I am attempting to use the pdsolve function in Maple to explicitly solve a PDE which is basically a perturbation of the Laplace equation.  Nothing happens when I enter pdsolve, however, is this because a boundary condition is also needed to produce a solution?  The BC which I have is that f(x, y, z) goes to zero as sqrt(x^2 + y^2 + z^2) goes to infinity but I am not sure how to enter such a BC in Maple.
PDE := diff(diff(f(x, y, z), x), x) + diff(diff(f(x, y, z), y), y) + diff(diff(f(x, y, z), z), z) - exp(-t*exp(sqrt(x^2 + y^2 + z^2)))*(diff(diff(f(x, y, z), x), x) + diff(diff(f(x, y, z), y), y) + diff(diff(f(x, y, z), z), z))/(1 + m/(2*sqrt(x^2 + y^2 + z^2)))^4 = 3/2*exp(sqrt(x^2 + y^2 + z^2) - t*exp(sqrt(x^2 + y^2 + z^2)))*(diff(f(x, y, z), x)*tx/sqrt(x^2 + y^2 + z^2) + diff(f(x, y, z), y)*ty/sqrt(x^2 + y^2 + z^2) + diff(f(x, y, z), z)*tz/sqrt(x^2 + y^2 + z^2))/(1 + m/(2*sqrt(x^2 + y^2 + z^2)))^4;
pdsolve(PDE);
Good day everyone,
I am running a maple code for a pde and is given the error code "Error, (in pdsolve/numeric/process_IBCs) initial/boundary condition must be given in terms of the dependent variables of the problem only ([W]), got ((D@@2)[1](W))(0, tau) = 0". The link is attached below.
pde.mw
Clifford http://math.tntech.edu/rafal/cliff12/index.html
I read really good reviews from fellow Maple users about Clifford Package( above link).
I couldn't access the link provided. What is the best way to install Clifford Package or get access to the link.
Thank You.
Hey everyone!
I have a complex function stored in a file (Comp-func.txt). The function is continues everywhere on the real axis (X-axis.txt). However, its log shows a jump somewhere close to x=-1.5. I would like to understand how Maple interprets this "jump" and how to avoid such numerical artifact.
thank you.
 Comp-func.txt
Jump-Log-Func.mw
X-axis.txt
Can I compute using maple some Riemann Stieltjes integrals
RSI.mw
This also looks like an applyrule bug.
kernelopts(version);
`Maple 2021.2, X86 64 LINUX, Nov 23 2021, Build ID 1576349`
double_angle_rule := [
        sin(x::name/2)*cos(x::name/2) = 1/2*sin(x),
        sin(x::name/2)^2 = 1/2*(1-cos(x)),
        cos(x::name/2)^2 = 1/2*(1+cos(x))
[sin((1/2)*x::name)*cos((1/2)*x::name) = (1/2)*sin(x), sin((1/2)*x::name)^2 = 1/2-(1/2)*cos(x), cos((1/2)*x::name)^2 = 1/2+(1/2)*cos(x)]
C := < cos(1/2*u)*sin(1/2*u), cos(1/2*u)^2 >;
Vector(2, {(1) = cos((1/2)*u)*sin((1/2)*u), (2) = cos((1/2)*u)^2})
This application fails. Why?
applyrule~(double_angle_rule, C);
Error, dimension bounds must be the same for all container objects in an elementwise operation
Download applyrule-bug2.mw
This looks like a bug to me but please correct me if it is not.
half_angle_rule := [
        sin(x::name) = 2*sin(x/2)*cos(x/2),
        cos(x::name) = 1 - 2*sin(x/2)^2
[sin(x::name) = 2*sin((1/2)*x)*cos((1/2)*x), cos(x::name) = 1-2*sin((1/2)*x)^2]
In this example, Maple applies the rule to the first element only.
It should apply to both.
A := < sin(u), sin(u) >;
applyrule~(half_angle_rule, A);
Vector(2, {(1) = sin(u), (2) = sin(u)})
Vector[column](%id = 36893628627946684772)
In this example, Maple applies the rule to the second element only.
