f := x^2+y-z = 0;
originvarslist := convert(indets(f), list);
varslist := ListTools:-Rotate(convert(indets(f), list),1);
varslistm := [seq(cat(m,i),i=1..nops(varslist))];
meet difficulty in this, how to reassign to itself during the seq
f := seq(subs(originvarslist[i]=varslistm[i],f), i=1..nops(originvarslist));
f := seq(subs(varslistm[i]=varslist[i],f), i=1..nops(originvarslist));
It appears that email notifications have gone on Christmas vacation.
When will they be back?
Heaviside2.mw
I am a new user of Maple (Dec 2014).  I am trying to calculate an integral related
to mechanical loss.  Temperature is a variable in the problem (as is time), and if
I use a sinusoidal (sine or cosine) temperature-time relationship, I think all works fine.
A difficulty is that the experiments have two-hour hold times(i.e., 7200 seconds) (followed by 22 hours of sinusoidal temperature variation.)
The experiments run for several weeks or months.
I tried using Heaviside functions to model the hold times.(Constant temperature periods)
Now I am receiving errors such as " Error, (in tools/eval_foo/do) too many levels of recursion..."
Probably the Maple code is crude and/or sloppy. Most of the code is simply the setting of constants in the problem.
I will be grateful for suggestions and comments--the file is attached.  Thank you.  John B
T__2 := 291.4:
T__f := 342.7:
B__f := 1265.:
A__0 := 0.452e-10:
`a__σ` := 1.6072:
`b__σ` := 5.6072:
mu := proc (x) options operator, arrow; .212008+0.21666e-2*x end proc:
t__age := 1800.:
`σ__app` := 3.91:
T__0 := 303.15:
D__0 := proc (x) options operator, arrow; .103172+0.633333e-2*x end proc:
A__ex := B__f*T__f/(T__f-T__2)-`a__σ`*`σ__app`^2:
C__ex := B__f*T__f/(T__f-T__2)-`b__σ`*`σ__app`:
A__00 := A__0*exp(A__ex/T__0):
NumericEventHandler(invalid_operation = `Heaviside/EventHandler`(value_at_zero = 1)):
tm := proc (t) options operator, arrow; `mod`(t, 86400) end proc:(temperature cycle repeats every 24 hours = 86,400 seconds)
T3 := proc (x) options operator, arrow; (303.15+15.+15*sin((3/2)*Pi+2*Pi*(x-7200)/79200.))*(1-Heaviside(x)+Heaviside(x-7200)) end proc:
F3 := proc (x) options operator, arrow; (Heaviside(x)-Heaviside(x-7200))*303.15 end proc:
ftemp := proc (i) options operator, arrow; evalf(T3(tm(i))+F3(tm(i))) end proc:
C := proc (x) options operator, arrow; A__0*exp(C__ex/ftemp(x)) end proc:
`τ__0` := proc (x) options operator, arrow; sqrt(A__00^2*(t__age^mu(ftemp(x)))^2+C(x)^2*x^(2*mu(ftemp(x)))) end proc:
f__0 := proc (z) options operator, arrow; int(1/`τ__0`(x), x = 0 .. z) end proc:
g__0 := proc (y) options operator, arrow; D__0(ftemp(y))*exp(f__0(y)^.333333) end proc:
ftim := proc (i) options operator, arrow; 1800.*i end proc:
`τ__0`(20);
35860.86195
f__0(20)
Download Heaviside2.mwHeaviside2.mw
Sorry for basic question, Maple newbie here and I could not find answer using google.
I understand in Maple one uses the back quote key (or rather the apostrophe, 0X27) to prevent one time evaluation of expression. Hence when writing
'sin(Pi)'; #this remain sin(Pi)
%; # now we get 0
But when I tried it on fraction, it did not hold it:
'16/4'; #maple replied with 4
This might indicate that the front end parser did this simplification before the main evaluator got hold of it, so it was too late?
Either way, how would one make Maple return 16/4 when the input is '16/4'?
I am trying to solve the following differential equation numerically using dsolve,
y * abs (y''') = -1
y(0) =1, y'(0) = 0, y''(0)=0
it works fine when tthe absolute function is not there, i.e. yy''' = -1.
Do you have any suggestion?
