1][_k, 8] := _dtbl[2][3][4][_k, 1] elif _dtbl[2][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[2][3][1][_k, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to rate hysteresis init `, _dtbl[2][5][24]); _dtbl[2][3][1][_k, 8] := _dtbl[2][5][24] elif _dtbl[2][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[2][3][1][_k, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to initial init `, _x0); _dtbl[2][3][1][_k, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to fireinitial init `, _x0-1); _dtbl[2][3][1][_k, 8] := _x0-1 end if end do; _dtbl[2][4][17] := 0; _dtbl[2][4][9] := 0; if _dtbl[1][4][10] = 1 then procname(procname("left")) end if end if; if _j[2] then for _k to _nv+1 do if _k <= _nv and not type(_dtbl[3][3][4][_k, 2], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to defined init `, _dtbl[3][3][4][_k, 2]); _dtbl[3][3][1][_k, 8] := _dtbl[3][3][4][_k, 2] elif _dtbl[3][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[3][3][1][_k, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to rate hysteresis init `, _dtbl[3][5][24]); _dtbl[3][3][1][_k, 8] := _dtbl[3][5][24] elif _dtbl[3][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[3][3][1][_k, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to initial init `, _x0); _dtbl[3][3][1][_k, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to fireinitial init `, _x0+1); _dtbl[3][3][1][_k, 8] := _x0+1 end if end do; _dtbl[3][4][17] := 0; _dtbl[3][4][9] := 0; if _dtbl[1][4][10] = 1 then procname(procname("right")) end if end if else for _k in _i do _dtbl[1][3][1][_k, 7] := 1 end do; _dtbl[2] := evaln(_dtbl[2]); _dtbl[3] := evaln(_dtbl[3]); _dtbl[4] := 0; if _dtbl[1][4][10] = 1 then if _x0 <= procname("right") then try procname(procname("right")) catch:  end try end if; if procname("left") <= _x0 then try procname(procname("left")) catch:  end try end if end if end if; return  elif type(_xin, `=`) and lhs(_xin) = "eventfired" then if not type(rhs(_xin), 'list') then error "'eventfired' must be specified as a list" end if; if _nv = 0 then error "this solution has no events" end if; if _dtbl[4] <> 2 and _dtbl[4] <> 3 then error "'direction' must be set prior to calling/setting 'eventfired'" end if; _i := _dtbl[4]; _val := NULL; if not assigned(_EnvEventRetriggerWarned) then _EnvEventRetriggerWarned := false end if; for _k in rhs(_xin) do if type(_k, 'integer') then _src := _k elif type(_k, 'integer' = 'anything') and type(evalf(rhs(_k)), 'numeric') then _k := lhs(_k) = evalf[max(Digits, 18)](rhs(_k)); _src := lhs(_k) else error "'eventfired' entry is not valid: %1", _k end if; if _src < 1 or round(_dtbl[1][3][1][_nv+1, 1]) < _src then error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; _src := {seq(`if`(_dtbl[1][3][1][_j, 1]-_src = 0., _j, NULL), _j = 1 .. _nv)}; if nops(_src) <> 1 then error "'eventfired' can only be set/queried for root-finding events and time/interval events" end if; _src := _src[1]; if _dtbl[1][3][1][_src, 2] <> 0. and _dtbl[1][3][1][_src, 2]-2. <> 0. then error "'eventfired' can only be set/queried for root-finding events and time/interval events" elif irem(round(_dtbl[1][3][1][_src, 4]), 2) = 1 then if _EnvEventRetriggerWarned = false then WARNING(`'eventfired' has no effect on events that retrigger`) end if; _EnvEventRetriggerWarned := true end if; if _dtbl[_i][3][1][_src, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_src, 4]), 32), 2) = 1 then _val := _val, undefined elif type(_dtbl[_i][3][4][_src, _i-1], 'undefined') or _i = 2 and _dtbl[2][3][1][_src, 8] < _dtbl[2][3][4][_src, 1] or _i = 3 and _dtbl[3][3][4][_src, 2] < _dtbl[3][3][1][_src, 8] then _val := _val, _dtbl[_i][3][1][_src, 8] else _val := _val, _dtbl[_i][3][4][_src, _i-1] end