B := < cos(u), cos(u) >;
applyrule~(half_angle_rule, B);
Vector(2, {(1) = cos(u), (2) = cos(u)})
Vector[column](%id = 36893628627946688132)
Download applyrule-bug1.mw
How to trace the 2 parabolas that pass through 4 cocyclical points. Thank you
Hello all. I'm using version 2021.2 to try to make some simple energy plots for my research. The math is pretty straightforward, but for some reason I cannot get the results to plot properly. My code is below:
A := 7.17;
B := 2.56*10^(-3);
C := 0.08*10^5;
_local(D);
1;
D := 0*10^(-6);
                           A := 7.17
                      B := 0.002560000000
                          C := 8000.00
                             D := 0
T_0 := 298;
G0 := -71.398;
S0 := 45.106;
Hf := -57.95;
cp := A + B*T + C/T^2 + D(T)^2;
`&Delta;H` := int(cp, T = T_0 .. T);
`&Delta;S` := int(cp/T, T = T_0 .. T);
G := -S0*T - T*`&Delta;S` + Hf + `&Delta;H`;
plot(G, T = T_0 .. T_max);
Which yields the following error message:
"Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct"
I've looked through everything I can find on this issue, and I'm coming up empty. Anyone know what's happening here?
Dear colleagues.
I use gradplot for a displacement vector in x-direction only, as foolows
gradplot(u1(x), x = 0 .. a, y = 0 .. b, grid = [10, 10], arrows = SLIM, color = u1(x), T, caption = typeset("The displacement field"), fieldstrength = fixed, size = [0.3, 0.5])
I need to make color legend to show the minimum and maximum value and in between for the displacement.
Amr
I need to use convert of complex exponentials to trig, but only to convert exp(I*x) to cos/sin using Euler formula.
The problem is that, since this is done in code without looking at what is inside the exp(), Maple will also convert non complex exponentials as exp(x) to hyperpolic trig which I do not want.  An example will make this clear
For an example, given exp(3*I*x - x)  and applying convert/trig to this it gives
             (cosh(x) - sinh(x))*(cos(3*x) + sin(3*x)*I)                       --(1)
But I only want to conver the exp(3*I*x) part of the of the above to obtain
          exp(-x) *  (cos(3*x) + sin(3*x)*I)                          ---(2)
I can break  exp(3*I*x - x) first using expand command and obtain  exp(-x) exp(3*I*x) and then parse this and filter out the complex exponentials (may be using select with has I) and then use convert on those terms only leaving the non-complex exponentials alone. But this gets messy for more complex exponentials.
Is there an easy way to tell Maple  to convert expression of the form exp(I*f(x) + g(x)) to trig but only to sin/cos, hence leaving the exp( g(x) ) as a factor? I looked at help but see nothing there so far.
Maple 2021.2
I try to know an equation of the tangent on the point [0.504244923, 0.3781836925] on the hyperbola7*x^2 - 7*y^2 - 12.0*x + 9.0*y + 2.25 - 2*x*y=0.How can I do that? Thank you.
I see that one of the parameters of the  function Graph accepts a Array of neighbors.
So I gave it a try.
G := GraphTheory:-Graph([1,2],[[2],[1]])
G := `Graph 10: an undirected unweighted graph with 2 vertices and 1 edge(s)`
It looks pretty good. But there's something wrong with the following codes.
G := GraphTheory:-Graph([0,1],[[1],[0]])
Error, (in GraphTheory:-Graph) invalid vertex 0 in list of neighbors
G := GraphTheory:-Graph(["0","1"],[["1"],["0"]])
Error, (in GraphTheory:-Graph) cannot determine if this expression is true or false: 1" < 1 or 2 < "1
G := GraphTheory:-Graph(["a","b"],[["b"],["a"]])
Error, (in GraphTheory:-Graph) cannot determine if this expression is true or false: b" < 1 or 2 < "b
How to use  Array of neighbors in  Graph  correctly?
PS: The source of the problem is that I got the following list of adjacencies of a graph  in Python and I want to convert it to  a graph in Maple. Its vertices are [0,1,2, ..., 9].
