I didn't even know the erf function existed until doing this problem. I looked up how to use it, so I tried plugging in the explicity form into Maple, hoping it'd solve it, but it just spit back out the erf function.
I am trying to get a number answer.  A decimal. Because this is calculating a probability. How do I get Maple to give me a number here? Thanks!
so i  got this code:
But it cannot Find a value for M (wich would be the maximum distance between) it literaly stays working for severeal minutes and necer gives an answer, also i cant find a function to do this for every value for n (n-1 steps from a to b), also would mean that xy would need to get more points, any idea of how can i solve this for any n? or at least fix the problem with M, and i do the steps from a to b Manually.
heeeelp me please this is driving me nuts
thanks a lot :)
hi
why this equation does not any answer?
s-s.mw
eq:={-J*g[1]*(diff(w(x), x, x, x, x, x, x))+J*c[1]*(diff(w(x), x, x, x, x))+A*g[113113]*(diff(w(x), x, x, x, x))+(beta[11]*A*0)*`ΔT`*(diff(w(x), x, x))+2*b*f[1133]*(Pi/L)^2*(d[33]*lambda[3]*`ΔT`*L/mu[33]-2*f[1133]*a*Pi/L-P[3]*`ΔT`*L)*sin(Pi*x/L)*sinh(h*Pi/(2*L))/(2*cosh(h*Pi/(2*L))*(-a33+d[33]^2/mu[33])) = 0, w(0) = 0, w(L) = 0, (D(w))(0) = 0, (D(w))(L) = 0, ((D@@3)(w))(0) = 0, ((D@@3)(w))(L) = 0}
{-J*g[1]*(diff(diff(diff(diff(diff(diff(w(x), x), x), x), x), x), x))+J*c[1]*(diff(diff(diff(diff(w(x), x), x), x), x))+A*g[113113]*(diff(diff(diff(diff(w(x), x), x), x), x))+b*f[1133]*Pi^2*(d[33]*lambda[3]*`ΔT`*L/mu[33]-2*f[1133]*a*Pi/L-P[3]*`ΔT`*L)*sin(Pi*x/L)*sinh((1/2)*h*Pi/L)/(L^2*cosh((1/2)*h*Pi/L)*(-a33+d[33]^2/mu[33])) = 0, w(0) = 0, w(L) = 0, (D(w))(0) = 0, (D(w))(L) = 0, ((D@@3)(w))(0) = 0, ((D@@3)(w))(L) = 0}
dsolve(eq, w(x))
Download s-s.mw
I'm trying to solve a Quantum Mechanics problem that requires me to normalize a wavefunction before I proceed. I have the book solutions to these problems (I'm just trying to practice solving using Maple) so I know what the answers are SUPPOSED to be. But I'm not getting the answers I expected when dumping it into Maple.
What I put into Maple:
What I was SUPPOSED to get:
I assume this is a radical simplication I need to make. But in highlighting the expression, right clicking, and trying the different simplification options, nothing worked.
http://www.maplesoft.com/applications/view.aspx?SID=4229
from book example, it seems assumed that input size of data such as list size or matrix size is the same as
trained data set size, but this need to hard code infinite number of types of size
What is the method to programming neural network when input size is smaller or changing and not equal to size of trained data set?
I have a list of equations. I would like to display this list in column.
Problem : as each term of my list is an equation, i can not transform my list in a vector.
How can I do to display a list of equations in column ?
Thank you for your help.
Hi guys,
I run my code and after a point all the numerical values are followed by a dot. Why is that? Also the symbolic variables have a 1. before them.
Thanks a lot!
Probably not Maple's territory, but maybe a challenge?  Can we can get maple to do this?  Done by Matlab found here..
http://stackoverflow.com/questions/28279337/matlab-cuda-ocean-wave-simulation
i got 2 curves
a := abs(x);
b := (3/4)*x^2+1/4;
how can i get the max distance between them from x = -1 until x =1?
 heeeeeeeeeelp
Hello! Hope everyone would be fine. I want to solve the following system of ODEs please help to find the numerical solution
N := .6; alpha := .4; beta := .1; Nt := .2; Pr := .5; Nb := .1; s := .2; lambda[1] := 1; delta := .5; gm := 1; Sc := 1:L:=1:
Eq1 := (alpha*s+1)*(diff(F(eta), eta, eta, eta))-(F(eta)+(1/2)*s*eta)*(diff(F(eta), eta, eta))+((1/2)*(diff(F(eta), eta))-s)*(diff(F(eta), eta))-2*(G(eta)^2-(1-gm)^2)-2*lambda[1]*(H(eta)+N*Y(eta))-(alpha+beta-(1/4)*delta*(diff(F(eta), eta, eta, eta)))*(diff(F(eta), eta, eta))^2-(alpha-2*beta)*(diff(F(eta), eta))*(diff(F(eta), eta, eta, eta))-(2*(alpha-beta-(1/4)*delta*(diff(F(eta), eta, eta, eta))))*(diff(G(eta), eta))^2-(2*(alpha-(1/4)*delta*(diff(F(eta), eta, eta))))*G(eta)*(diff(G(eta), eta, eta)) = 0; Eq2 := (alpha*s+1)*(diff(G(eta), eta, eta))-F(eta)*(diff(G(eta), eta))+G(eta)*(diff(F(eta), eta))+s*(1-gm-G(eta)-(1/2)*eta*(diff(G(eta), eta)))-(1/2)*alpha*s*eta*(diff(G(eta), eta, eta, eta))+((3/2)*alpha+beta)*G(eta)*(diff(F(eta), eta, eta, eta))-((1/2)*alpha+beta)*(diff(F(eta), eta))*(diff(G(eta), eta, eta))-delta*((diff(F(eta), eta, eta))^2+6*(diff(G(eta), eta))^2)*(diff(G(eta), eta, eta)) = 0; Eq3 := (diff(H(eta), eta, eta))/Pr-F(eta)*(diff(H(eta), eta))+(1/2)*H(eta)*(diff(F(eta), eta))-s*(2*H(eta)+(1/2)*eta*(diff(H(eta), eta)))+Nb*(diff(H(eta), eta))*(diff(Y(eta), eta))+Nt*(diff(H(eta), eta))^2 = 0; Eq4 := (diff(Y(eta), eta, eta))/Sc-F(eta)*(diff(Y(eta), eta))+(1/2)*Y(eta)*(diff(F(eta), eta))-s*(2*Y(eta)+(1/2)*eta*(diff(Y(eta), eta)))+Nt*(diff(H(eta), eta, eta))/Nb = 0;
IC1 := F(0) = 0, (D(F))(0) = 0, G(0) = gm, H(0) = 1, Y(0) = 1; IC2 := (D(F))(L) = 0, G(L) = 1-gm, (D(G))(L) = 0, H(L) = 0, Y(L) = 0; dsys1 := {Eq1, Eq2, Eq3, Eq4, IC1, IC2}; dsol1 := dsolve(dsys1, numeric, output = listprocedure, range = 0 .. L);
dsol1f := subs(dsol1, F(eta));
dsol1g := subs(dsol1, G(eta)); dsol1h := subs(dsol1, H(eta)); dsol1y := subs(dsol1, Y(eta));
With my best regards and sincerely.