I have solved ODE's with either i.c. or b.c. (mechanics stuff) where the results were in terms of expressions, not functions.  I could plot these expressions, substitute values in for parameters, etc.
Then I thought that the real way to solve an ODE or system of ODE's was to define functions.  I wanted this to be in three levels: the solutions in generality, the solutions with i.c./m.c. applied, and then further with the parameter values defined.
So far, no joy.  Lots of confusion--input eqns as sequence, list, set?  I looked on the Maple help page, thought I was doing things right. I even tried out "union" for the ode's and the ic's.
The code is below; statement (11) produces an error. Yes, I am using Maple 18, even though the file says Maple 15.  I'd like to solve the 4-ODE system at the three levels listed above, and then (if possible), plot the result! Am I asking too much?  Should I be using MapleSim or some other product instead?
Thanks for any and all help!
robert w.
assume(m1 > 0);
eqn1 := diff(z1(t), t) = z2(t);
eqn2 := diff(z2(t), t) = -(k1+k2)*z1(t)/m1-(c1+c2)*z2(t)/m1+k2*z3(t)/m1+c2*z4(t)/m1;
eqn3 := diff(z3(t), t) = z4(t);
eqn4 := diff(z4(t), t) = k2*z1(t)/m2+c2*z2(t)/m2-k2*z3(t)/m2-c2*z4(t)/m2;
eqns := eqn1, eqn2, eqn3, eqn4;
diff(z1(t), t) = z2(t), diff(z2(t), t) = -(k1+k2)*z1(t)/m1-(c1+c2)*z2(t)/m1+k2*z3(t)/m1+c2*z4(t)/m1, diff(z3(t), t) = z4(t), diff(z4(t), t) = k2*z1(t)/m2+c2*z2(t)/m2-k2*z3(t)/m2-c2*z4(t)/m2
var := z1(t), z2(t), z3(t), z4(t);
ic1 := z1(0) = -2;
z1(0) = -2
ic2 := z2(0) = 0;
z2(0) = 0
ic3 := z3(0) = 1;
z3(0) = 1
ic4 := z4(0) = 0;
z4(0) = 0
ics := ic1, ic2, ic3, ic4;
z1(0) = -2, z2(0) = 0, z3(0) = 1, z4(0) = 0
dsolve(`union`(eqns, ics), var)
Error, invalid input: `union` received diff(z1(t), t) = z2(t), which is not valid for its 1st argument
var;
data:=(m1=1,m2=2,m3=1,c1=0,c2=0,c3=0,k1=5,k2=2,k3=2);
m1 = 1, m2 = 2, m3 = 1, c1 = 0, c2 = 0, c3 = 0, k1 = 5, k2 = 2, k3 = 2
eqnsev := subs(data, eqns);
diff(z4(t), t) = z1(t)-z3(t)
(14)
Download mae340_state_space_4-ode_system.mw
how to shift shift(1,[x,y,z]) = [y,z,x]
shift(2,[x,y,z]) = [z,x,y]
shift(3,[x,y,z]) = [x,y,z]
Hello Maple
I am preparing for an examination in Calculus, but my worksheet in Maple 18 doesn't cooperate.
A lot of my studypartners use Maple 16 and they have no problems.
I meet the following error:
- Error, (in solve) invalid input: hastype expects 2 arguments, but received 1
I'm totally sure, that I'm typing correctly, because I write just the same as my studypartners.
So is it an error, which only is seen in Maple 18 and can I do anything to solve the problem?
Kind regards
Anders Kristensen
PS: I can't figure out how to add a picture
I solve the problem on computational geometry: "A cube of side one contains two cubes of sides a and b having non-overlapping interiors. How to prove the inequality a+b≤1?" To this end I use the DirectSearch package , namely,
Here are some comments to it. The cube of side a is centered at (x_1,y_1,z_1) and rotated by the angles phi_1, psi_1, theta_1 (see http://uk.wikipedia.org/wiki/%D0%95%D0%B9%D0%BB%D0%B5%D1%80%D0%BE%D0%B2%D1%96_%D0%BA%D1%83%D1%82%D0%B8 ) and the cube of side b is centered at (x_2,y_2,z_2) and rotated by the angles phi_2, psi_2, theta_2. The procedure
calculates the distance between these cubes, for example,
st := time(); dist(.2, .9, .2, .2, .2, .7, .7, .7, 0, 0, 0, 0, 0, 0); time()-st;
[HFloat(5.453016092898238e-11), [s1 = HFloat(0.2646161775314957),
  s2 = HFloat(0.2828503247068887),
  s3 = HFloat(0.29444713116943216),
  t1 = HFloat(0.2646161774916062),
  t2 = HFloat(0.28285032471998384),
  t3 = HFloat(0.2944471311346344)], 2527]
                            191.133
Unfortunately, my code (which is syntactically correct) is spinning on my wondercomp during 10 hours without any output. I don't understand it at all. Your advices are welcome.