if; if type(_k, `=`) then if _dtbl[_i][3][1][_src, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_src, 4]), 32), 2) = 1 then error "cannot set event code for a rate hysteresis event" end if; userinfo(3, {'events', 'eventreset'}, `manual set event code `, _src, ` to value `, rhs(_k)); _dtbl[_i][3][1][_src, 8] := rhs(_k); _dtbl[_i][3][4][_src, _i-1] := rhs(_k) end if end do; return [_val] elif type(_xin, `=`) and lhs(_xin) = "direction" then if not member(rhs(_xin), {-1, 1, ':-left', ':-right'}) then error "'direction' must be specified as either '1' or 'right' (positive) or '-1' or 'left' (negative)" end if; _src := `if`(_dtbl[4] = 2, -1, `if`(_dtbl[4] = 3, 1, undefined)); _i := `if`(member(rhs(_xin), {1, ':-right'}), 3, 2); _dtbl[4] := _i; _dtbl[_i] := `dsolve/numeric/SC/IVPdcopy`(_dtbl[1], `if`(assigned(_dtbl[_i]), _dtbl[_i], NULL)); if 0 < _nv then for _j to _nv+1 do if _j <= _nv and not type(_dtbl[_i][3][4][_j, _i-1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to defined init `, _dtbl[_i][3][4][_j, _i-1]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][3][4][_j, _i-1] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to rate hysteresis init `, _dtbl[_i][5][24]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][5][24] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to initial init `, _x0); _dtbl[_i][3][1][_j, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to fireinitial init `, _x0-2*_i+5.0); _dtbl[_i][3][1][_j, 8] := _x0-2*_i+5.0 end if end do end if; return _src elif _xin = "eventcount" then if _dtbl[1][3][1] = 0 or _dtbl[4] <> 2 and _dtbl[4] <> 3 then return 0 else return round(_dtbl[_dtbl[4]][3][1][_nv+1, 12]) end if elif type(_xin, `=`) and lhs(_xin) = "setdatacallback" then if not type(rhs(_xin), 'nonegint') then error "data callback must be a nonnegative integer (address)" end if; _dtbl[1][28] := rhs(_xin) else return "procname" end if end if; if _xout = _x0 then return [_x0, seq(evalf(_dtbl[1][6][_vmap[_i]]), _i = 1 .. _n-_ne)] end if; _i := `if`(_x0 <= _xout, 3, 2); if _xin = "last" and 0 < _dtbl[_i][4][9] and _dtbl[_i][4][9] < 100 then _dat := eval(_dtbl[_i], 2); _j := _dat[4][20]; return [_dat[11][_j, 0], seq(_dat[11][_j, _vmap[_i]], _i = 1 .. _n-_ne-_nd), seq(_dat[8][1][_vmap[_i]], _i = _n-_ne-_nd+1 .. _n-_ne)] end if; if not type(_dtbl[_i], 'array') then _dtbl[_i] := `dsolve/numeric/SC/IVPdcopy`(_dtbl[1], `if`(assigned(_dtbl[_i]), _dtbl[_i], NULL)); if 0 < _nv then for _j to _nv+1 do if _j <= _nv and not type(_dtbl[_i][3][4][_j, _i-1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to defined init `, _dtbl[_i][3][4][_j, _i-1]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][3][4][_j, _i-1] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to rate hysteresis init `, _dtbl[_i][5][24]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][5][24] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to initial init `, _x0); _dtbl[_i][3][1][_j, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to fireinitial init `, _x0-2*_i+5.0); _dtbl[_i][3][1][_j, 8] := _x0-2*_i+5.0 end if end do end if end if; if _xin <> "last" then if 0 < 0 then if `dsolve/numeric/checkglobals`(op(_dtbl[1][14]), _pars, _n, _y0) then `dsolve/numeric/SC/reinitialize`(_dtbl, _y0, _n, procname, _pars, _i) end if end if; if _dtbl[1][4][7] = 0 then error "parameters must be initialized before solution can be computed" end if end if; _dat := eval(_dtbl[_i], 2); _dtbl[4] := _i; try _src := `dsolve/numeric/SC/IVPrun`(_dat, _xout) catch: userinfo(2, `dsolve/debug`, print(`Exception in solnproc:`, [lastexception][2 .. -1])); error  end try; if _dat[17] <> _dtbl[1][17] then _dtbl[1][17] := _dat[17]; _dtbl[1][10] := _dat[10] end