Version: Maple 2020.1
When i set the color for the gridlines it only seems to be applied for the major-tick gridlines as the following trivial example shows:
plot(sin(t), t = 0 .. Pi, axes = frame, background = "#303030", color = "Orange", axis = [gridlines = [color = "#707070", linestyle = dot]])
I assume it must also be possible to also specify the color for the minor tick-marks gridlines?
The obvious (?) variant "axis=[gridlines = [color = ["#707070", "#707070"] , ... " just seems to crash maple (nothing happens when the plot() expression is evaluated).
I'm unable to find anything in the documentation regarding this and it only seems to imply that the color should be applied to both major & minor gridlines which is not the case.
Hi everyone! Currently I'm studying magnetism, and I was thinking that maybe seeing represented the helix movement of an atom with a vector v parallel to the Magnetic Field B subject to the Force of Lorentz and the Hysteresis cycle created in the magnetazation of a ferromagnetic material could help me understand it more. I tried to create the plots in Maple 2015 but I couldn't.. anyone can help me by creating those two plots?
I notice that when I enter ?convert or ?convertininto the maple prompt, the help window opens once and then ceases to function.
Update. It seems that the problem is not restricted to a specific command, this occurs for any command. To replicate, open help using F1, exit maple help, then open help again using F1. Maple help won't open again. I have to do a hard exit to get it to work again.
Platform details:
Recently I switched from Mathematica to Maple. I have the following code
solve({pf'(e)- psi'(e) - tau - mu*pi(tau)/(1 - pi(tau)) = 0}, {tau}) assuming 0 < p, 0 < tau, 0 < mu, 0 <= pi< 1
and I am getting a result of
RootOf(-D(pf)(e)*pi(_Z) - mu*pi(_Z) + _Z*pi(_Z) + 2*pi(_Z) + D(pf)(e) - _Z - 2)
I have to questions: (a) what does that _Z means? (b) is it possible to express the above solution in a more "readable" way?
/Mrs.,
How can I plot "log scale base 2" instead of "log scale base 10" (plot "log2plot(x,x=0..10)" instead of "logplot(x,x=0..10)")?
I would appreciate if you make me some help with this situation.
faithfully,
I am trying to apply assumptions to the solution set of an equation. I've tried assume and assuming (see attached) to no avail. What am I missing? How can I achieve this?assume.mw
`assuming`([solve(x^2-x-2 = 0, x)], [x > 0])
2, -1
assume(x > 0)
2, -1
Download assume.mw
I am generating splines using CurveFitting[Spline] command, which produces piecewise functions. I would like to extract the different "pieces" of the spline for use elsewhere. How do I do that? In the attached worksheet, for example, I would like to extract (59*x^2)/756, -1/84*x^2 + 17/63*x - 17/84, and -19/504*x^2 + 19/36*x - 61/72. There has to be a way to do this, but I'm coming up short.
spline.mw
with(CurveFitting)
f := Spline([[0, 0], [3, 1/2], [7, 1]], x, degree = 2)
piecewise(x < 3/2, (59/756)*x^2, x < 5, -(1/84)*x^2+(17/63)*x-17/84, -(19/504)*x^2+(19/36)*x-61/72)
Download spline.mw
I want to plot some oscillating function (function involve sin and cos) as a function to time (t). And when I try a large interval like t=0..1000, it is going to take forever to plot the graph and the system becomes a little laggy. Is there any way I can do to make it compute quickly?
Thank you all
11111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
I am trying to use Threads in my procedures as much as possible.  However, one of them returned different results when compared to map or Grid:-Map (I have checked if the used functions are threadsafe (perhaps I miss something)).  Here is the procedure (optimization of the code is most welcome).
searchMonomialsEqns:=proc(conds::set,Eqns::list,Vars::list,poolofeqns::list(list))
description "Find if a set of monomials in an equation can be found in a pool of monomials and returns the condition when it is true":
local A:=Array(1..0),
      C,
      i,
      res,
      n:=numelems(Eqns):
#  Find the monomials of Eqns
res:=subs(conds,Eqns):
for i from 1 to n do
    C:= coeffs(expand(lhs(res[i])-rhs(res[i])),Vars, 'M'):
    A,={M}:
ifelse(member([seq(A)],poolofeqns)=false,NULL,conds):
1) Threads:-Map
ans1:=CodeTools:-Usage(Threads:-Map(w->searchMonomialsEqns(w,eqns[1..2],vars[2..3],validYZeqnMon),conds5)):nops(ans1);
returns
memory used=0.58GiB, alloc change=139.56MiB, cpu time=40.23s, real time=11.12s, gc time=1.01s
                              8613
2) map
ans2:=CodeTools:-Usage(map(w->searchMonomialsEqns(w,eqns[1..2],vars[2..3],validYZeqnMon),conds5)):nops(ans2);
returns
memory used=0.57GiB, alloc change=-4.00MiB, cpu time=22.48s, real time=21.55s, gc time=1.70s
                              8637
3) Grid:-Map
ans3:=CodeTools:-Usage(Grid:-Map(w->searchMonomialsEqns(w,eqns[1..2],vars[2..3],validYZeqnMon),conds5)):nops(ans3);
return
memory used=23.29MiB, alloc change=21.88MiB, cpu time=3.77s, real time=2.25s, gc time=3.14s
                              8637
Although the number of elements is the same, Grid:-Map returns the result with set function mentioned in my previous post. (I am aware that CodeTools:-Usage is pointless here).