[[1, 2, 3, 4, 5, 6], [0, 2, 3, 4, 7, 8],
 [0, 1, 3, 5, 7, 9], [0, 1, 2, 6, 8, 9],
 [0, 1, 5, 6, 7, 8], [0, 2, 4, 6, 7, 9],
[0, 3, 4, 5, 8, 9], [1, 2, 4, 5, 8, 9],
[1, 3, 4, 6, 7, 9], [2, 3, 5, 6, 7, 8]]
G := GraphTheory:-Graph([$0..9],[[1, 2, 3, 4, 5, 6],
[0, 2, 3, 4, 7, 8], [0, 1, 3, 5, 7, 9],
 [0, 1, 2, 6, 8, 9], [0, 1, 5, 6, 7, 8],
 [0, 2, 4, 6, 7, 9], [0, 3, 4, 5, 8, 9],
 [1, 2, 4, 5, 8, 9], [1, 3, 4, 6, 7, 9],
[2, 3, 5, 6, 7, 8]])
L=100 H, R=20 ohm, C=1/401 F, DC=200 V and Impulse =2000 V. q(0)=0 and Q'(0)=2000/L.
Maple new user can't show the ODE function. I just use the toolber menu.
Tokoro.
with(inttrans):
U__0:=20:
U := t -> U__0*exp(-1/10*t)*cos(2*t):
plot(U(t), t = 0 .. 2*Pi,
     axis[2] = [tickmarks = [0 = 0, 20 = U__0]],
     labels = [t, 'U(t)'], size=[500,300]);
laplace(U(t), t, s)
200*(10*s+1)/((10*s+1)^2+400)
simplify(200*(10*s+1)/((10*s+1)^2+400))
(2000*s+200)/(100*s^2+20*s+401)
expand((2000*s+200)/(100*s^2+20*s+401))
2000*s/(100*s^2+20*s+401)+200/(100*s^2+20*s+401)
"Y(s):=((20)/(s)*100*s)/(100 s+20+401/(s))+(200/(s))/(100 s+20+401/(s))"
proc (s) options operator, arrow, function_assign; 2000/(100*s+20+401/s)+200/(s*(100*s+20+401/s)) end proc
" y(t):=invlaplace(Y(s),s,t):"
plot(y(t), t = 0 .. 2*Pi, axis[2] = [tickmarks = [0 = 0, 20 = U__0]], labels = [t, 'U(t)'], size = [500, 300])
Parse:-ConvertTo1D, "first argument to _Inert_ASSIGN must be assignable"
Error, illegal use of an object as a name
"L:=100:R:=20:C:=1/401:E:=200:L*i(0):=2000:q(0):=0:"
dsolve[interactive]()
Error, invalid function arguments
"diff(,t)"
plot([diff(q(t), t), 20*exp(-(1/10)*t)*cos(2*t)], t = 0 .. 2*Pi)
Warning, expecting only range variable t in expression diff(q(t),t) to be plotted but found name q
plot([q(t), (4000/401)*exp(-(1/10)*t)*sin(2*t)-(200/401)*exp(-(1/10)*t)*cos(2*t)+200/401], t = 0 .. 2*Pi)
Warning, expecting only range variable t in expression q(t) to be plotted but found name q
I am trying to perform a numerical integration of a matrix using parallel computing. I have found two packages to do that:
1. With Threads package
A:=Matrix([x,x^2],[2*x,sin(x)]);
Threads[Map](int,A,x=0..2,numeric=true);
This code does not parallelize at my Ryzen 5 processor and is using exactly 1 logical core during computation. The matrix is just an example, real matrices are much bigger.
kernelopts(multithreaded) returns true
kernelopts(numcpus) returns 6 when SMT is off and 12 when SMT is on (pretty weird though, it should always return 6)
2. With Grid package
This leads to numerous messages:
"Error, attempting to assign to `int` which is protected.  Try declaring `local int`; see ?protect for details."
Meanwhile, the rezult seems OK and all cores are working to produce it.
What am I doing wrong?
First 370 371 372 373 374 375 376 Last Page 372 of 2458
