In the post :
http://www.mapleprimes.com/questions/209721-Simplification-Of-Trigonometric-Expressions
you have help me to build a procedure so as to simplify trigonometric expressions of the following form, that is to say where each trigonometric expression is in factor with a term :
x0(t)+sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))*xb[1]-sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))*zb[1]-sin(alpha0(t))*cos(beta0(t))*yb[1]+cos(alpha0(t))*sin(gamma0(t))*zb[1]+cos(alpha0(t))*cos(gamma0(t))*xb[1]-l2[1]*(sin(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))-cos(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))+sin(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))+cos(psi[1](t))*cos(alpha0(t))*sin(gamma0(t)))-l3[1]*(sin(theta[1](t))*sin(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))+sin(theta[1](t))*cos(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))+cos(theta[1](t))*sin(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))-cos(theta[1](t))*cos(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))-sin(theta[1](t))*sin(psi[1](t))*cos(alpha0(t))*sin(gamma0(t))+sin(theta[1](t))*cos(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))+cos(theta[1](t))*sin(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))+cos(theta[1](t))*cos(psi[1](t))*cos(alpha0(t))*sin(gamma0(t)))-xp[1](t) = 0
From a mechanical point of view, this form of equations comes from the constraint equations obtained with a vectorial closure.
Now I would like to silmplify the constraint equations which come form angular closure.
The equations are in the form :
sin(gamma0(t))*cos(beta0(t)) = -(sin(psi[1](t))*cos(theta[1](t))*cos(gamma[1](t))+sin(psi[1](t))*sin(theta[1](t))*sin(gamma[1](t))-cos(theta[1](t))*cos(psi[1](t))*sin(gamma[1](t))+cos(psi[1](t))*sin(theta[1](t))*cos(gamma[1](t)))*cos(beta[1](t))
i try to treat the right side with the following code :
applyrule([
cos(u::anything)*cos(v::anything)-sin(u::anything)*sin(v::anything)=cos(u+v),
cos(u::anything)*sin (v::anything)+sin(u::anything)*cos(v::anything)=sin(u+v),
sin(u::anything)*sin(v::anything)-cos(u::anything)*cos(v::anything)=-cos(u+v),
-sin(v::anything)*cos(u::anything)-sin(u::anything)*cos(v::anything)=-sin(u+v)], simplify(-(sin(psi[1](t))*cos(theta[1](t))*cos(gamma[1](t))+sin(psi[1](t))*sin(theta[1](t))*sin(gamma[1](t))-cos(theta[1](t))*cos(psi[1](t))*sin(gamma[1](t))+cos(psi[1](t))*sin(theta[1](t))*cos(gamma[1](t)))*cos(beta[1](t)), size))
The result is :
(-sin(theta[1](t)+psi[1](t))*cos(gamma[1](t))+sin(gamma[1](t))*cos(theta[1](t)+psi[1](t)))*cos(beta[1](t))
It seems that the result is not simplified enough. I would like to obtain this expression :
cos(beta[1](t))*sin(gamma[1](t)-theta[1](t)-psi[1](t))
Have you a idea why the simplification is not conducted once more ? Do you have ideas so as to simplify the equation so as to obtain the result mentioned ?
Thanks a lot for your help
Dear All
How can we collect coefficient wrt certain differential ration in an expression?