if; if _src = 0 and 100 < _dat[4][9] then _val := _dat[3][1][_nv+1, 8] else _val := _dat[11][_dat[4][20], 0] end if; if _src <> 0 or _dat[4][9] <= 0 then _dtbl[1][5][1] := _xout else _dtbl[1][5][1] := _val end if; if _i = 3 and _val < _xout then Rounding := -infinity; if _dat[4][9] = 1 then error "cannot evaluate the solution further right of %1, probably a singularity", evalf[8](_val) elif _dat[4][9] = 2 then error "cannot evaluate the solution further right of %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_val) elif _dat[4][9] = 3 then if _dat[4][25] = 3 then error "cannot evaluate the solution past the initial point, problem may be initially singular or improperly set up" else error "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up" end if elif _dat[4][9] = 4 then error "cannot evaluate the solution further right of %1, accuracy goal cannot be achieved with specified 'minstep'", evalf[8](_val) elif _dat[4][9] = 5 then error "cannot evaluate the solution further right of %1, too many step failures, tolerances may be too loose for problem", evalf[8](_val) elif _dat[4][9] = 6 then error "cannot evaluate the solution further right of %1, cannot downgrade delay storage for problems with delay derivative order > 1, try increasing delaypts", evalf[8](_val) elif _dat[4][9] = 10 then error "cannot evaluate the solution further right of %1, interrupt requested", evalf[8](_val) elif 100 < _dat[4][9] then if _dat[4][9]-100 = _nv+1 then error "constraint projection failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-100 = _nv+2 then error "index-1 and derivative evaluation failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-100 = _nv+3 then error "maximum number of event iterations reached (%1) at t=%2", round(_dat[3][1][_nv+1, 3]), evalf[8](_val) else if _Env_dsolve_nowarnstop <> true then `dsolve/numeric/warning`(StringTools:-FormatMessage("cannot evaluate the solution further right of %1, event #%2 triggered a halt", evalf[8](_val), round(_dat[3][1][_dat[4][9]-100, 1]))) end if; Rounding := 'nearest'; _xout := _val end if else error "cannot evaluate the solution further right of %1", evalf[8](_val) end if elif _i = 2 and _xout < _val then Rounding := infinity; if _dat[4][9] = 1 then error "cannot evaluate the solution further left of %1, probably a singularity", evalf[8](_val) elif _dat[4][9] = 2 then error "cannot evaluate the solution further left of %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_val) elif _dat[4][9] = 3 then if _dat[4][25] = 3 then error "cannot evaluate the solution past the initial point, problem may be initially singular or improperly set up" else error "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up" end if elif _dat[4][9] = 4 then error "cannot evaluate the solution further left of %1, accuracy goal cannot be achieved with specified 'minstep'", evalf[8](_val) elif _dat[4][9] = 5 then error "cannot evaluate the solution further left of %1, too many step failures, tolerances may be too loose for problem", evalf[8](_val) elif _dat[4][9] = 6 then error "cannot evaluate the solution further left of %1, cannot downgrade delay storage for problems with delay derivative order > 1, try increasing delaypts", evalf[8](_val) elif _dat[4][9] = 10 then error "cannot evaluate the solution further right of %1, interrupt requested", evalf[8](_val) elif 100 < _dat[4][9] then if _dat[4][9]-100 = _nv+1 then error "constraint projection failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-100 = _nv+2 then error "index-1 and derivative evaluation failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-100 = _nv+3 then error "maximum number of event iterations reached (%1) at t=%2", round(_dat[3][1][_nv+1, 3]), evalf[8](_val) else if _Env_dsolve_nowarnstop <> true then `dsolve/numeric/warning`(StringTools:-FormatMessage("cannot evaluate the solution further left of %1, event #%2 triggered a halt", evalf[8](_val), round(_dat[3][1][_dat[4][9]-100, 1]))) end if; Rounding := 'nearest'; _xout := _val end if else error "cannot evaluate the solution further left of %1", evalf[8](_val) end if end if; if _EnvInFsolve = true then _dig := _dat[4][26]; if type(_EnvDSNumericSaveDigits, 'posint') then _dat[4][26] := _EnvDSNumericSaveDigits else _dat[4][26] := Digits end if; _Env_dsolve_SC_native := true; if _dat[4][25] = 1 then _i := 1; _dat[4][25] := 2 else _i := _dat[4][25] end if; _val := `dsolve/numeric/SC/IVPval`(_dat, _xout, _src); _dat[4][25] := _i; _dat[4][26] := _dig; [_xout, seq(_val[_vmap[_i]], _i = 1 .. _n-_ne)] else Digits := _dat[4][26]; _val := `dsolve/numeric/SC/IVPval`(eval(_dat, 2), _xout, _src); [_xout, seq(_val[_vmap[_i]], _i = 1 .. _n-_ne)] end if end proc, (2) = Array(0..0, {}), (3) = [xi, theta__0(xi), diff(theta__0(xi), xi)], (4) = []}); _vars := _dat[3]; _pars := map(rhs, _dat[4]); _n := nops(_vars)-1; _solnproc := _dat[1]; if not type(_xout, 'numeric') then if member(x_rkf45, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x_rkf45, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x_rkf45, ["last", 'last', "initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x_rkf45, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x_rkf45), 'string') = rhs(x_rkf45); if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else error "initial and/or parameter values must be specified in a list" end if; if lhs(_xout) = "initial" then return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x_rkf45), 'string') = rhs(x_rkf45)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _vars end if; if procname <> unknown then return ('procname')(x_rkf45) else _ndsol := 1; _ndsol := _ndsol; _ndsol := pointto(_dat[2][0]); return ('_ndsol')(x_rkf45) end if end if; try _res := _solnproc(_xout); [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] catch: error  end try end proc
Download n=1_analytical.mw
ode1 is Lane emden equation that can be solved analytically for n=0,1,5 .
For other values of n it needs to be solved numerically.
My question is how to proceed and use the numeric result in ode2 with bcs mentioned and get same or close result to analytical one. I am trying to verify alpha. In the worksheet i have chosen n=1 because i want to learn how to deal with numeric solution for which i already have the answer to verify. If ode2 also needs to to solved numeric its ok. The point is to get at the derivative value from various alpha values for different n like 3. Please help and let me know if additional info is needed.
I re-opened my maple file and got the following error code:
"There were problems during the loading process. Your worksheet may be incomplete"
I have attatched the original file and todays backup file.
Backup:
D_Maple_files_Mat_2_Hjemmeopgave_7_igen22_MAS_1_1.mw
Original:
Hjemmeopgave_7_igen.mw
I hope some of you can solve this issue for me, as I am at a loss. Appreciate any help I can get.
This setup works, where B extends A, then B method access local variable in A directly, since it now becomes part of the object B itself
module A()
  option object;
  local s::string:="";
end module;
module B()
   option object(A);
   export foo::static:=proc(_self,$)
      _self:-s := cat(_self:-s,"something");
      print(_self:-s);
end module;
o:=Object(B);
o:-foo()
Gives "something"
Now, I changed B, by adding an anonymous local proc() and did the same exact thing as above, which is to access s.
