I have some triangles ABC with vertices
1) A(-13,-5,5), B(-5,11,-11), C(-3,-9,15) has centre of out circle is (3, 3, 3), orthocentre (-27, -9, 3) and centroid (-7, -1, -3).
2) A(-6,6,-1), B(-5,-1,-3), C(2,10,7) has centre of out circle is (1, 2, 3), orthocentre (-11, 11, -3) and centroid (-3, 5, 1).
How can I write a program to find a triangle with integer coordinates of vertices, centroid, orthocenter and center of the triangle in geometry 3D?
Does anyone know how to incorporate the tetrad with the directional derivative? I tried using the SumOverIndices, but get crazy results. I know Maple can find the answer easily because I have done the same thing by hand. What am I missing?
The directional derivative should take the form f,1 = eaμ df/dxμ . The answer is Y,1 = dY/dζ – Ybar dY/du.  I obviously do not get this result.
restart; with(Physics); with(Tetrads)
0, "%1 is not a command in the %2 package", Tetrads, Physics
`#msup(mi("ds",mathcolor = "#af00af"),mn("2",mathcolor = "#af00af"))` := Physics:-`*`(Physics:-`*`(2, dzeta), dzetabar)+Physics:-`*`(Physics:-`*`(2, du), dv)+Physics:-`*`(Physics:-`*`(2, H(zetabar, zeta, v, u)), (du+Physics:-`*`(Ybar(zetabar, zeta, v, u), dzeta)+Physics:-`*`(Y(zetabar, zeta, v, u), dzetabar)-Physics:-`*`(Physics:-`*`(Y(zetabar, zeta, v, u), Ybar(zetabar, zeta, v, u)), dv))^2)
2*dzeta*dzetabar+2*du*dv+2*H(zetabar, zeta, v, u)*(du+Ybar(zetabar, zeta, v, u)*dzeta+Y(zetabar, zeta, v, u)*dzetabar-Y(zetabar, zeta, v, u)*Ybar(zetabar, zeta, v, u)*dv)^2
X = [zetabar, zeta, v, u]
PDEtools:-declare(`#msup(mi("ds",mathcolor = "#af00af"),mn("2",mathcolor = "#af00af"))`)
Ybar(zetabar, zeta, v, u)*`will now be displayed as`*Ybar
Setup(automaticsimplification = true, coordinatesystems = (X = [zetabar, zeta, v, u]), metric = 2*dzeta*dzetabar+2*du*dv+2*H(zetabar, zeta, v, u)*(du+Ybar(zetabar, zeta, v, u)*dzeta+Y(zetabar, zeta, v, u)*dzetabar-Y(zetabar, zeta, v, u)*Ybar(zetabar, zeta, v, u)*dv)^2)
[automaticsimplification = true, coordinatesystems = {X}, metric = {(1, 1) = 2*H(X)*Y(X)^2, (1, 2) = 1+2*H(X)*Y(X)*Ybar(X), (1, 3) = -2*H(X)*Y(X)^2*Ybar(X), (1, 4) = 2*H(X)*Y(X), (2, 2) = 2*H(X)*Ybar(X)^2, (2, 3) = -2*H(X)*Ybar(X)^2*Y(X), (2, 4) = 2*H(X)*Ybar(X), (3, 3) = 2*H(X)*Y(X)^2*Ybar(X)^2, (3, 4) = 1-2*H(X)*Y(X)*Ybar(X), (4, 4) = 2*H(X)}]
g_[]
g_[mu, nu] = (Matrix(4, 4, {(1, 1) = 2*H(X)*Y(X)^2, (1, 2) = 1+2*H(X)*Y(X)*Ybar(X), (1, 3) = -2*H(X)*Y(X)^2*Ybar(X), (1, 4) = 2*H(X)*Y(X), (2, 1) = 1+2*H(X)*Y(X)*Ybar(X), (2, 2) = 2*H(X)*Ybar(X)^2, (2, 3) = -2*H(X)*Ybar(X)^2*Y(X), (2, 4) = 2*H(X)*Ybar(X), (3, 1) = -2*H(X)*Y(X)^2*Ybar(X), (3, 2) = -2*H(X)*Ybar(X)^2*Y(X), (3, 3) = 2*H(X)*Y(X)^2*Ybar(X)^2, (3, 4) = 1-2*H(X)*Y(X)*Ybar(X), (4, 1) = 2*H(X)*Y(X), (4, 2) = 2*H(X)*Ybar(X), (4, 3) = 1-2*H(X)*Y(X)*Ybar(X), (4, 4) = 2*H(X)}))
eqn3 := SumOverRepeatedIndices(Physics:-`*`(d_[mu](Y(X)), e_[1, `~mu`]))
((Y(X)*Ybar(X)-1)*(diff(Y(X), zetabar))+(Y(X)*Ybar(X)-1)*(diff(Y(X), zeta))+(diff(Y(X), u)+diff(Y(X), v))*(Y(X)+Ybar(X)))*2^(1/2)/((-(Ybar(X)^2+1)*(Y(X)^2+1)/(Y(X)+Ybar(X))^2)^(1/2)*(2*Y(X)+2*Ybar(X)))
Download Directional_Derivative.mw
I'm trying to solve the following in Maple.
minimize(int(0.1e-3+.5*t+0.2e-2*t^2-b*t-a, t = 0 .. 300), location = true)
But Maple told me that the answer is
Float(-infinity), {[{a = Float(infinity), b = Float(infinity)}, Float(-infinity)]}.
