I posted this earlier on a question I asked more than a month ago due to the similarity of the problem.  However, I got no response.  So I will post this as a new question in an effort to get a response.
I get the following error when working with the "INERT" Sum?
I do not get the message when working with the "ACTIVE" sum.  I tried the AllSolutions option, but still get the same message.  How can I get the proper output working with the "INERT" form?
lost_solutions.mw
Hello Forum,
I have a quick question i was hoping someone could help me with.
Is there a way to put a line though "math" text like below
+8 = +8
to visualize that to values cancels each other out?
I hope someone can help, i can´t find anything on google
IllIN -
hello my friends
I have a critical problem to solve below the system of differential equations
-(9/14)*R(t)^(19/14)-(285/196)*(diff(R(t), t, t))/R(t)^(9/14)+(2565/2744)*(diff(R(t), t))^2/R(t)^(23/14) = -k*(4*lambda+1/a(t)^3)
and R(t) = 6*((diff(a(t), t))^2/a(t)^2+(diff(a(t), `$`(t, 2)))/a(t))
I need to find form of a(t) numerically from set of differential equatios
plz help me as soon as possible
I just want to get 3 digits after the comma. I wrote something random, but I could not find the right one.What exactly do I have to write when I click on the custom?
Dear reader,
My questions about Multivariate Statistics are all programmed the hard way. When using R in the classroom, which has all the commands available this looks a little awkward. Thing is that every command should give a specific answer which can be related to a question box.
A little help would be nice. I am more than happy to share questions
$e=maple("Vector([1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1])");
$n=maple("evalf(Statistics[Count]($e))");
$k=2;
:// data input;
:// dependent variable Y;
$Y=maple("[11.259,11.238,11.492,11.479,11.016,11.241,10.949,10.690,10.964,10.733,10.493,10.684,10.459,10.595,10.953,10.838,10.545,10.806,10.455,10.299,10.608,10.605,10.536,10.492]");
$vY=maple("Vector([$Y])");
$nY=maple("evalf(Statistics[Count]($Y))");
$muY=maple("evalf(Statistics[Mean]($Y))");
$sumY=maple("add($Y)");
:// independent variable X1;
$X1=maple("[7.5,7.5,6.5,7,8,7.5,7.5,8,8.5,8,8,8.5,8,8,8,8,8,8,8.5,8.5,8.5,8,8,8]");
$vX1=maple("Vector([$X1])");
$nX1=maple("evalf(Statistics[Count]($X1))");
$muX1=maple("evalf(Statistics[Mean]($X1))");
$sumX1=maple("add($X1)");
:// independent variable X2;
$X2=maple("[22,22,20,22.5,21.5,22,21.5,21,21.5,21,20.35,21,20.35,20.75,21.5,21.35,20.75,21.1,20.35,20,20.75,20.75,20.75,20.35]");
$vX2=maple("Vector([$X2])");
$nX2=maple("evalf(Statistics[Count]($X2))");
$muX2=maple("evalf(Statistics[Mean]($X2))");
$stdvX2=maple("evalf(Statistics[StandardDeviation]($X2))");
$sumX2=maple("add($X2)");
:// independent variable X3;
$X3=maple("[8.01,9.1,8.39,8.37,8.73,9.11,7.52,7.17,7.54,7.24,6.79,7.09,3.6,6.95,7.52,7.34,5.82,7.29,5.68,5.45,6.97,8.03,5.8,4.69]");
$vX3=maple("Vector([$X3])");