Now Maple complains that B does not export s
module A()
  option object;
end module;
module B()
   option object(A);
        proc()
            _self:-s:=cat(_self:-s,"somethig");
            print(_self:-s);
        end proc();
end module;
o:=Object(B);
o:-foo()
It gives
Error, (in anonymous procedure called from anonymous procedure) module `B` does not export `s`
Could someone help me understand why this happens? How it works in the first example but not in the second?  I do not see why it would make difference. isn't anonymous procedure part of the class that is being extended?
Update
It is worst than I thought. Even named local proc, inside method now fail. Here is an example
module A()
  option object;
end module;
module B()
   option object(A);
        local z::string:="something";
        local my_inner_proc:=proc()
            _self:-s:=cat(_self:-s,z);
        end proc();
        my_inner_proc();
end module;
o:=Object(B);
o:-foo()
Gives
I was using code which worked before, but now after extending the class, I am finding all these problems.
Is this documented something that local proc()'s inside method do not work as expected when extending classes in Maple OOP? It means now I have to move these local proc() to the outside of its current enclosing proc() to make Maple happy.  I just do not understand why this limitation.
Maple 2023.1 on Windows 10
Hi Users!
I hope everyone is fine here. I have plotted the density plot below:
restart; Digits := 20; with(LinearAlgebra); with(plots); N := 20; Mx := 20; L := 1; `&Delta;x` := L/Mx; T := 2; `&Delta;t` := T/N; for i from 0 while i <= Mx do u[i, 0] := 0 end do; for n from 0 while n <= N do u[0, n] := 0; u[Mx, n] := 0 end do; for n from 0 while n <= N-1 do for i while i <= Mx-1 do Ru[i, n] := eval((u[i, n+1]-u[i, n])/`&Delta;t` = (u[i+1, n+1]-2*u[i, n+1]+u[i-1, n+1])/`&Delta;x`^2-u[i, n+1]+.5) end do; Sol[n] := fsolve({seq(Ru[i, n], i = 1 .. Mx-1)}); assign(op(Sol[n])) end do;
Digits := 10; NP := 100; XX := [seq(seq(i1/Mx, i1 = 0 .. Mx), i2 = 0 .. N)]; TT := [seq(seq(i2, i1 = 0 .. Mx), i2 = 0 .. N)]; ZZ := [seq(seq(u[i1, i2], i2 = 0 .. N), i1 = 0 .. Mx)]; interfunc := subs(__M = Matrix(Matrix(Mx+1, N+1, ZZ), datatype = float[8]), proc (x, y) options operator, arrow; CurveFitting:-ArrayInterpolation([[`$`(i1, i1 = 0 .. Mx)], [`$`(i2, i2 = 0 .. N)]], __M, [[x], [y]], method = cubic)[1, 1] end proc); newz := CurveFitting:-ArrayInterpolation([[`$`(i1, i1 = 0 .. Mx)], [`$`(i2, i2 = 0 .. N)]], Matrix(Mx+1, N+1, ZZ, datatype = float[8]), [[seq(Mx*(i3-1)/(NP-1), i3 = 1 .. NP)], [seq(N*(i3-1)/(NP-1), i3 = 1 .. NP)]], method = cubic); nminz, nmaxz := (min, max)(newz); C := .666*(1-ImageTools:-FitIntensity(newz)); PC := PLOT(GRID(0 .. Mx, 0 .. N, newz, COLOR(HUE, C)), STYLE(PATCHNOGRID)); numcontours := 15; PP := (proc (P) options operator, arrow; (op(0, P))(op(P), ROOT(BOUNDS_X(0), BOUNDS_Y(0), BOUNDS_WIDTH(600), BOUNDS_HEIGHT(500))) end proc)(plots:-display(PC, plots:-contourplot(interfunc, 0 .. Mx, 0 .. N, thickness = 0, contours = [seq(nminz+(nmaxz-nminz)*(i3-1)/(numcontours+2-1), i3 = 1 .. numcontours+2)]), seq(plot(ZZ[1], nminz .. nminz, thickness = 15, color = COLOR(HUE, .666*(1-i3/(numcontours+1))), legend = sprintf(" %.3f", nminz+i3*(nmaxz-nminz)/(numcontours+1))), i3 = numcontours+1 .. 0, -1), legendstyle = [location = right, font = [Helvetica, 14]], font = [Helvetica, 16], labelfont = [Helvetica, bold, 16], labels = [x, t], labeldirections = [horizontal, vertical]));
plots[display](PP, size = [500, 400]);
Here the t-axis is from 0 to 20 but its actual value is from 0 to 2 and the x-axis is from 0 to 20 but its actual value is from 0 to 2. How can I change the axis? Moreover, I used the following way to extract the data in a dat file to plot the function (say f) in some professional software.
