This is an extremely common situation; either some moderator displaced or deleted the question, or the OP deleted himself (herself).
Whatever the reason, it's always extremely upsetting to be confronted with this situation, which shows how rude, to put it mildly, some people can be.
Initial question (this day, about 2 hours ago)
Comment
Should not  print("my matrix is ",A) at least print "my matrix is " even if A is not correctly filled/setup?
Notice that nothing shows on screen when using print (but lprint does)
Is this expected? If it makes any difference, I am using worksheet and this is my display options
21836
A:=Matrix(1,0);
print("My matrix is =",A);
lprint("My matrix is =",A);
"My matrix is =", Matrix(1,0,{},datatype = anything,storage = rectangular,order
= Fortran_order,shape = [])
Download why_print_empty_june_7_2024.mw
If I do    odetest(...,odeA) I get correct result. But if I do    odetest(...,odeB);  odetest(...,odeA);   now it gives wrong output for the odeA one.
Same exact code. It just depends on the call done before it.
Why would issuing a command before changes the output of odetest? It seems Maple remembers something from last call. But I have no idea how to fix this.
Is there a way to tell odetest not to remember or cache any results from last calls? i.e. Can I clear its remember table before calling odetest??
This is messing all my testing now since I get different result each time depending on which call was made before. I can't do restart before testing each ode, since this is done in a loop.  I just need a way to tell Maple to clear its internal cache so that each call to odetest is not affected by last call result.
Doing forget(odetest); before the call had no effect.
Reported to Maplesoft.
Worksheet below
#EXAMPLE 1
ode:=x*diff(y(x),x)^n=0;
sol:=dsolve(ode);
odetest(sol,ode);
x*(diff(y(x), x))^n = 0
y(x) = c__1
ode:=diff(y(x),x)^n=0;
sol:=dsolve(ode);
odetest(sol,ode);
y(x) = c__1
0^n
##EXAMPLE 1 repeated. Why now different result??
sol:=dsolve(ode);
odetest(sol,ode);
y(x) = c__1
x*0^n
Download why_different_result_from_odetest_june_6_2024.mw
Update
FYI, I got email from Maplesupport that Maple R&D group will look at this issue.
So hopefully this will be fixed in a future version of Maple.
I am not able to find a workaround but doing tracing I see that odetest does rememebr something from last call but have no idea to fix this myself.
I want to display W__LJ as I typed it, without Maple running the calculations resulting in the output here below:
'W__LJ = 0.75 + 0.98*((1.18/Gamma)^1.9 - (1.15/Gamma)^0.98)';
W__LJ = .75+1.342152577*(1/Gamma)^1.9-1.123854165*(1/Gamma)^.98
Download display_formula.mw
This is important as I will place such expression in a plot like this:
textplot([2,0.9,typeset('W__LJ=0.75+0.98((1.18/Gamma)^1.9-(1.15/Gamma)^0.98)')],'font'=["helvetica","roman",35])
and I need it in the original functional form, which is easier to interpret.
I can't figure this out. Same exact patmatch works in global worksheet. But fails inside a proc.
I am using same exact code. In proc, I am doing    a::anything where `a` is now local symbol ofcourse. In worksheet, it is global ofcourse. I make sure I clear `a` in worksheet each time also.
So why it pathmatch fail in the proc? I must be doing something wrong but do not see it.,
26148
a:='a':
stat:=0^n:
if patmatch(stat,0^a::anything) then
     0;
     stat;
  fi;
foo:=proc(stat)
  local a;
     0;
     stat;
  fi;
#why this does not return zero as expected?
foo(stat)
0^n
Here is screen shot in debugger showing patmatch failed inside the proc
Very strange. What do I need to change in the proc to make it work as in worksheet?
Download patmatch_in_proc.mw
Is the following valid result from odetest? is returns 0^n when 0 was expected.
Is this a bug or valid result? Maple solution is correct, so I expected 0 only not 0^n as result.
25748
`The "Physics Updates" version in the MapleCloud is 1756 and is the same as the version installed in this computer, created 2024, June 5, 19:39 hours Pacific Time.`
ode:=diff(y(x), x)^n = 0
sol:=dsolve(ode)
y(x) = c__1
odetest(sol,ode)
0^n
odetest(sol,ode) assuming n::real
0^n
odetest(sol,ode) assuming n>0
0^n
Download strange_odetest_result_june_6_2024.mw
Update
Until this bug is fixed, I added the following to my code which checks for odetest result. it looks for 0^anything and changes it to 0.
ode:=diff(y(x), x)^n= 0;
sol:=dsolve(ode);
stat:=odetest(sol,ode);
if patmatch(stat,0^a::anything) then 0; else stat; fi
gives    0
I found this problem when using odetest to check mysolution for this ode and was not getting 0 as expected,.