$nX3=maple("evalf(Statistics[Count]($X3))");
$muX3=maple("evalf(Statistics[Mean]($X3))");
$stdvX3=maple("evalf(Statistics[StandardDeviation]($X3))");
$sumX3=maple("add($X3)");
$X3s=maple("$vX3.$vX3");
:// small variables based on deviation around average value;
$y=maple("$vY-$muY*$e");
$x1=maple("$vX1-$muX1*$e");
$x2=maple("$vX2-$muX2*$e");
$x3=maple("$vX2-$muX2*$e");
:// summation of deviation values;
$sumysq=maple("$y.$y");
$sumx1sq=maple("$x1.$x1");
$sumx2sq=maple("$x2.$x2");
$sumx3sq=maple("$x3.$x3");
$sumyx1=maple("$y.$x1");
$sumyx2=maple("$y.$x2");
$sumyx3=maple("$y.$x3");
$sumx1x2=maple("$x1.$x2");
$sumx1x3=maple("$x1.$x3");
$sumx2x3=maple("$x2.$x3");
:// calculation of the coefficients;
:// coefficient betha1;
$b1=maple("(($sumyx1)*($sumx2sq)-($sumyx2)*($sumx1x2))/(($sumx1sq)*($sumx2sq)-($sumx1x2)^2)");
$b2=maple("(($sumyx2)*($sumx1sq)-($sumyx1)*($sumx1x2))/(($sumx1sq)*($sumx2sq)-($sumx1x2)^2)");
$a=maple("($muY)-($b1)*($muX1)-($b2)*($muX2)");
:// calculate estimate based on given values;
$valuex1=range(8,8,1/10);
$valuex2=range(21,21,1/10);
$yhatvalue=$a+($b1)*$valuex1+($b2)*$valuex2;
:// standard deviations;
$stdvy=maple("evalf(Statistics[StandardDeviation]($y))");
$stdvx1=maple("evalf(Statistics[StandardDeviation]($x1))");
$stdvx2=maple("evalf(Statistics[StandardDeviation]($x2))");
$stdvx3=maple("evalf(Statistics[StandardDeviation]($x3))");
:// correlation coefficients;
$ryx1=maple("($sumyx1)/($n*$stdvy*$stdvx1)");
$ryx2=maple("($sumyx2)/($n*$stdvy*$stdvx2)");
$ryx3=maple("($sumyx3)/($n*$stdvy*$stdvx3)");
$rx1x2=maple("($sumx1x2)/($n*$stdvx1*$stdvx2)");
$rx1x3=maple("($sumx1x3)/($n*$stdvx1*$stdvx3)");
$rx2x3=maple("($sumx2x3)/($n*$stdvx2*$stdvx3)");
:// estimated values;
$Yhat=maple("($a)*$e+($b1)*$vX1+($b2)*$vX2");
$error=maple("$vY-$Yhat");
$sumerror=maple("$error.$e");
$sumerrorsq=maple("$error.$error");
:// $errortr=maple("LinearAlgebra[Transpose]($error)");
:// $sumerrorsq=maple("LinearAlgebra[MatrixMatrixMultiply]($errortr,$error)");
$errorstdv=maple("sqrt($sumerrorsq/($n-2-1))");
:// standard error of the coefficients;
$errorb1=maple("$errorstdv/sqrt((($sumx1sq*$sumx2sq)-(($sumx1x2)^2))/($sumx2sq))");
$errorb2=maple("$errorstdv/sqrt((($sumx1sq*$sumx2sq)-(($sumx1x2)^2))/($sumx1sq))");
:// R-squared;
$Rsq=maple("1-$sumerrorsq/$sumysq");
:// adjusted R-squared;
$Rasq=maple("1-($sumerrorsq/($n-$k-1))/($sumysq/($n-1))");
:// hypothesis: does variable X[i] influence Y? H[0]: it does not so b=0;
$tb1=maple("$b1/$errorb1");
$tb2=maple("$b2/$errorb2");
$Tdf=$n-$k-1;
$alpha=range(0.05,0.05,1/100);
$T=maple("Statistics[Quantile](StudentT($Tdf),(1-$alpha/2))");
$ptb1=maple("Statistics[CDF](StudentT($Tdf),$tb1)");
$ptb2=maple("1-Statistics[CDF](StudentT($Tdf),$tb2)");
Our students use R for solving digital questions about Multivariate Statistics made with MapleTA.
How to use a MLE in MapleTA. Below the code I used in a question?
Remaks about how to program this better or more easy are more than welcome.
