From differential expression I am trying to extract coefficients corresponding to given indets, but the coeffs command is giving me error as "invalid argument to coeffs"
For example for worksheet titled "[852] Determining Equations using Prolongation" the error is showing for expression (9).
Whereas the same command in worksheet titled "[411] Determining Equations for Variable Coeff KdV(Reviewed)" is working okay and is giving desired result at (16).
I am running both worksheets in Maple 18.
[852]_Determining_Equations_Using_Prolongation.mw
[411]_Determing_Equations_for_Variable_coefficient_KdV_(reviewed).mw
Can anybody please tell, where I can find seminar/workshops on Maple training ?
I am a new Maple user and I am still unaware of a lots of fancy features of Maple. I have a problem of simultaneous fitting polynomials. I wish that I could have help from you. Say, we have two polynomials of two variables,
f1(x,y)=a1+a2*x+a3*y+(a4+a5)*x2+(a4-a5)*y2;
f2(x,y)=b1+b2*x+b3*y+(a4-a5)*x2+(a4+a5)*y2.
Note that a4 and a5 are shared by the two polynomials. I would like to fit the two polynomials against their respective data set. Is there anyway I can do it using Maple? Any of your help is highly appreciated!
Best regards,
Toby
HI
HOW I convert root of in to another form
lorenz_5.mw
I'd like to find out what number Maple can still calculate the isprime for, and what number will make it go "No thanks, this is madness - ERROR".
I tried isprime (10100,000,000 + 2), and it can still calculate the result. No prime of course, that's the whole point of the +2.
I tried isprime(1010ˆ9 + 2) and it crashed.
But what is the tipping number?
I decided I should write a loop, and let maple write away the last number till it crashes. Is this possible? I think I'll need something like
> for n from 5 to ??? do isprime (10ˆn + 2) and ??? end do
This isn't suitable at all, but I cant figure out how to program "to error" or "write away this number"...
I hope the question is clear and look forward to ideas on how to make this work.
Dear Community,
I have difficulties evaluating a rather complicated infinite integral (see attachment). The result should be something like 12.319. Any idea how to go get this?
Tx for the kind help in advance,
best regards
Andras
Infinite_Integral_2.mw
Plz help me! How to accelerate the calculation speed the following the program?
with(PDEtools); declare((u, W)(x, t)); KN := 10;
AFP := proc (C1, C2, C3, C4, H, KN, N) local ADM1, n, lambda, F, i, A0, A, U, W, u, L, R, NL, w, PDE1, IC1, d, Eq1, Eq2, Eq3, LI, trL, tr1, trN, Apr, AprK, trSol, Sol, AD; declare((u, W)(x, t)); ADM1 := proc (n) options operator, arrow; convert(subs(lambda = 0, value((Diff(F(Sum(lambda^i*U[i], i = 0 .. n)), `$`(lambda, n)))/factorial(n))), diff) end proc; A0[0] := F(U[0]); for n to KN do A0[n] := ADM1(n) end do; for n from 0 to KN do A[n] := convert(C1*(diff(subs({seq(U[i] = W[i](x, t), i = 0 .. KN)}, expand(subs(F(U[0]) = U[0]*exp(U[0]), A0[n]))), x)), diff)+convert(C2*subs({seq(U[i] = Diff(W[i](x, t), x), i = 0 .. KN)}, expand(subs(F(U[0]) = U[0]^2, A0[n]))), diff) end do; L := proc (w) options operator, arrow; diff(w(x, t), t) end proc; R := proc (w) options operator, arrow; C3*(diff(w(x, t), x)) end proc; NL := proc (w) options operator, arrow; C1*(diff(w(x, t)*exp(w(x, t)), t))-C2*(diff(w(x, t), x))^2 end proc; PDE1 := proc (w) options operator, arrow; L(w)-R(w) = -NL(w) end proc; IC1 := u(x, 0) = sum(2*(int(sin((d+1/2)*Pi*x/H), x = 0 .. H))*exp(-C4*(d+1/2)^2*Pi^2*t/H^2)*sin((d+1/2)*Pi*x/H)/H, d = 0 .. N); LI := proc (w) options operator, arrow; Int(w(x, t), t = 0 .. t) end proc; tr1 := u-rhs(IC1); Eq1 := LI(lhs(PDE1(u))) = LI(rhs(PDE1(u))); Eq2 := simplify(subs(lhs(Eq1) = tr1, Eq1)); trL := u = add(u[j](x, t), j = 0 .. KN); trN := LI(NL(u)) = Int(Sum(A[i], i = 0 .. KN), t = 0 .. t); Eq3 := subs(trL, lhs(Eq2)) = subs(trN, rhs(Eq2)); Apr[0] := u[0](x, t) = rhs(IC1); AprK := u[k+1](x, t) = -(Int(AD[k], t = 0 .. t)); for i from 0 to KN do Apr[i+1] := value(subs({seq(Apr[m], m = 0 .. i)}, subs({seq(W[m] = u[m], m = 0 .. i)}, subs(k = i, AD[i] = A[i], AprK)))) end do; trSol := {seq(Apr[i], i = 0 .. KN)}; value(subs(trSol, trL)) end proc;
Download AFP.mw
Am here again, pls help me check out this adm code, cant get a result.
