I downloaded a maplesoft apps, and wat to activate, an activeation form displayed requiring me to put in a purchase code of which i don't know or have. How can i get it or where can i find it? please some one help.
Does anyone know what the default function is for the pre-subscript and pre-superscript?  I would like to use them for a variable name to represent the local reference frame and global reference frame in my multibody calculations.  Thanks
1.I want to plot (x-x0)^2 from x=0..10 with a value for x0 in the plot function not in the procedure. The procedure should
test x against x0 and if x<x0 then y=0 else y=(x-x0)^2
2.Is it possible to use explore and use x0 as a slider?
Staffan
http://mathforum.org/kb/message.jspa?messageID=685890
i find equation above
for ii from 0 by 5 to 365 do
eq1 := x^2 + y^2 = arccos(x/r);
eq2 := y = evalf((atan(-1) - ii*Pi/180)/Pi)*(-1.0)*x;
xy := fsolve({eq1, eq2});
print("M",rhs(xy[1]),rhs(xy[2]),","):
but i do not understand how to set r
i use a line scanning 365 degrees to get the path of swirl
would like to get path data for c# WPF animation
but this method may have multiple solution because an intersection of swirl
and a line can have multiple points
how to change rotation angle into slope of line?
with(MTM):
evalf(solve(atan(-1) - 45*Pi/180 = atan(x), x))*180/Pi;
above can not be solved
if angle is 30 degree
is following correct?
with(MTM):
angle := 30:
evalf((atan(-1) - 30*Pi/180)/Pi)*(-1.0);
Hello people in mapleprimes,
I have a question:
What are you doing when you use maple in calculating, for example, your paper,
to avoid missing, for example, variables you use, or for your needs to look back the outcomes you obtained before?
If this is a paper-using work, on considering what to do next, you will read some pieces of papers you wrote and
on which you had calculated and obtained necessary equations. But, with small monitor 13 inch, and with
inconvenience of dealing with things in PC, compared with papers, I feel some stress in using maple in writing a paper.
So, now, I am asking you what kind of methods you has devised to make what you are writing compact and easy,
for you to handle with what you are writing.
I know surely that there are the document block, which enables output or input to not be shown, the workbook,
which is helpful in putting attached worksheets or jpg files together at one workbook, and the distinction of ":" and ";",
which in the case of the former, hides expressions in the outcome.
But, yet, I want to ask you about the ways you use to make it easy to write something.
If you have some, I will be very glad if you show it here.
Best wishes.
taro
I would like compute the vertices of the convex hull of finitely many points in some \mathbb{R}^{n}, where the coordinates of these points could be rational numbers or irrational numbers like \sqrt{2}.
I know that PolyhedralSets[ConvexHull] is a direct command, however it does not support irrational numbers. But if I transform all coordinates into floating point numbers, for some rational numbers the rounding error would be large enough to affect the result. For example, after the transform some collinear points are no longer collinear.
Dear All
I need to reduce system of differential equation system into triangular system which I came to know can be done using Maple package "DifferentialAlgebra", but I do not know how to use this package for triangularization.
The differential system is DetSys derived from  some PDE:
with(PDEtools):
DepVars := [f(u(x, t)), u(x, t)]; 1; declare(f(u(x, t)), u(x, t))
f(u(x, t))*`will now be displayed as`*f
PDE1 := diff(u(x, t), t, t)-(diff(u(x, t), x, x))-f(u) = 0
diff(diff(u(x, t), t), t)-(diff(diff(u(x, t), x), x))-f(u) = 0
G := [xi(x, t, u), tau(x, t, u), phi(x, t, u)]
declare(G)
phi(x, t, u)*`will now be displayed as`*phi
tau(x, t, u)*`will now be displayed as`*tau
xi(x, t, u)*`will now be displayed as`*xi
DetSys := DeterminingPDE(PDE1, G, integrabilityconditions = false)
{-2*(diff(diff(tau(x, t, u), t), u))+diff(diff(phi(x, t, u), u), u), 2*(diff(diff(tau(x, t, u), u), x))-2*(diff(diff(xi(x, t, u), t), u)), 2*(diff(diff(xi(x, t, u), u), x))-(diff(diff(phi(x, t, u), u), u)), 2*(diff(tau(x, t, u), x))-2*(diff(xi(x, t, u), t)), 2*(diff(xi(x, t, u), x))-2*(diff(tau(x, t, u), t)), diff(diff(tau(x, t, u), x), x)+2*(diff(diff(phi(x, t, u), t), u))-(diff(diff(tau(x, t, u), t), t))-3*(diff(tau(x, t, u), u))*f(u), diff(diff(xi(x, t, u), x), x)-2*(diff(diff(phi(x, t, u), u), x))-(diff(diff(xi(x, t, u), t), t))-f(u)*(diff(xi(x, t, u), u)), -(diff(diff(phi(x, t, u), x), x))+diff(diff(phi(x, t, u), t), t)-phi(x, t, u)*(diff(f(u), u))+(diff(phi(x, t, u), u))*f(u)-2*(diff(tau(x, t, u), t))*f(u), diff(diff(tau(x, t, u), u), u), diff(diff(xi(x, t, u), u), u), diff(tau(x, t, u), u), diff(xi(x, t, u), u)}
for EQ in sort([op(DetSys)], length) do EQ = 0 end do:
Download [1117]_Symmetries_determination.mw
USB and or RS232 porting from inside maple console. Title explains what i need, or how to port an externally built java app into the maple console, either which will engine my dispatch tonight
Hello everybody!
I have a PDE with initial and boundary conditions. I want to plot its solution by taking "t" as x axis. I have seen the documentation. It only has the space variable on x axis. Please show me a way to achieve what I intend.
here is the file pdsolve.mw
The value of x can be chosen as 0.16 or 0.21
I wish to define a function which is the derivative of another function.
> f:=(x)->x^2:
> g:=(x)->diff(f(x),x):
> g(x);
2 x
> f(2);
4
> g(2);
Error, (in g) invalid input: diff received 2, which is not valid for its 2nd argument
I cannot find a way in which I can define the function g, using the functional operator, so that I can actually evaluate g(x).
How can I do this?
i think i might have asked this before for another thing if so im sorry but anyway i think its @ or something, i would like to plot the final output here indexed against th
NrANGE := (rand(0 .. 20))()
Š := {}
Y := proc (X) local N, S1, Š; if X <> `union`(X, S1[N]) then N := (rand(1 .. NrANGE))(); S1[N] := {K[1](N+1), K[1](N)}; Š := `union`(X, S1[N]) else  end if end proc
NrANGE := (rand(0 .. 20))(); nops(Y(Y(Y(Y({}))))); nops(Y(Y(Y({})))); nops(Y(Y({}))); nops(Y({}))
Download mapleprimes90916.mw
e number of iterations of Y conducted besides the original performed on the empty set
I am trying to solve a PDE using pdsolve-numeric. I am getting an error related to boundary conditions.
Please see the follwing worksheet and suggest me some solutions
pdsolve.mw
hi every one, i want to get derivative with sacalar function psi, first time ordinary derivative and second time covariant derivative , how should i write that ?!
I would like to use the angle symbol to represent polar numbers (phasor notation for electrical engineering. In other words, I would like to enter 10<30 instead of polar(10, pi/6). Also, I would like the results displayed with the angle notation.  Is this possible in Maple. In the "other package" by PTC this is trivial. Even on a TI graphing calucator it is trivial. Someone please tell me it is possible in Maple.
For computation, Maple is great. For presentation, there is a lot to be desired.
First 1107 1108 1109 1110 1111 1112 1113 Last Page 1109 of 2459