://noise. In Dutch ruis means noise;
$ruislow=range(1,5,1);
$ruishigh=range(6,9,1);
://data 1;
$x1=10+rand($ruislow,$ruishigh,1);
$x2=30+rand($ruislow,$ruishigh,1);
$x3=50+rand($ruislow,$ruishigh,1);
$x4=70+rand($ruislow,$ruishigh,1);
$x5=90+rand($ruislow,$ruishigh,1);
$x6=125+rand($ruislow,$ruishigh,1);
$x7=175+rand($ruislow,$ruishigh,1);
$X=maple("Vector([$x1,$x2,$x3,$x4,$x5,$x6,$x7])");
$displayX=maple("printf(MathML:-ExportPresentation($X))");
$TX=maple("LinearAlgebra[Transpose]($X)");
$displayTX=maple("printf(MathML:-ExportPresentation($TX))");
://data 2;
$y1=4+rand($ruislow,$ruishigh,1);
$y2=12+rand($ruislow,$ruishigh,1);
$y3=32+rand($ruislow,$ruishigh,1);
$y4=36+rand($ruislow,$ruishigh,1);
$y5=42+rand($ruislow,$ruishigh,1);
$y6=36+rand($ruislow,$ruishigh,1);
$y7=19+rand($ruislow,$ruishigh,1);
$Y=maple("Vector([$y1,$y2,$y3,$y4,$y5,$y6,$y7])");
$displayY=maple("printf(MathML:-ExportPresentation($Y))");
$TY=maple("LinearAlgebra[Transpose]($Y)");
$displayTY=maple("printf(MathML:-ExportPresentation($TY))");
://data 3;
$z1=76+rand($ruislow,$ruishigh,1);
$z2=108+rand($ruislow,$ruishigh,1);
$z3=128+rand($ruislow,$ruishigh,1);
$z4=54+rand($ruislow,$ruishigh,1);
$z5=18+rand($ruislow,$ruishigh,1);
$z6=4+rand($ruislow,$ruishigh,1);
$z7=1+rand($ruislow,$ruishigh,1);
$Z=maple("Vector([$z1,$z2,$z3,$z4,$z5,$z6,$z7])");
$displayZ=maple("printf(MathML:-ExportPresentation($Z))");
$TZ=maple("LinearAlgebra[Transpose]($Z)");
$displayTZ=maple("printf(MathML:-ExportPresentation($TZ))");
://totals;
$t1=$y1+$z1;
$t2=$y2+$z2;
$t3=$y3+$z3;
$t4=$y4+$z4;
$t5=$y5+$z5;
$t6=$y6+$z6;
$t7=$y7+$z7;
$T=maple("Vector([$t1,$t2,$t3,$t4,$t5,$t6,$t7])");
$displayT=maple("printf(MathML:-ExportPresentation($T))");
:// percentage Y;
$py1=$y1/$t1;
$py2=$y2/$t2;
$py3=$y3/$t3;
$py4=$y4/$t4;
$py5=$y5/$t5;
$py6=$y6/$t6;
$py7=$y7/$t7;
:// percentage Z;
$pz1=$z1/$t1;
$pz2=$z2/$t2;
$pz3=$z3/$t3;
$pz4=$z4/$t4;
$pz5=$z5/$t5;
$pz6=$z6/$t6;
$pz7=$z7/$t7;
://odds;
$o1=$py1/$pz1;
$o2=$py2/$pz2;
$o3=$py3/$pz3;
$o4=$py4/$pz4;
$o5=$py5/$pz5;
$o6=$py6/$pz6;
$o7=$py7/$pz7;
://logit;
$ln1=ln($o1);
$ln2=ln($o2);
$ln3=ln($o3);
$ln4=ln($o4);
$ln5=ln($o5);
$ln6=ln($o6);
$ln7=ln($o7);
$L=maple("Vector([$ln1,$ln2,$ln3,$ln4,$ln5,$ln6,$ln7])");
$displayL=maple("printf(MathML:-ExportPresentation($L))");
://linreg;
://$fit1=maple("Statistics[LinearFit]([1,t],$X,$L,t)");
$fit=maple("map(rhs, Statistics[Fit](a*x+b, $X, $L, x, output=parametervalues))");
$intercept=maple("$fit[2]");
$slope=maple("$fit[1]");
$r=maple("evalf(Statistics[Correlation]($X,$L))");
Best regards,
Nico
Hi everybody,
I have written a module (let's say MyModule) that  I use as a package in a worksheet (with(MyModule)).
At some point in my worksheet I call the procedure MyProc which is part of MyModule.