See for detail:
with(PDEtools):
u := a[0]+a[1]*(diff(phi(xi), xi))/phi(xi)
-k*(diff(u, `$`(xi, 2)))+alpha*(diff(u, `$`(xi, 3)))
-k*(a[1]*(diff(diff(diff(phi(xi), xi), xi), xi))/phi(xi)-3*a[1]*(diff(diff(phi(xi), xi), xi))*(diff(phi(xi), xi))/phi(xi)^2+2*a[1]*(diff(phi(xi), xi))^3/phi(xi)^3)+alpha*(a[1]*(diff(diff(diff(diff(phi(xi), xi), xi), xi), xi))/phi(xi)-4*a[1]*(diff(diff(diff(phi(xi), xi), xi), xi))*(diff(phi(xi), xi))/phi(xi)^2+12*a[1]*(diff(diff(phi(xi), xi), xi))*(diff(phi(xi), xi))^2/phi(xi)^3-3*a[1]*(diff(diff(phi(xi), xi), xi))^2/phi(xi)^2-6*a[1]*(diff(phi(xi), xi))^4/phi(xi)^4)
expand(dsubs(diff(phi(xi), `$`(xi, 2)) = -lambda*(diff(phi(xi), xi))-mu*phi(xi), -k*(a[1]*(diff(diff(diff(phi(xi), xi), xi), xi))/phi(xi)-3*a[1]*(diff(diff(phi(xi), xi), xi))*(diff(phi(xi), xi))/phi(xi)^2+2*a[1]*(diff(phi(xi), xi))^3/phi(xi)^3)+alpha*(a[1]*(diff(diff(diff(diff(phi(xi), xi), xi), xi), xi))/phi(xi)-4*a[1]*(diff(diff(diff(phi(xi), xi), xi), xi))*(diff(phi(xi), xi))/phi(xi)^2+12*a[1]*(diff(diff(phi(xi), xi), xi))*(diff(phi(xi), xi))^2/phi(xi)^3-3*a[1]*(diff(diff(phi(xi), xi), xi))^2/phi(xi)^2-6*a[1]*(diff(phi(xi), xi))^4/phi(xi)^4)))
-a[1]*(diff(phi(xi), xi))*alpha*lambda^3/phi(xi)-a[1]*alpha*lambda^2*mu-7*a[1]*(diff(phi(xi), xi))^2*alpha*lambda^2/phi(xi)^2-8*a[1]*(diff(phi(xi), xi))*alpha*lambda*mu/phi(xi)-a[1]*(diff(phi(xi), xi))*k*lambda^2/phi(xi)-2*a[1]*alpha*mu^2-a[1]*k*lambda*mu-12*a[1]*(diff(phi(xi), xi))^3*alpha*lambda/phi(xi)^3-8*a[1]*(diff(phi(xi), xi))^2*alpha*mu/phi(xi)^2-3*a[1]*(diff(phi(xi), xi))^2*k*lambda/phi(xi)^2-2*a[1]*(diff(phi(xi), xi))*k*mu/phi(xi)-6*a[1]*(diff(phi(xi), xi))^4*alpha/phi(xi)^4-2*a[1]*(diff(phi(xi), xi))^3*k/phi(xi)^3
How ca extract coefficients of fraction (diff(phi(xi), xi))/phi(xi) in (3) ????
Download Coefficients_of_Fractions.mw
Dear All
In student numerical package, for in case of Secant method, how can we force Maple to print procedure and result of every iteration like we do in calculations by hand??
It gives direct output like:
with(Student[NumericalAnalysis]):
f := x^3-7*x^2+14*x-6
x^3-7*x^2+14*x-6
Secant(f, x = [2.7, 3.2], tolerance = 10^(-2))
3.005775850
Secant(f, x = [2.7, 3.2], tolerance = 10^(-2), output = sequence)
2.7, 3.2, 3.100884956, 2.858406793, 3.026267866, 3.005775850
What is we want print actual procedure that carry out calculations in step (3) ?
*What if, **want to
Download Secant_Method.mw
So have to calculate frequency response of RLC-circuit
Long story short - I can't get how to solve something like this
solve(abs(I+x) = 1)
Obv - the answer is 0 or -I, but i get 1-I, -1-I instead
In a post of April 15, 2013 by Kitonum, the procedure named Picture accepts a list of polygon segments, creates a plot of these as a 2D polygon's boundaries and fills the polygon with a color.
The code below attempts to modify Picture to produce a 3D filled polygon in a plane parallel to the xy plane.
When invoked by the code below the procedure, the filling color conforms to the straight line boundaries but overflows the curved, parabolic boundary. How can this be corrected?