with(plots); f := plot(sin(x), x = -Pi .. Pi); dat1 := `~`[plottools:-getdata]([f]); for i while i <= 1 do A[i] := dat1[i, 3]; Y[i] := A[i][1 .. -1, 2] end do; X := A[1][1 .. -1, 1]; MM1 := `<|>`(X, `$`(Y[j2], j2 = 1 .. 1)); ExportMatrix("C:/Users/Usman/Desktop//Graph f.dat", MM1);
How I can, I extract data in the form of a dat file to plot in some professional software?
integral of sqrt(sin(x)) is known to be as given in few place such as in here and other places.
Maple gives a result which is much more complicated (but also in terms of EllipticE special function).
Could someone find a way to simplify it to the above answer and also to the same answer given by Mathematica?
int(sqrt(sin(x)),x)
Compare to
Maple's result seems to be correct, as I plotted it and compared the smaller known resut. But I was not able to simplify it to obtain the smaller antiderivative.
Any tricks to do that?
Maple 2023.1 will not let me overload a method for an object when using _self.  Is there a way around this?
module person()
   option object;
   local the_name::string:="*",the_age;
   export set_info::static:= overload(
      proc(_self,the_name::string,$) option overload;
          _self:-the_name:=the_name;
      end proc,
      proc(_self,the_name::string,the_age::integer, $) option overload;
          _self:-the_age:=the_age;
      end proc
   export get_name::static:=proc(_self,$)
      RETURN(_self:-the_name);
end module;
And now when I do
o:=Object(person);
o:-set_info("me");
o:-set_info("me",20)
Error, (in person:-set_info) `me` does not evaluate to a module
Error, invalid input: no implementation of person:-set_info
matches the arguments in call, 'person:-set_info("me",20)'
The problem goes away by removing `_self` as first argument in signature of the overloaded method. But then I will not be able to use _self any more inside the methods.
There is no problem overloading the method when using normal module, or one that does not use _self. For example this works
module person()
   export set_info:= overload(
      proc(the_name::string,$) option overload;
          print(the_name);
      end proc,
      proc(the_name::string,the_age::integer, $) option overload;
          print(the_name);
          print(the_age);
      end proc
end module;
person:-set_info("me");
How to make the first example above work? I need to overload a method inside an module with option object that uses _self
update
I found a workaround. But it is not good, but for now. For the overloaded method, instead of using
           o:-set_info("me");
This works instead
         set_info(o,"me");
So the following now works
o:=Object(person);
#o:-set_info("me");   #do not use with overloaded
#o:-set_info("me",20); #do not use with overloaded
set_info(o,"me");  #now works OK with no error
set_info(o,"me",20); #now works OK with no error
o:-get_name();  #OK since this method  is not overloaded
o:-get_age();  #OK since this method  is not overloaded
I do not understand why _self can't be used with overloaded methods and if this a bug or by design.