I find it not to work as expected. So I modify it within MyModule and generate again the archive which contains this module.
Because my worksheet does a lot of things before the call to MyProc, I would like to test quickly the above modifications.
The idea is to do :
unwith(MyModule):  # packages() no longer exhibits its name
with(MyModule);      # to load the corrected one
Unfortunately, contrary to what happens with a "native" package,  the command unwith(MyModule) is ineffective:
  • once done showstat(MyProc) still displays the content of the procedure, and running  the command MyProc(...) proves that it still "exists" in the worksheet
  • forcing a reload of MyModule ( with(MyModule) ) and acanning again MyProc ( showstat(MyProc) ) reveals the code MyProc had when MyModule has been loaded for the first time.
Is it possible to "free" a user package through the "unwith" command ?
Hope to read you soon, TIA
PS : to be clearer
A worksheet contains  the definition of N procedures, plus the one of MyModule, and ends with the commands to generate an archive file named MyModule.mla.
MyModule is defined that way
MyModule := module()
option package
export Proc1 := eval(:-Proc1),
           MyProc := eval(:-MyProc),
           ProcN := eval(:-ProcN):
end module
hellow can we draw the figure like this
How can I install GeM software from the link http://cpc.cs.qub.ac.uk/?
I have tried many times but I didn't get.
@mskalsi
I was trying the direct method for conservation law of wave equation.But the fluxes and conserved density are not coming correct in eq.(4)(see attached file) because (1) and (6) are not same.What mistake have I done?
wave_eq_3.mws
Dear friends~I knew that I can copy each function's code into one worksheet bue it's tedious if I need to call many functions.So I want to find another approach with maple's statement.
Thank you ~
I have problem with plot of the function ( See attachment)
Chargement plots
plot((x^3-x^2)^(1/3), x)
Download PlotProblème.mw
I dont fully understand the principle of a global variable for example _Z in RootOf expressions. Can someone please explain this to me.
Hi I've been trying to solve these set of PDEs below and have been at it for very long
My codes are below
I tried solving the first equation by using:
sys_ode := 2*(diff(T(eta), eta, eta, eta))+T(eta)*(diff(T(eta), eta, eta)) = 0
ics := T(0) = 0, (D(T))(0) = 1, (D(T))(20) = 0
Digits := 10
sol1 := dsolve({ics, sys_ode}, numeric, output = operator)
{q(eta) = rhs(sol1[2](eta)), w(eta) = rhs(sol1[3](eta))}
Then inputting into the subsequent two equations:
PDE1 := eval([2/P . (diff(g(x, eta), eta, eta))+q(eta)*(diff(g(x, eta), eta))-g(x, eta)*w(eta) = 2*x*w(eta)*(diff(g(x, eta), x)), 2/S . (diff(phi(x, eta), eta, eta))+q(eta)*(diff(phi(x, eta), eta)) = 2*x*w(eta)*(diff(phi(x, eta), x))])
subBC1 := -phi(x, 0)*exp(g(x, 0)*sqrt(x)/(1+varepsilon*g(x, 0)*sqrt(x)))
subBC2 := alpha . ((phi(x, 0))(sqrt(x)))(exp(g(x, 0)*sqrt(x)/(1+varepsilon*g(x, 0)*sqrt(x))))
BC := {diff(g(0, eta), eta, eta) = 0, diff(phi(0, eta), eta, eta) = 0, g(0, eta) = 0, g(x, 20) = 0, phi(0, eta) = 1, phi(x, 20) = 1, (D[2](g))(x, 0) = subBC1, (D[2](phi))(x, 0) = subBC2}
P = 1
S = 1
pds := pdsolve(PDE, {BC}, numeric, spacestep = .25)
but always end up with :Error, (in pdsolve/numeric/process_PDEs) number of dependent variables and number of PDE must be the same
I know my BC conditions might probably have some major errors too but i really cant proceed on cos i always end up with this same error. I really hope anyone would be able to help me on this
help please
Thought it would be a neat way to create identation for loops and if branches in a text editor and copy the code into Maple. But Maple inserts a new prompt at the beginning of every line.
Is there a solution in 2018?
First 887 888 889 890 891 892 893 Last Page 889 of 2459