Picture:=proc(L, C, N::posint:=100, Boundary::list:=[linestyle=1])
 local i, var, var1, var2,e, e1, e2,e3, P, h ;
 global Q,Border;
 for i to nops(L) do
#` set P`[i] = list of points for each segment.
#` for a segment defined as a list of points, P[i] = the segment's definition`
#` for a curve definition, approximate it with a list of [x,y] points of its function evaluated at N even intervals in its
# range`
  if type(L[i],listlist(algebraic))  then P[i]:=op(L[i]);   else
  #` for curve def'n, set var = def'n and h= `(variable range)/(2)
  var:=lhs(L[i,2]);  var1:=lhs(rhs(L[i,2]));  var2:= rhs(rhs(L[i,2])); h:=(var2-var1)/(N);
  #` for function def'n, set e=function`
 if type(L[i,1], algebraic) then  e:=L[i,1];
  #` for polar function r=f(t) create N values of the [cos*r,sin*r] i.e. the equivalent [x,y] values for r valued at N even
  # divisions of its range`
 if nops(L[i])=3 then P[i]:=seq(subs(var=var1+h*i,[e*cos(var), e*sin(var)]), i=0..N);  else
    #` for non-polar function y=f(x) create N values of [x,y] for x values at N even divisions of its range`
 P[i]:=seq([var1+h*i, subs(var=var1+h*i,e)], i=0..N)  fi;  else
 #` for parametric function [f`(t),g(t)] create N values of [f(t),g(t)] for t values at N even divisions of its range.
     e1:=L[i,1,1];  e2:=L[i,1,2];
#` P`[i]:=seq(subs(var=var1+i*h,[e1, e2]), i=0..N):
 P[i]:=seq([subs(var=var1+i*h,e1), subs(var=var1+i*h,e2),0], i=0..N) fi; fi; od;  #`  MODIFIED FOR 3 D `[f(t), g(t), 0]
  Q:=[seq(P[i], i=1..nops(L))];
 Border:=plottools[curve]([op(Q), Q[1]],  op(Boundary));
     #` the shaded figure is a polygon whose vertices are Q, whose interior color is C`
 #` return a list of the polygon and its border`
   [plottools[polygon](Q, C),  Border];
L := [[[0, 0, 0], [0, 1, 0]], [[x, x^2+1, 0], x = 0 .. 2], [[2, 5, 0], [2, 2, 0]], [[x, x, 0], x = 2 .. 0]]:
plots[display](Picture(L, color = yellow), axes = normal, scaling = constrained)
I would like to extract from a equation only the list of variables depending of time.
eq:= x0(t)+sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))*xb[1]-sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))*zb[1]-sin(alpha0(t))*cos(beta0(t))*yb[1]+cos(alpha0(t))*sin(gamma0(t))*zb[1]+cos(alpha0(t))*cos(gamma0(t))*xb[1]-l2[1]*(sin(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))-cos(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))+sin(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))+cos(psi[1](t))*cos(alpha0(t))*sin(gamma0(t)))-l3[1]*(sin(theta[1](t))*sin(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))+sin(theta[1](t))*cos(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))+cos(theta[1](t))*sin(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))-cos(theta[1](t))*cos(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))-sin(theta[1](t))*sin(psi[1](t))*cos(alpha0(t))*sin(gamma0(t))+sin(theta[1](t))*cos(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))+cos(theta[1](t))*sin(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))+cos(theta[1](t))*cos(psi[1](t))*cos(alpha0(t))*sin(gamma0(t)))-xp[1](t) = 0;
I think the indets function should help be.
indets(lhs(eq)-rhs(eq), function(t))
The last argument of the indets is wrong but should enable to explain my need.
I have this list :
T:=[alpha(t),beta(t)]
I would like to create this list automatically:
Tmod:=[alpha_,beta_]
In other words, how can I remove the 3 characters "(t)" and replace it by "_"
Do you have ideas to do so ?