These two expressions are the same
e1:=-sqrt(-(exp(-2 + 2*x) - 2)*exp(-2 + 2*x))/(exp(-2 + 2*x) - 2);
e2:=1/sqrt(2*exp(-2*x)*exp(2) - 1);
Is there an automated way to simplify e1 to e2? Below are my attempts. The closest I got is
simplify(e1) assuming real;
But that still does not give same as e2. I can do it by "hand" as shown. But I like to find automated way since this is done in code without looking at expression. So I can't use the "hand" method there.
We can assume everything in real domain.
15244
plot([e1,e2],x=-3..3)
-(-(exp(-2+2*x)-2)*exp(-2+2*x))^(1/2)/(exp(-2+2*x)-2)
1/(2*exp(-2*x)*exp(2)-1)^(1/2)
simplify(e1,size);
simplify(e1,symbolic);
simplify(e1) assuming real; #closest but still no cigar
-I*exp(-1+x)/(exp(-2+2*x)-2)^(1/2)
exp(-1+x)/(-exp(-2+2*x)+2)^(1/2)
#can do it "by hand" by dividing upstairs and downstrais by numerator
A:=exp(-1 + x);
B:=-exp(-2 + 2*x) + 2;
e3:=1/sqrt( simplify(expand(B/A^2)))
exp(-1+x)
-exp(-2+2*x)+2
1/(-1+2*exp(2-2*x))^(1/2)
#verify
plot([e3,e2],x=-3..3)
Download simplification_june_6_2024.mw
I have two surfaces crossing the z=0 plane for some ranges of x and y values.
For the first surface, x=Gamma is bounded between 0 and 10 and y=rho between -1 and +1. For the second surface, x=Gamma_1 is bounded between 0 and 10 and y=Gamma_2 between 0 and 10 as well. I want to clearly identify (parametric):
  1. For which Gamma and rho ranges of values the first surface is positive (and for which negative)
  2. For which Gamma_1 and Gamma_2 ranges of values the second surface is positive (and for which negative)
Worksheet: sign_regions.mw (highlighted in yellow my two failed attempts)
How do I get the susset that contains unknowns on the rhs of the elements?
# I need this subset {a=1/sqrt(2+A), b=6*sqrt(4+N),  d=5*H}
C:={a=1/sqrt(2+A),b=6*sqrt(4+N) ,c=sqrt(7),d=5*H,,e=-12,f=-96}
{a = 1/(2+A)^(1/2), b = 6*(4+N)^(1/2), c = 7^(1/2), d = 5*H, e = -12, f = -96}
selectremove(has,indets(rhs~(C)),C)
{}, {A, H, K, N, 1/(2+A)^(1/2), (4+N)^(1/2)}
selectremove(has,lhs~(C)=indets(rhs~(C)),C)
() = (), {a, b, c, d, e} = {H, K, N, (4+N)^(1/2)}
Download 2024-06-05_Q_Select_Remove_indet_elements.mw
Hello, in a Maple script intended for Maple Learn I need to use a slider but I don't know how to get its value.
What should I do to get it?
I have a positive surface that I plot3d for bounded x- and y- value ranges. It reaches 1000 but it's mostly flat except almost at the edges of the x- and y-axes. Therefore, I inlcude view=[default,default,0..10] among the options of plot3d so that I can focus on the features of interest.
For coloring I use 'colorscheme'=["zgradient",["LightGray", "Gray", "Green"]]. However, this applies to the whole surface (up to 1000) and NOT exclusively to the viewed part as I would like to.
Question: how to scale the zgradient so that it only applies to my "view" portion?
Note that I don't want to do this by using the 'markers' options to readjust the color splits manually, as I don't know the exact proportion and I don't want to randomly play around with different triplets until I achieve a visually satisfying result...
We see that this ode (x + y(x))*(1+diff(y(x),x)) = 0  has 2 solutions, One when (x + y(x))=0 and one when (1+diff(y(x),x))=0. Maple gives 3 solutions. They are correct but why?
Also when changing (1+diff(y(x),x)) to (a+diff(y(x),x)) now it gives only two solution.
Why does this happen? Should it not just return 2 solutions in both cases? and more strange one
(x + y(x))^2 *(1+diff(y(x), x))=0; now it gives 4 solutions. But this is no different. We also have 2 solutions. One when (x + y(x))=0 and one when (1+diff(y(x), x))=0. This time the extra two solutions are complex.
