In the fraction 3^665/2^x=y, where y is more than 1 and less than 2, I want to know the value of x. What input should I write, please?
  1. (k-2)*(k^2+5)*(k^3-k^2+7*k+8)/(6*k*(k^2-3*k+8))
  2. (k+2)*(k^2+5)*(k^3-5*k^2+13*k-8)/(6*k*(k^2-3*k+8))
  3. k^3+3*k^2+11*k-3
  4. k^2+2*k+9
How to draw the following function containing an imaginary number
u := proc (x, t) options operator, arrow; 1/2+I*sqrt(2)/(exp(x-t)+2*exp(-x+t))+(1/2)*(exp(x-t)-2*exp(-x+t))/(exp(x-t)+2*exp(-x+t)) end proc
Download plot33.mwDownload plot33.mw
I'm attempting to solve the complex-valued differential equation
assume(t::real):
pde := diff(A(t),t) - I * conjugate(A(t))*A(t)^2 = 0:
dsolve(pde);
However, it seems Maple attempts to solve it using separation of variables and gives
t-Intat(-I/conjugate(_a)/_a^2,_a = A(t))+_C1 = 0
Unless I'm mistaken, a complex integral such as this isn't even defined without a contour.
Working the integral out by hand, I know the solution to be
_C1*exp(I*abs(_C1)*t)
Is there a trick I'm missing to get Maple to find this solution? Or is this outside the scope of what Maple can handle on it's own?
I believe I am having memory issues which is causing the MAPLE kernal to terminate.  If I assign m a value then it seems to work, but I would like to leave m unassigned so that S1 can later be evaluated for any arbitrary m.  Is there a way around this?
T := M*tau;
`assuming`([simplify(expand(combine(S1)))], [m::integer])
Download MAPLE_crashing.mw
Hello everybody
I am currently having trouble 'manually simplifying' an equation that I differentiated using maple. Basically, the equation that I get involves hessian-matrices. Since the resulting equation is rather long, I would like to replace every such matrix by a sign, say H.
This is easy to do for non-matrix equations, i.e.
subs(sin(x)sin(y) = z, sin(x)sin(y) + xy)
will give me z + xy, which looks a bit easier.
However, I couldn't figure out how to do a similar thing with matrices. For example, the following code
subs(Matrix(3, 3, [[x, y, z], [y, z, x], [z, x, y]]) = A, Matrix(3, 3, [[x, y, z], [y, z, x], [z, x, y]])+B)
 will not work.
I already thought about converting the matrices first into lists (because for some reason it works for lists). However, I would also like to do the same as above for for functions of matrices, i.e. set F(A) = G, where A is a matrix (this also fails, probably for the same reason).
Also, the same thing seems to fail for vectors and general arrays, so I guess the actual problem might be the array type.
I also tried alternative ways, such as eval or algsubs, but the later even gives an error since it cannot handle matrices at all.
This feels a bit like a noob question, but I spent almost 2 days now searching for an answer or a workaround, so my apologies if I missed something trivial.
All the best
Adrian
Hi, I try to solve the below integral. when I press enter key maple dosen't show answer and show the integral again.
int(r*r[bc]*r[tc], r = r[bc] .. r[tc]);
but when I write intgral this way and use " i " as subscript ,maple solve it.
int(r[i]*r[bc]*r[tc], r[i] = r[bc] .. r[tc]);
I just want to know why?
what is difference between first and second integral?
and also is there any way (or any packages) to solve these integrals?
(I read https://www.maplesoft.com/applications/view.aspx?SID=6846&view=html article befor)
thanks.
Good day everyone,
I'm relatively new to Maple, and I study engineering (not maths), so maybe my problem is related to a bad approach of the equations.
The problem is that I'm asking Maple to do a double integral of a "complex" expression and it only solve the first integral, but not the second.
Here is the code:
https://www.dropbox.com/home/C%C3%81LCULO%20FUERZAS
Dears!
Hope everyone should be fine. I am face to import excel sheet in maple. I saved execl sheet with name "Employees.xlsx" at desktop. When I use the following command
S := Import("Employees.xlsx", 1, "A1:B101");
I got the following error.
"Error, (in ExcelTools:-Import) Could not open the file"
Please help me to fix this problem. I am waiting positive response.
Special request to:
@Carl Love
@Preben Alsholm
@acer
  1. (2*k^3-6*k^2+7*k+15-k*sqrt(k^6-12*k^5+64*k^4-198*k^3+448*k^2-636*k+369))/(-k^4+2*k^3-2*k^2+10*k+15)
  2. (k^3+5*k+(-k^2+k)*sqrt(k^4-10*k^3+37*k^2-60*k+180)+30)/(-k^4+k^3+k^2+5*k+30)
Please I am trying to get a compact result for this code in particular the lines assigne "a" and "b" respectively. I am sure the result shoud not be more than two lines. Can someone be of help?