Maple 2023.1 on windows 10
67588
module person()
   option object;
           #print("Inside first overloaded set_info");
      end proc,
          #print("Inside second overloaded set_info");
      end proc
   export get_age::static:=proc(_self,$)
      RETURN(_self:-the_age);
end module;
module person () local the_name::string, the_age; option object; end module
o:=Object(person);
#o:-set_info("me");
set_info(o,"me"):
set_info(o,"me",20):
o:-get_name();
o:-get_age();
"me"
20
Download self_with_overloaded.mw
In short, I'd like to obtain n largest/smallest elements in a huge list of (probably non-numeric) data. Of cource I can sort it and then extract the desired part, yet isn't there a dedicated procedure that do a partial sort of the input data in Maple?
Edit. In a MatLab weblog, the blogger gave:
So I believe that a dedicated one is not useless. But what is the Maple equivalent to MatLab's maxk, mink, and topkrows?
If if solve for two circles intersecting the general solution conteint a factor of (xc1-xc2) i.e. x co-ors of the circle centres in both numerator and denominator. So the solution fails if they are equal i.e circles vertically aligned.
I can get arount the problem using  "RealDomain" but that introduces Signum which I dont like and is much slower to solve. I substitued out substitued signum out signum(xc1-xc2)=1. Works.
Just looking for is neater solution approach.
eq1 := (x-xc1)^2+(y-yc1)^2 = R1^2
eq2 := (x-xc2)^2+(y-yc2)^2 = R2^2
eq3 := (xc1-xc2)^2-(yc1-yc2)^2 < (R1+R2)^2
Sol1 := `~`[simplify](solve({eq1, eq2}, [x, y], explicit))[]
[x = (1/2)*((-yc1+yc2)*(-(xc1-xc2)^2*(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)-(xc1-xc2)*(-xc1^3+xc1^2*xc2+(R1^2-R2^2+xc2^2-yc1^2+2*yc1*yc2-yc2^2)*xc1-xc2*(R1^2-R2^2+xc2^2+yc1^2-2*yc1*yc2+yc2^2)))/((xc1^2-2*xc1*xc2+xc2^2+(yc1-yc2)^2)*(xc1-xc2)), y = ((-(xc1-xc2)^2*(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+yc1^3-yc1^2*yc2+(-R1^2+R2^2+xc1^2-2*xc1*xc2+xc2^2-yc2^2)*yc1+yc2^3+(R1^2-R2^2+xc1^2-2*xc1*xc2+xc2^2)*yc2)/(2*yc1^2-4*yc1*yc2+2*yc2^2+2*(xc1-xc2)^2)], [x = (1/2)*((yc1-yc2)*(-(xc1-xc2)^2*(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)-(xc1-xc2)*(-xc1^3+xc1^2*xc2+(R1^2-R2^2+xc2^2-yc1^2+2*yc1*yc2-yc2^2)*xc1-xc2*(R1^2-R2^2+xc2^2+yc1^2-2*yc1*yc2+yc2^2)))/((xc1^2-2*xc1*xc2+xc2^2+(yc1-yc2)^2)*(xc1-xc2)), y = (-(-(xc1-xc2)^2*(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+yc1^3-yc1^2*yc2+(-R1^2+R2^2+xc1^2-2*xc1*xc2+xc2^2-yc2^2)*yc1+yc2^3+(R1^2-R2^2+xc1^2-2*xc1*xc2+xc2^2)*yc2)/(2*yc1^2-4*yc1*yc2+2*yc2^2+2*(xc1-xc2)^2)]
eval(Sol1[1], [R1 = 85, R2 = 30, xc2 = 200, yc2 = 144.85, xc1 = 130, yc1 = 95.7071])
[x = 178.3493912, y = 165.6165872]
eval(Sol1[2], [R1 = 85, R2 = 30, xc2 = 200, yc2 = 144.85, xc1 = 130, yc1 = 95.7071])
[x = 212.1767210, y = 117.4323513]
Sol2 := `assuming`([`~`[simplify](solve({eq1, eq2}, [x, y], explicit))[]], [eq3])
with(RealDomain)