below is the attached file
 adm_2_method.mw
Ok i have used a diverse range of programming IDE now, but i am of course alot more comfortable the maple interface simply because of the amount of time i have spent on it, also it was my first "real" introduction to programming, but i was keen to trial and review of all the major CAS out on the market, but for a common purposed package within them they provide, for example the number theory package.
So the question is quite broad, im looking for suggestions for the most unbias way to go about this.
it would need to be a coauthored review with a representative writer for the seasoned user for each one right?
hi...how i can pdsolve this equation numerically or analyticlly?
this equation is time-fractional  equation with generalized Cattaneo model
where
 is the fractional derivative operator considered in the
Caputo sense.
FRACTION.mw
k := 1; -1; rho := 1; -1; h := 1; -1; alpha := 2-Upsilon; -1; 0 < Upsilon and Upsilon <= 1
k*(diff(T(z, t), z, z)) = rho*(diff(T(z, t), [`$`(t, alpha)]))
diff(diff(T(z, t), z), z) = diff(T(z, t), [`$`(t, 2-Upsilon)])
k*(diff(T((1/2)*h, t), z)) = 1:
k*(diff(T((-h)*(1/2), t), z)) = 0:
T(z, 0) = 0
T(z, 0) = 0
Download FRACTION.mw
Dear Community,
I would like to calculate a rather sophisticated function (see it in the attachmenet) Once I try to evaluate it at certain values I get the error message:
"Error (in pD) illegal use of an object as a name"
What object Maple means? I guess its a minor mistake, yet I'm lost here, and the online help says "There is no help page available for this error"
Andras
Bessel_plot.mw
Is anyone running the 2016.1a patch on ubuntu 16.04?
A fresh installation starts up and works, but after I install the patch the installation seems broken:
cd /usr/local/maple2016/bin
./maple
/usr/local/maple2016/bin.X86_64_LINUX/mserver: error while loading shared libraries: libicuucmpl.so.56: cannot open shared object file: No such file or directory
maple: could not start mserver
it looks like my installation does not have libicuucmpl.so.56. I can see these however:
./bin.X86_64_LINUX/libicuucmpl.so.49.1.1
running xmaple has maple open, then stay unresponsive.
Here is the upgrade file, i've been trying to use:
md5sum ./Maple2016.1LinuxX64Upgrade.run
7502caaa65cc623d5d2574823eee9343  ./Maple2016.1LinuxX64Upgrade.run
Has anyone else encountered this problem?
Dear Pros, I'm a biginer so I have a question about my program.
I have a lot of arrays which are result from 2 while loop. Now, I want creat a matrix from them but i can't. So, could you help me to do it.
For detail:
V[1]:=[ 1 2 3]
V[2]:=[2 3 4]
V[3]:=[3 4 5]
V[4]:=[2 6 7]
V[5]:=[7 8 9]
V[n]
with type of V[i] is a array.
I searched and found a solution by manual to create a matrix as follow:
V_matrix:=<V[1],V[2],V[3]>
but in this case i can't but manual with n=100
please help me to have a Matrix.
Thank a lots.
I wondering if it is able to create a new symbol in maple, like it is possible to create a custom snippet in the pallets. Speceficly I am asking how to create a new symbol/charachter for 2D math. So if anyone knows please tell me :)
I would like to solve the following non linear ODE with Maple, but I am no able. I do not know if it is possible, beccause it is nolinear.
I really appreciate any advice or help. This is the equation:
y'(x) - (Q - x*p0*(exp(alpha-beta*y(x)))/(1+exp(alpha-beta*y(x))))^2=0
thanks a lot
First 1104 1105 1106 1107 1108 1109 1110 Last Page 1106 of 2459