4) Threads:-Seq
ans4:=CodeTools:-Usage([Threads:-Seq](searchMonomialsEqns(conds5[i],eqns[1..2],vars[2..3],validYZeqnMon),i=1..nops(conds5))):nops(ans4);
returns
memory used=0.58GiB, alloc change=0 bytes, cpu time=33.99s, real time=8.68s, gc time=644.74ms
                              8622
What am I missing?
Many thanks
Ed
"What's new in Maple 2020" explain an exciting new option for DrawGraph: layout=interactive, that should allow you to move vertices in the plot. I tried this in the help page opened in a worksheet window and it works.
Unfortunately when I write in a new worksheet the command
with(GraphTheory): with(RandomGraph): G:=RandomGraph(10,25); DrawGraph(G,layout=interactive)
I get the error
"Error, invalid input: GraphTheory:-DrawGraph expects value for keyword parameter [style, layout] to be of type identical(none, bipartite, circle, default, fixed, grid, interactive, network, spectral, spring, spring[constant], tree, user, planar, random), but received plots:-interactive"
Could you help me? Thanks
This is really a math question. But I can't figure how Maple did it.
Maple solves the ODE with 2 initial conditions correctly.
But if I use the general solution, and setup the set 2 equations, and tell Maple to solve _C1 and _C2, it says there is no solutions. Which is correct.
I would really like to know how Maple then managed to solve for these initial conditions.  This is problem from text book
I know how to solve it by hand to obtain general solution. But do not know how find solution that satisfies the IC's. when pluggin the initial conditions, the resulting 2 equation have no solution.
ode:=2*diff(y(x),x$2)=exp(y(x));
maple_general_sol:=dsolve(ode);
odetest(maple_general_sol,ode);
IC:=y(0)=0,D(y)(0)=1;
maple_sol_with_IC:=dsolve([ode,IC]);
odetest(maple_sol_with_IC,[ode,IC]);
The goal is to now take the general solution found by Maple above, and manually solve for _C1 and _C2:
eq1:=0=subs(x=0,rhs(maple_general_sol));
the_derivative:= diff(rhs(maple_general_sol),x):
eq2:=1=subs(x=0,the_derivative);
Two equations, two unknown. But using solve or PDEtools:-Solve produce no solution.
sol1:=solve([eq1,eq2],[_C1,_C2]);
sol2:=PDEtools:-Solve([eq1,eq2],[_C1,_C2]);
Looking at equation (1) above, we see that it is the same as
eq1:=1=(tan(_C2/(2*_C1))^2 + 1)/_C1^2;
Because 0=ln(Z) means Z=1. Using the above simpler equation now gives
We see that there is indeed no solution. Second equation above says _C1= tan(.). Let tan(.)=Z. Plugging this in first equation gives Z^2= (Z^1+1) which has no solution for Z since this says 0=1
So direct appliction of the initial conditions produces no solution. So how did Maple find the solution it obtained? I also tried using limits. But no luck. Book does not show how to obtain solution either.
Any ideas?
When solving this by hand   sqrt(y)=tanh(x), I would square both sides to obtain  y=tanh(x)^2 as solution.
Maple does this when RHS is tan,cos,sin, but not when RHS is hyperbolic.
Why is that, and how to best tell Maple to give  the simple solution? Here is an example
eq:=sqrt(y)=tanh(x);
sol:=solve(eq,y);
Compare to Mathematica:
I can post-process Maple solution like this
sol:=solve(eq,y);
sol:=convert(sol,trigh);
sol:=simplify(sol)
Which is tanh(x)^2.
But this is all too much work, since this is done in a program, and I do not know what specific convert to use at the time to try.
My question is, why does not maple simply solves   sqrt(y) = f(x)  giving     y=f(x)^2?  it works for generic function
eq:=sqrt(y)=f(x);
sol:=solve(eq,y);
it works for non-hyper trig functions also
eq:=sqrt(y)=tan(x);
sol:=solve(eq,y);
Is there a trick to make it work for hyperbolic functions also automatically?
ps. for now, to avoid all these issues, I am doing this
the_rhs:=tanh(x);
eq:=sqrt(y)=f;
sol:=solve(eq,y);
sol:=subs(f=the_rhs,sol);
Since I know that the RHS contains no y before hand. The above bypasses any issues Maple has with hyper trig functions.
Without any success, I've been trying to hide the input/code, such that only the output (moment and shear) diagram is shown. I've tried guides with Document Blocks method but all seem outdated, since they're referring to commands which don't seem to exist i.e. "collapse document block". I can't understand that there isn't some neat and user-friendly way to something as simple as show/hide the input, to make it more document-reader friendly? It seems the only way is to just hightlight the input and color it white, which isn't too viable long term.
I hope you can help, it would be alot of help to me and my classmates.
Kind regards and thanks for your time.
PS. Here's a picture of the input and diagram.
First 514 515 516 517 518 519 520 Last Page 516 of 2458