Sol3 := `~`[simplify](solve({eq1, eq2}, [x, y], explicit))[]
[x = (-(yc1-yc2)*signum(xc1-xc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+xc1^3-xc1^2*xc2+(-R1^2+R2^2-xc2^2+yc1^2-2*yc1*yc2+yc2^2)*xc1+xc2*(R1^2-R2^2+xc2^2+yc1^2-2*yc1*yc2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2), y = (signum(xc1-xc2)*(xc1-xc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+(yc1+yc2)*xc1^2-2*xc2*(yc1+yc2)*xc1+(yc1+yc2)*xc2^2-(yc1-yc2)*(R1^2-R2^2-yc1^2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2)], [x = ((yc1-yc2)*signum(xc1-xc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+xc1^3-xc1^2*xc2+(-R1^2+R2^2-xc2^2+yc1^2-2*yc1*yc2+yc2^2)*xc1+xc2*(R1^2-R2^2+xc2^2+yc1^2-2*yc1*yc2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2), y = (-signum(xc1-xc2)*(xc1-xc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+(yc1+yc2)*xc1^2-2*xc2*(yc1+yc2)*xc1+(yc1+yc2)*xc2^2-(yc1-yc2)*(R1^2-R2^2-yc1^2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2)]
eval(Sol3[1], [R1 = 85, R2 = 30, xc2 = 200, yc2 = 144.85, xc1 = 130, yc1 = 95.7071])
[x = 178.3493912, y = 165.6165871]
eval(Sol3[2], [R1 = 85, R2 = 30, xc2 = 200, yc2 = 144.85, xc1 = 130, yc1 = 95.7071])
[x = 212.1767209, y = 117.4323512]
Sol3a := subs(signum(xc1-xc2) = 1, Sol3[1])
[x = (-(yc1-yc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+xc1^3-xc1^2*xc2+(-R1^2+R2^2-xc2^2+yc1^2-2*yc1*yc2+yc2^2)*xc1+xc2*(R1^2-R2^2+xc2^2+yc1^2-2*yc1*yc2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2), y = ((xc1-xc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+(yc1+yc2)*xc1^2-2*xc2*(yc1+yc2)*xc1+(yc1+yc2)*xc2^2-(yc1-yc2)*(R1^2-R2^2-yc1^2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2)]
Sol3b := subs(signum(xc1-xc2) = 1, Sol3[2])
[x = ((yc1-yc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+xc1^3-xc1^2*xc2+(-R1^2+R2^2-xc2^2+yc1^2-2*yc1*yc2+yc2^2)*xc1+xc2*(R1^2-R2^2+xc2^2+yc1^2-2*yc1*yc2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2), y = (-(xc1-xc2)*(-(-xc1^2+2*xc1*xc2-xc2^2+(R1-R2+yc1-yc2)*(R1-R2-yc1+yc2))*(-xc1^2+2*xc1*xc2-xc2^2+(R1+R2+yc1-yc2)*(R1+R2-yc1+yc2)))^(1/2)+(yc1+yc2)*xc1^2-2*xc2*(yc1+yc2)*xc1+(yc1+yc2)*xc2^2-(yc1-yc2)*(R1^2-R2^2-yc1^2+yc2^2))/(2*xc1^2-4*xc1*xc2+2*xc2^2+2*(yc1-yc2)^2)]
eval(Sol3a, [R1 = 85, R2 = 30, xc2 = 200, yc2 = 144.85, xc1 = 130, yc1 = 95.7071])
eval(Sol3b, [R1 = 85, R2 = 30, xc2 = 200, yc2 = 144.85, xc1 = 130, yc1 = 95.7071])
(14)
Download 28-10-28_Q_Circles_Intersect.mw
It seems like my maple document has been corrupted. When I tri to open the document I'm met with an error message "There were problems during the loading process. Your worksheet may be incomplete."
I have spent a great amount of time in this document, so if there was a way to recover it, that would be fantastic.
Download prac_exam_ece4179.mw
Why, when I run the integral command, it only prints the integral instead of solving it?
First 188 189 190 191 192 193 194 Last Page 190 of 2457