P:=a[0]+(a[1]*x)/(1+(a[2]*x)/(1+(a[3]*x))):
Q:=diff(P,x):
T:=diff(P,x,x):
e1:=simplify(eval(P, x=q))=y[n]:
e2:=simplify(eval(Q,x=q))=f[n]:
e3:=simplify(eval(Q,x=q+h))=f[n+1]:
e4:=simplify(eval(T,x=q+h))=g[n+1]:
var:=seq(a[i], i=0..3):
M:=e||(1..4):
Cc:=eval(<var>, solve(eval({M}),{var}) ):
for i from 1 to 4 do
	a[i-1]:=Cc[i]:
Cf:=P:
a:=y[n+1]=collect(simplify(eval(Cf, x=q+h)),[y[n], f[n], f[n+1],g[n+1]], recursive):
b:=map(eval@allvalues, [a]);
I'm receiving a very interesting error when attempting to solve a system of differntial equations:
{sqrt(2)*sqrt(F1(t))*diff(F2(t),t) = 0}:
% union {F3(t) = 0}:
pdsolve(%, {F1(t),F2(t),F3(t)});
When attempting to run this code, I get the following error:
Error, (in pdsolve/sys) invalid input: DifferentialAlgebra:-DifferentialRing expects value for keyword parameter blocks to be of type {undefined, Or(list({name, unknown, list({name,unknown})}),name,unknown)}, but received [F3, F2, _F1 = (NULL), F1 = [_F1, F1], _F2]
Interestingly, removing the second line, or even the sqrt(2), allows the calculation to proceed correctly. It this a bug, or am I doing something wrong?
Thank you very much!
(I'm aware this would technically be a system of ODEs, not PDEs; my actual code includes additional partial derivatives. Additionally, dsolve appears to only generate a trivial solution in this case).
Hey folks.
I need to do a kind of loop calc. in maple and im not shure how to.
lets say i guess a temperature T.
i then put it through all soughts of eqations where the variabel T is necessary for the outcome of my result, which i then use again as T. the loop should finish when T as a result is the same as my guess in the beginning. like:
T:=45
bla bla calculation
T_new:= 35
again
T:=35
bla bla calculation
T_new= 35
Finish!!
Any ideas?
Dear sir I want to plot the graph for different values of F=0.1, F=0.2,F=0.5 . My codes are given and i am attaching the sample graph. For F=0.1, Nb=0.1,0.2,0.3 three curves
Similarly For F=0.2,Nb=0.1,0.2,0.3 three curves and for F=0.5, Nb=0.1,0.2,0.3 three curves. Total nine curves
h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
K1:=((4/h(z)^4)-(sin(alpha)/F)-h(z)^2+Nb*h(z)^4):
lambda:=Int(K1,z=0..1):
L1:=0.2:
d1:=0.2:
alpha:=Pi/6:
plot( [seq(eval(lambda, Nb=j), j in [0.1,0.2,0.3])], delta2=0.02..0.1);
please how can I simplify the results of assigned K cum each of the coefficients further in the following code? the results are too large.
#k=2:
omega:=u/h:
psi:=v/h:
t:=(sum(a[j]*x^j,j=0..2)+a[3]*sin(omega*x)+a[4]*cos(omega*x)+a[5]*sin(psi*x)+a[6]*cos(psi*x)):
F:=diff(t,x):
G:=diff(t,x,x):
p1:=simplify(eval(t,x=q+h))=y[n+1]:
p2:=simplify(eval(F,x=q))=f[n]:
p3:=simplify(eval(F,x=q+h))=f[n+1]:
p4:=simplify(eval(F,x=q+2*h))=f[n+2]:
p5:=simplify(eval(G,x=q))=g[n]:
p6:=simplify(eval(G,x=q+h))=g[n+1]:
p7:=simplify(eval(G,x=q+2*h))=g[n+2]:
vars:= seq(a[i],i=0..6):
Cc:=eval(<vars>, solve({p||(1..7)}, {vars})):
for i from 1 to 7 do
	a[i-1]:=Cc[i]:
Cf:=t:
K:= collect(combine(simplify(eval(Cf,x=q+2*h),size),trig),{y[n+1],f[n],f[n+1],f[n+2],g[n],g[n+1],g[n+2]},factor):
alpha[1]=simplify(coeff(K,y[n+1]));
beta[0]=simplify(coeff(K,f[n]),size);
beta[1]=simplify(coeff(K,f[n+1]),size):
beta[2]=simplify(coeff(K,f[n+2]),size):
gamma[0]=simplify(coeff(K,g[n]),size):
gamma[1]=simplify(coeff(K,g[n+1]),size):
gamma[2]=simplify(coeff(K,g[n+2]),size):
First 895 896 897 898 899 900 901 Last Page 897 of 2459