I tried to solve a system of two equations using fsolve in Maple, however Maple didn't return any result (yet there is the result of that equation's system):
Maple is returning the command if there are no roots but that isn't my case.
How can I obtain the result in Maple?
worksheet.mw
solution of system of differential equations
is {a(t) = 1, b(t) = exp(t), c(t) = 0}
1 = exp(t), since t = 0, is characteristic equation = (y-0)?
0 = exp(t), how to find this characteristic equation when division is zero?
exp(t) = exp(t), is characteristic equation = (y-t)?
after solved,
diff(a(t), t) = diff(a(t), t)
diff(b(t), t) = 0
diff(c(t), t) = -b(t)/c(t)
there is a diff(a(t), t) term
how to plot this kind of system?
can diff(a(t), t) be ignore so that only consider two equations, diff(b(t),t) and diff(c(t),t) ?
if so, i use below to plot, it can not show the arrow clearing , i can only see arrow near origin, but not far point
fieldplot([0, y/x], x = -2 .. 2, y = -2 .. 2);
fieldplot([0, y/x], x = -2 .. 2, y = -2 .. 2, arrows = SLIM,grid = [1, 1]);
fieldplot([0, y/x], x = -10 .. 10, y = -10 .. 10);
 about how to calculate vector field of system of 3 differential equations which in terms of a(t), b(t), c(t) , diff(a(t),t), diff(b(t),t), diff(c(t),t)?
is the only method is the express diff(a(t),t), diff(b(t),t), diff(c(t),t) in terms of a(t), b(t), c(t) ?
for example
<diff(a(t),t), diff(b(t),t), diff(c(t),t)>
if result is
diff(a(t),t) = a(t)*b(t)
diff(b(t),t) =b(t)*c(t)
diff(c(t),t) =c(t)*a(t)
<a(t)*b(t), b(t)*c(t), c(t)*a(t)>
then
is it the vector field <a*b, b*c, c*a> ?
When I put maximize(cos(t)), everything is fine.
When I put maximize(cos(Pi)), everything is fine.
When I put maximize(cos(t*Pi)), it says invalid limiting point??? What went wrong?
Suppose I have a function like this: f=cos(2t/m)+cos(2(t+5)/m).
Now for each fixed m, we get the maximum value of f. Then I want to build a plot where x-axis is m and y-axis is f, how could I do that? Please help!
I want to solve a optimization problem with maple/maplesim.
A car has to move a defined distance on a plane, straight road in a defined time. Given is the mass of the car, the maximum force to accelerate the car, the distance and the time. The rolling resistance and the drag force should be considered. At start-point speed v = 0m/s and also at the end-point speed should be v= 0m/s.
So there are the following model parameters:
mass                            m = 2000kg
distance                        d  = 1000m
time                              t_max = 120s
                                    v_0 = 0m/s
                                    v_d = 0m/s
accelerating force           -1m/s2 <= F_acc/m <= 1m/s2
resistance to rolling        F_rol = C + A*v2                      C and A are later defined
resulting force at mass   F_res = F_acc - F_rol
The energy consumption  integral F_acc(s) ds (from 0 to d) should be minimized and I want to print the graph of F_acc(s)
How can or can Maple help me solving this optimization problem?
Can we get it in MapleSim, not in exactly this form, but in substance? (Not in Maple)
The line of intersection of surfaces:
(x1-0.5) ^ 4 + x2 ^ 4 + x 3 ^ 4-1. ^ 2 = 0.;
x1 ^ 2 + (x2-0.25) ^ 2 + x3 ^ 2-1. ^ 2 = 0.;
(Red) rotates about an axis oX3. During rotation, the line intersects with the fixed sphere ((0., 1.5, 0 .5); R = 1.725). One of the points of intersection is drawn in green. Green Dot and the center of the sphere connected to the blue segment.  In the sphere  of  fixed  trajectory of  the green point.
In other words, the geometric model  3d  cam mechanism and its kinematics.
First 1187 1188 1189 1190 1191 1192 1193 Last Page 1189 of 2459
