I've this equation ,what is displacement,
U := sum(C[i]*lambda[i]*h^2*M*(C[13]+C[55])*exp(Z*lambda[i]*M)*cos(M*x)/C[11], i = 1 .. 4);
 But when I used the data ,I do not get the right result
the datas are
h := .25;
M := Pi/L; L := 1;
E[3] := 1; E[1] := 40; E[2] := 1;
V[13] := .25; V[31] := .25; V[12] := .25; V[23] := .25; V[32] := .25; V[21] := .25;
G[44] := .2; G[55] := .2; G[66] := .2;
G[13] := .5;
C[55] := G[13];
Omega := -2*V[13]*V[21]*V[32]-V[12]*V[21]-V[13]*V[31]-V[23]*V[32]+1;
C[11] := (-V[23]*V[32]+1)*E[1]/Omega;
C[12] := (V[13]*V[32]+V[12])*E[2]/Omega;
C[33] := (1-V[12]*V[12])*E[3]/Omega;
C[1] := -.2596702449; C[2] := -2.411545729; C[3] := -0.6051254981e-1; C[4] := .4085627399;
lambda[1] := .6891428810; lambda[2] := -.6891428810; lambda[3] := 9.177422410; lambda[4] := -9.177422410;
could you help me plase
I'm trying to plot a piecewise function whose return value has units, but I get an error saying that it found a "name" (i.e., the unit symbol).
Example:
> f := t -> 2*t;
> fp := piecewise(f(tt) <= 4, 1*Unit(W), f(tt) > 4 and f(tt) <= 8, 2*Unit(W), f(tt) > 8, 3*Unit(W));
> plot(fp, tt = 0..10);
I've tried using the option useunits, but no success. Any help will be appreciated.
Limitation of Maple spreadsheet is only 100 x 52
I don't know why there's a limitation on the size but there's no way of increasing it either.  Is there?
Just to be sure that some outside operation wouldn't nudge the spreadsheet size I tried
with(Spread):
a:=CreateSpreadsheet():
b:=Matrix(100,100):
SetMatrix(a,b)
                           Error, (in Spread:-SetMatrix) spreadsheets cannot exceed 52 columns
So unfortunately until the feature gets built into Maple I don't believe there is a workaround.
Hello.
When I click to start simulation button maple start counting but after that don't open visualization. When I open visualization manually, there aren't results of simulation. Program don´t show any error. It does not work with my models and examples to. Thanks for your help.
I read research paper about elasticity, and I don't not how can get the results for displacment ant shaer stress,, could you help me please.
please help me
Kind Regards
I have a matrix A and a matrix B defined as B:=A. When an entry of B is changed in my Maple code, the matrix A is also changed.
A := Matrix([1, 1]):
B := A:
B[1, 1] := 2:
print(A):
The result is
[2,1] but as you see, I did not change the entries of A during the code.
This never happen for numbers.
Please help me.
confused in matrix substitution
http://tinypic.com/r/5a048l/9
I have a multivariate polynomial in x and y. How can I firstly collect the terms with respect to the powers of x and y and then simplifying their coefficients.
with(RealDomain):
A := Matrix(5, 5, {(1, 1) = 0, (1, 2) = 1, (1, 3) = 1, (1, 4) = 1, (1, 5) = 1, (2, 1) = 1, (2, 2) = 0, (2, 3) = c__1, (2, 4) = y, (2, 5) = c__2, (3, 1) = 1, (3, 2) = c__1, (3, 3) = 0, (3, 4) = c__3, (3, 5) = x, (4, 1) = 1, (4, 2) = y, (4, 3) = c__3, (4, 4) = 0, (4, 5) = c__4, (5, 1) = 1, (5, 2) = c__2, (5, 3) = x, (5, 4) = c__4, (5, 5) = 0})
Matrix(%id = 4510803138)
B := Determinant(A)
-2*c__1^2*c__4+2*c__1*c__2*c__3+2*c__1*c__2*c__4-2*c__1*c__2*x+2*c__1*c__3*c__4-2*c__1*c__3*y-2*c__1*c__4^2+2*c__1*c__4*x+2*c__1*c__4*y+2*c__1*x*y-2*c__2^2*c__3-2*c__2*c__3^2+2*c__2*c__3*c__4+2*c__2*c__3*x+2*c__2*c__3*y-2*c__2*c__4*y+2*c__2*x*y-2*c__3*c__4*x+2*c__3*x*y+2*c__4*x*y-2*x^2*y-2*x*y^2
Download A.mw
hi.i encounter error in pdsole equations with unknown parameter(N)??
please help me for solve it....thanks alotmaple_prime.mw
Dear friend! Hope every thing going fine with you. I need the solution of the following inqulity (for what values of a[1], a[2] and a[3] the equity hold) and it simplist form.
3*a[1]*a[2]*a[3]-2*a[1]*a[2]-2*a[1]*a[3]-2*a[2]*a[3]+2*a[1]+2*a[2]+2*a[3]-1 <= 3*a[2]*a[1]*a[3]-((a[1]*a[2]*a[3]+1)/(a[2]*a[3]-a[3]+1)-1)*((a[1]*a[2]*a[3]+1)/(a[1]*a[3]-a[1]+1)-1)-((a[1]*a[2]*a[3]+1)/(a[2]*a[3]-a[3]+1)-1)*((a[1]*a[2]*a[3]+1)/(a[1]*a[2]-a[2]+1)-1)-((a[1]*a[2]*a[3]+1)/(a[1]*a[3]-a[1]+1)-1)*((a[1]*a[2]*a[3]+1)/(a[1]*a[2]-a[2]+1)-1)
I am waiting your quick response
Mob #: 0086-13001903838
Is it possible to assign both a value of zero to a variable and a unit? Maple seems to be ignoring the units when I do that.
For example:
a := 0atm
Becomes simply a := 0. My workaround so far is to declare a very small value, e.g.:
a := 1E-6atm
This keeps the units for the variable a. Note that 0 pressure isn't relevant here (the same happens for 0m).
Running Maple15 on a five year old lap top, complicated animations are taking up to 30 seconds as shown by debugopt(traceproc) followed by showstat.
Would a discrete video card e.g. Nvidia as opposed to an integrated video card significantly reduce these times or are such times primarily dependent on processor speed?
I have such problem:
I calculated rather complicated function, and i want to obtain the array or list of data with definite step.
For this purpose I used next expression:
Out:=[seq(t,F(t),t=0..tmax,step]
I need minimum 1000 points, but calculation for the 100 points requires about 300 second, for 1000 - it will be about 3000 seconds. It's too long for me.
How could I accelerate this process?
P.S.
Plotting of my function requires about 90 seconds for the entire range. So, this is very strange, thad converting to data list requres so much time.
Is there any webpage like Wolfram Library Archive but with Maple related resources? I've missed something or everything goes to mapleprimes?
I need to complete the definition of bcount so that bcount(n) returns the total number
of odd coefficients
n
k , 0 ≤ k ≤ n. For instance, the values of
n
k for n = 6, with odd values highlighted, are:
1, 6, 15, 20, 15, 6, 1,
bcount:=
proc(n::TYPE)
description "Count odd binomial coefficients.";
---MORE STUFF HERE---
end proc; # bcount
Any help appreciated
First 1230 1231 1232 1233 1234 1235 1236 Last Page 1232 of 2472
