I am a middle school teacher trying to program an app where a student will type in a linear equation in any form. They are to solve this for the variable Y and graph the line. I have most of this up and running, but I would like to include a step by step help system, where after entering the equation, the students can click on a button and it will display the 1st step to solve the equation. I am using the built-in function “LinearSolveSteps” in the Students [Basics] package. Every repeated click of the button would reveal the next step. I have this working to a point, but I don't seem to be able to add the next step into the math container without deleting the contents that are already in there. I have tried rebuilding the string by using the "+" but the + shows up in the equation and it is not on a new line. Any ideas would be appreciated. Thank you.
It seems a frequent issue that exported 3d plots are not shown as wished. I experience the same problem. Although I exported in the .eps format into a .tex latex-file the resulting .pdf-file shows a somewhat pixelated image of my 3d plot as if it was created in "Paint". Is there a solution for this in Maple13?
Take a 3d plot of some uneven surface in the xyz space and you want to have the surface colored according to local z-coordinates (e.g. a valley is blue, a peak is red with all rainbow colors inbetween). For such a color-coding one can in principal select the plot option "Color->Z (Hue)". What do you do if the valley and the peak are still more or less green colored? How can you force the valley and peak to have different colors?
I have this surface which I display with the following commands:
     Belt:=plots[surfdata](Surface,color=C,labels=["x","y","z"]):
     display({...,Belt});
It all works, and the surface has nice default rainbow colors, but when I choose Color->Z (Hue) everything turns to green. Also when I manually write in the first of the above lines "color=["Blue","Red"]" the surface turns all red. The ranges of the x and y axis are larger than the z axis by a factor of about 50. Might this be the problem? How can I adjust the color ranges for my small z axis?
I wqant to minimize a function that has som parameters (here number of parameters are two). how can i do that?
I have attache a picture from my target function. Could you please help me?
Tahnk you.
Let a be som expression like
a:=t^2
Now how do I define a function using a.
f:=t->a
doesnt work
I've got the following piecewise function :
(x^2+y^2)^(alpha).arcsin(y/x) if (x,y) are in [-pi/2,pi/2]
0, (x,y)=(0,0)
1. How do I plot this function taking the alpha variable and the piecewise construct into account?
2. How can I check for points of discontinuity, indifferentiability from the plot/function itself?
Hello everybody,
I'm an engineer and i want to solve the following ODE:
EJ*diff(w(x),x,x,x,x) - (Nr/2*(1+x)+Nl/2*(1-x))*diff(w(x),x,x) = q(x)
constants: EJ, Nr, Nl
Is it possible to solve this ODE in Maple? I tried dsolve with coeffs=rational but it doesn't work!
Thx!!!
I am attempting to maximize Planck's intesnity function for any given temperature T with respect to lambda. The function is as follows:
Iy = (2*h*c^2)/(lambda^5*(e^(hc/(lambda*k*T))-1))
My initial attempt was to simply take the derivative of this function with respect to labda, set it equal to zero, and then solve for lamda. Theoretically this should give me the value of lambda that maximizes the intesity with respect to the constants / values h, c, k, and T (where T is temperature).
However doing this in maple just leads to the result "warning, solutions may have been lost".
Does anyone know how I can go about maximizing this?
When I try and evaluate the minimize command the result is just echoed.
If I try Maples example function, they echo such as:
minimize(x^2+y^2-3*x+3*y+3);
         minimize(x^2 + y^2 - 3 x + 3 y + 3)
Any suggestions?
Hi everyone,
I am using the following code (by dr. Corless) to animate a Riemann surface:
B := 1.5;
u2 := r*cos(th); v2 := r*sin(th);
w1 := u1+I*v1; w2 := u2+I*v2;
z1 := evalc(w1^2); z2 := evalc(w2^2);
x1 := evalc(Re(z1)); x2 := evalc(Re(z2));
y1 := evalc(Im(z1)); y2 := evalc(Im(z2));
f1 := proc (theta) options operator, arrow; plot3d([-x1, -y1, v1], u1 = -6 .. 1, v1 = -B .. B, grid = [50, 50], orientation = [theta, 80], color = u1) end proc;
f2 := proc (theta) options operator, arrow; plot3d([-x2, -y2, v2], r = 1 .. 1, th = -Pi .. Pi, grid = [50, 50], orientation = [theta, 80], color = black) end proc;
display(seq([f1(10*k), f2(10*k)], k = -17 .. 18), insequence = true, axes = box, view = [-1 .. 1, -1 .. 1, -B .. B]);
f1 is the Riemann surface and f2 is the winding curve.
The animation works fine on the individual plots, i.e. when I do:
display(seq(f1(10*k), k = -17 .. 18), insequence = true, axes = box, view = [-1 .. 1, -1 .. 1, -B .. B]);
or
display(seq(f2(10*k), k = -17 .. 18), insequence = true, axes = box, view = [-1 .. 1, -1 .. 1, -B .. B]);
but with both f's (as in my modification)  the animation does not combine correctly the two plots and shows them separately. Is there any way I can combine the plots so that display produces a smooth animation with each rotated frame containing its winding curve?
Many thanks,
Yiannis
Hello there, could someone tell me how to input this differential equation?
d2x/dt2 - (3)dx/dt + 2x = 2t -3
x=2, t=0, dx/dt=4
So it looks like radians work.
Why does degrees fail and how do I get degrees work?
How do you guys like to access pi? Do you keep a symbol of it around in a random document to open?
http://i.imgur.com/07o1dyH.png
Let A(x , 2 , -1) ,B(0, y , 1) ,C(3 , 4 , -2) , AB=AC and ABC is isosceles right triangle. Find x and y ?
How would you insert a label-coordinate in this command:
textplot3d([subs(E[11]=0,x[11]),subs(E[11]=0,y[11]),subs(E[11]=0,z[11]),"Planet"]):
What is the command for filling the space between two circular spacecurves? Something like a Saturnian ring?
First 1351 1352 1353 1354 1355 1356 1357 Last Page 1353 of 2463