17168
`The "Physics Updates" version in the MapleCloud is 1754 and is the same as the version installed in this computer, created 2024, June 3, 20:39 hours Pacific Time.`
ode:=(x + y(x))*(a+diff(y(x),x)) = 0;
dsolve(ode);
map(X->odetest(X,ode),[%])
(x+y(x))*(a+diff(y(x), x)) = 0
y(x) = -x, y(x) = -a*x+c__1
[0, 0]
ode:=(x + y(x))*(1+diff(y(x),x)) = 0;
dsolve(ode);
(x+y(x))*(1+diff(y(x), x)) = 0
y(x) = -x, y(x) = -x-c__1, y(x) = -x+c__1
[0, 0, 0]
ode:= (x + y(x))^2 *(1+diff(y(x), x))=0;
dsolve(ode);
(x+y(x))^2*(1+diff(y(x), x)) = 0
y(x) = -x, y(x) = -x+c__1, y(x) = -(1/2)*c__1-((1/2)*I)*3^(1/2)*c__1-x, y(x) = -(1/2)*c__1+((1/2)*I)*3^(1/2)*c__1-x
[0, 0, 0, 0]
Download why_extra_solution_from_dsolve_june_5_2024.mw
Any idea why this sometimes happens? odeadvisor says ode is quadrature but when asking it to solve it using quadrature sometimes it works and sometimes not.
Am I doing something wrong?
22020
Example 1 that does not work
ode:=diff(y(x),x)=-1;
DEtools:-odeadvisor(ode);
diff(y(x), x) = -1
[_quadrature]
sol:=dsolve(ode,y(x),['quadrature']);
"sol := "
Example 2 that works
ode:=diff(y(x),x)=x;
diff(y(x), x) = x
[_quadrature]
y(x) = (1/2)*x^2+c__1
Download sometimes_dsolve_works_on_quadrature_june_5_2024.mw
I have a data, how can I study this data using N-soft set : Normalized the data, membership function, analyse the risk, ..... compute the risk, interpret the results
Cancer_patient.xlsx
N_soft_set.mw
Thank you for your help
Maybe someone get the code working ?
with(VectorCalculus):
# Example 1: Vector Field and Visualization
V := [x, y, z]:
print("Vector Field V:", V):
fieldplot3d([V[1], V[2], V[3]], x = -2..2, y = -2..2, z = -2..2, arrows = slim, title = "Vector Field in 3D"):
# Example 2: Tangent Vector to a Curve
curve := [cos(t), sin(t), t]:
print("Curve:", curve):
tangent := diff(curve, t):
print("Tangent Vector:", tangent):
plot3d([cos(t), sin(t), t], t = 0..2*Pi, labels = [x, y, z], title = "Curve in 3D"):
# Example 3: Curvature of a Surface
u := 'u': v := 'v':
surface := [u, v, u^2 - v^2]:
print("Surface:", surface):
# Compute the first fundamental form
ru := [diff(surface[1], u), diff(surface[2], u), diff(surface[3], u)]:
rv := [diff(surface[1], v), diff(surface[2], v), diff(surface[3], v)]:
E := ru[1]^2 + ru[2]^2 + ru[3]^2:
F := ru[1]*rv[1] + ru[2]*rv[2] + ru[3]*rv[3]:
G := rv[1]^2 + rv[2]^2 + rv[3]^2:
firstFundamentalForm := Matrix([[E, F], [F, G]]):
print("First Fundamental Form:", firstFundamentalForm):
# Compute the second fundamental form
ruu := [diff(surface[1], u, u), diff(surface[2], u, u), diff(surface[3], u, u)]:
ruv := [diff(surface[1], u, v), diff(surface[2], u, v), diff(surface[3], u, v)]:
rvv := [diff(surface[1], v, v), diff(surface[2], v, v), diff(surface[3], v, v)]:
normal := CrossProduct(ru, rv):
normal := eval(normal / sqrt(normal[1]^2 + normal[2]^2 + normal[3]^2)):
L := ruu[1]*normal[1] + ruu[2]*normal[2] + ruu[3]*normal[3]:
M := ruv[1]*normal[1] + ruv[2]*normal[2] + ruv[3]*normal[3]:
N := rvv[1]*normal[1] + rvv[2]*normal[2] + rvv[3]*normal[3]:
secondFundamentalForm := Matrix([[L, M], [M, N]]):
print("Second Fundamental Form:", secondFundamentalForm):
# Compute the Christoffel symbols
# Ensure DifferentialGeometry package is loaded
with(DifferentialGeometry):
DGsetup([u, v], N):
Gamma := Christoffel(firstFundamentalForm):
print("Christoffel Symbols:", Gamma):
# Visualize the surface
plot3d([u, v, u^2 - v^2], u = -2..2, v = -2..2, labels = [u, v, z], title = "Saddle Surface in 3D"):
First 130 131 132 133 134 135 136 Last Page 132 of 2457