twocubes.mw
Hi there,
I have an ODE system which apparently needs some initial conditions to have its vector field plotted.
I am giving Maple's dfieldplot function the following arguments:
dfieldplot([de1, de2], [A(t), G(t)], t = 0..1, [A(0) = 25, G(0) = 0], A = 0..900, G = 0..200)
But Maple yields an error that reads:
Error, (in DEtools%2Fdfieldplot) invalid use of initial points or option - see phaseportrait
I would say that the initial conditions are correctly stated, according to the documentation of the function.
This is the attempt: MaplePrimes_Malaria_infection_cont.mw
Any ideas on what's missing?
jon
Hi there,
I would like to have the Jacobian matrix of an ODE system evaluated, and their eigenvalues computed, at the steady states of the system.
I know how to get the Jacobian matrix evaluated and the eigenvalues computed on an individual basis, setting manually each steady state as the argument of the matrix.
However, I would like to have it in a loop, so that the loop manages all steady states, that is:
steadyStates:= solve(mySystem); # would yield a set of pairs/lists
for each steadyState
m:=Jacobian(steadyStateN); # evaluate the Jacobian matrix
ev:= eigenvals(m); # compute the eigenvalues and save them to another variable/array and print them
end for:
First, I am not to find a way to loop over my steadyStates.
Attached is an example where the Jacobian matrix and eigenvalues are computed individually, where the steady states have been hard-coded once they have been computed: MaplePrimes_Predator_prey_model_Jacobian.mw
Any ideas on how to do this?
jon
Hi there,
I would like to compute and display the nullclines of a set of ordinary differential equations.
AFAIK, I can compute the nullclines in Maple by defining the equations and solving the system
e.g.:
# Define the equations
eq1 := u(t)*(1-u(t)/kappa)-u(t)*v(t) = 0;
eq2 := g*(u(t)-1)*v(t) = 0;
# Solve the system (i.e. compute the nullclines)
sol := solve({eq1, eq2}, {u(t), v(t)});
However, I am not quite able to imagine how to display them over a dfieldplot or a phaseportrait.
Attached is an example with some differential equations, and their vector field and trajectories: MaplePrimes_Predator_prey_model_nullclines.mw.
It can be use to illustrate how to (compute and) display the nullclines.
Thank you,
jon
Hi there,
I would like to have an operator (in this case, the natural logarithm) applied to a list/array of points defined as:
ydata := [0.572594976618e-1, 0.327865007249e-1, 0.280821589546e-1, 0.114365745192e-1, 0.578537931608e-2, 0.139154661062e-2, 0.641467839994e-3, 0.18013801847e-3];
How can I apply Maple's ln() operator to the whole array (i.e. avoid to apply it to ydata [1], ydata [2], etc.)?
Thank you,
jon
I have a 30-dimensional, semisimple Lie algebra which I would like to know the decomposition of (and decomposable it must certainly be, as no simple Lie algebra has dimension 30). The function DifferentialGeometry:-LieAlgebras:-Decompose is, I guess, the proper command to use. Unfortunately, on my computer, an Intel Core i3 with 4 GB RAM, it seems to drag on forever. Therefore, I have the following two questions:
1.) Is it possible to gain some useful insight into any progress, while the calculation goes on? To have some status bar, so to speak? The amount of information should not be overwhelming, however.
2.) Does there exist some smarter way of doing a decomposition? Perhaps just a partial one?
Aslam-u-Alikum. Hope you will be fine. I facing the problem of the last line to the attached program. I need the values of lambda in decimal.
Help.mw
PhD (Scholar)
Department of Mathematics
First 1367 1368 1369 1370 1371 1372 1373 Last Page 1369 of 2463