Let:
f:=x->1/sqrt(2*Pi)*exp(-x^2/2);
I.e. f is a standard Gaussian PDF.
Then (in Maple 2016.1):
Int(convert(f(x)*f(y)*x*x*abs(x+y),piecewise,x),x=-infinity..infinity,y=-infinity..infinity):
evalf(%);
Returns:
1.692568751
However (again in Maple 2016.1):
int(convert(f(x)*f(y)*x*x*abs(x+y),piecewise,x),x=-infinity..infinity,y=-infinity..infinity):
evalf(%);
Returns:
-0.5641895835
This is clearly incorrect, as the integral of a positive function must be positive.
This also seems to be a problem in which ever version of Maple is used behind the scenes on this forum.
int(convert(1/sqrt(2*Pi)*exp(-x^2/2)*1/sqrt(2*Pi)*exp(-y^2/2)*x*x*abs(x+y),piecewise,x),x=-infinity..infinity,y=-infinity..infinity)
gives:
Hi, there
How can I find the recurrence relation  for second derivative of sequence of functions  f-{n}(x)=\frac{(1-x^2)^n}{n!} in  maple 15?
please specify the commands.
we know the solution f"_{n}(x)=2(1-2n)f_{n-1}(x)+4f_{n-2}(x)
M.R. Yegan
I have created a script code in maple. I also have contructed a power circuit in matlab simulink. How I use my code in matlab?
Seem to be a bit stuck. Here's my code:
Thanks in advance :-)
It is suggested
hypergeom([1/3, 2/3], [3/2], (27/4)*z^2*(1-z)) = 1/z
if z > 1. Here is my try to prove that with Maple:
a := `assuming`([convert(hypergeom([1/3, 2/3], [3/2], (27/4)*z^2*(1-z)), elementary)], [z > 1])
-(1/((1/2)*(27*z^3-27*z^2+4)^(1/2)+(3/2)*z*(3*z-3)^(1/2))^(1/3)-1/((1/2)*(27*z^3-27*z^2+4)^(1/2)-(3/2)*z*(3*z-3)^(1/2))^(1/3))/(z*(3*z-3)^(1/2))
b := `assuming`([simplify(a, symbolic)], [z >= 1])
2*(-(12*(3*z+1)^(1/2)*z-12*z*(3*z-3)^(1/2)-8*(3*z+1)^(1/2))^(1/3)+(12*(3*z+1)^(1/2)*z+12*z*(3*z-3)^(1/2)-8*(3*z+1)^(1/2))^(1/3))/((3*z-3)^(1/2)*(12*(3*z+1)^(1/2)*z+12*z*(3*z-3)^(1/2)-8*(3*z+1)^(1/2))^(1/3)*(12*(3*z+1)^(1/2)*z-12*z*(3*z-3)^(1/2)-8*(3*z+1)^(1/2))^(1/3)*z)
plot(1/b, z = 1 .. 10)
simplify(diff(1/b, z), symbolic)
-48*(((3*z-2)*(3*z+1)^(1/2)+z*(3*z-3)^(1/2))*((12*z-8)*(3*z+1)^(1/2)-12*z*(3*z-3)^(1/2))^(1/3)+((12*z-8)*(3*z+1)^(1/2)+12*z*(3*z-3)^(1/2))^(1/3)*((-3*z+2)*(3*z+1)^(1/2)+z*(3*z-3)^(1/2)))/((3*z+1)^(1/2)*(3*z-3)^(1/2)*((12*z-8)*(3*z+1)^(1/2)+12*z*(3*z-3)^(1/2))^(2/3)*((12*z-8)*(3*z+1)^(1/2)-12*z*(3*z-3)^(1/2))^(2/3)*(((12*z-8)*(3*z+1)^(1/2)-12*z*(3*z-3)^(1/2))^(1/3)-((12*z-8)*(3*z+1)^(1/2)+12*z*(3*z-3)^(1/2))^(1/3))^2)
Download simplification.mw
First 1025 1026 1027 1028 1029 1030 1031 Last Page 1027 of 2428