I really need to get a kind of numerical answer. Would it be possible? Please Help me!!
https://social.msdn.microsoft.com/Forums/vstudio/en-US/cc2a85ad-30ec-44ed-8c75-636ff71eade2/how-to-convert-integer-or-decimal-number-into-any-base-number?forum=csharpgeneral
1. for example how to convert decimal or integer number into base 3 number, base 5 number etc.
2.how to do logical operation with custom logic table for example,
120 special operator 235
01111000
11101011
special operator according to logical table is
1st op 2nd op output
0 0 1
0 1 0
1 0 1
1 1 0
  01111000
  11101011
=00010100 = 20
Hi everybody,
is it possible to define an homokinetic joint in MapleSim for multibody modeling? How can I do that?
thanks.
I'm trying to solve the following non-linear ODE numerically:
by ececuting
but maple gives me this error-message:
"Error, (in dsolve/numeric/make_proc) Could not convert to an explicit first order system due to 'RootOf'"
I couldnt find any useful information in the manual. What does this error mean? Is there something wrong with my maple code or is there just no solution for this particulare differential equation?
I have this PDE and was wondering how I can get Maple to solve it
utt+2ut-uxx=18sin(3πx/l)
with conditions u(0,t)=u(l,t)=0 and u(x,0)=ut(x,0)=0
James
Could anyone assist in rectifying this error ''Error, (in fsolve) {f[1], f[2], f[3], f[4], f[5], f[6], f[7], f[8], f[9], f[10], f[11], theta[11]} are in the equation, and are not solved for''. Here is the worksheet FDM_Revisit_1.mw
The "program" below includes a readline statement.  This does not clear the former output when run again.  Is there any modification to correct this?
David
 with(plottools):
 #f:=proc()
 #local c, numplayers:
 #numplayers:=4:
 #c:= rectangle([0,0], [11,11], color=red):
 #plots[display](c, scaling=constrained, view=[-0.8..11.5,-0.8..12],axes=BOXED);
 printf("Enter the number of players:\n");
 numplayers:=readline(terminal):
 printf("Number of players is %s\n",numplayers);
 #printf("Number of players is %d\n",numplayers);
 #return "foo";
 #end proc:
 #f();
I am using the SumOverRepeatedIndices and get a Length of Output Exceeded error. Sometimes if I close the file and restart the program then I get a result and no error.  However, if I recalculate then I get the error.
[e_, eta_, gamma_, l_, lambda_, m_, mb_, n_]
`#msup(mi("ds",mathcolor = "#af00af"),mn("2",mathcolor = "#af00af"))` := Physics:-`*`(Physics:-`*`(2, dzeta), dzetabar)+Physics:-`*`(Physics:-`*`(2, du), dv)+Physics:-`*`(Physics:-`*`(2, H(zeta, zetabar, u, v)), (du+Physics:-`*`(Ybar(zeta, zetabar, u, v), dzeta)+Physics:-`*`(Y(zeta, zetabar, u, v), dzetabar)-Physics:-`*`(Physics:-`*`(Y(zeta, zetabar, u, v), Ybar(zeta, zetabar, u, v)), dv))^2)
2*dzeta*dzetabar+2*du*dv+2*H(zeta, zetabar, u, v)*(du+Ybar(zeta, zetabar, u, v)*dzeta+Y(zeta, zetabar, u, v)*dzetabar-Y(zeta, zetabar, u, v)*Ybar(zeta, zetabar, u, v)*dv)^2
X = [zeta, zetabar, u, v]
Ybar(zeta, zetabar, u, v)*`will now be displayed as`*Ybar
Setup(coordinates = (X = [zeta, zetabar, u, v]), metric = 2*dzeta*dzetabar+2*du*dv+2*H(zeta, zetabar, u, v)*(du+Ybar(zeta, zetabar, u, v)*dzeta+Y(zeta, zetabar, u, v)*dzetabar-Y(zeta, zetabar, u, v)*Ybar(zeta, zetabar, u, v)*dv)^2)
[coordinatesystems = {X}, metric = {(1, 1) = 2*H(X)*Ybar(X)^2, (1, 2) = 1+2*H(X)*Ybar(X)*Y(X), (1, 3) = 2*H(X)*Ybar(X), (1, 4) = -2*H(X)*Ybar(X)^2*Y(X), (2, 2) = 2*H(X)*Y(X)^2, (2, 3) = 2*H(X)*Y(X), (2, 4) = -2*H(X)*Y(X)^2*Ybar(X), (3, 3) = 2*H(X), (3, 4) = 1-2*H(X)*Ybar(X)*Y(X), (4, 4) = 2*H(X)*Y(X)^2*Ybar(X)^2}]
g_[]
g_[mu, nu] = (Matrix(4, 4, {(1, 1) = 2*H(X)*Ybar(X)^2, (1, 2) = 1+2*H(X)*Ybar(X)*Y(X), (1, 3) = 2*H(X)*Ybar(X), (1, 4) = -2*H(X)*Ybar(X)^2*Y(X), (2, 1) = 1+2*H(X)*Ybar(X)*Y(X), (2, 2) = 2*H(X)*Y(X)^2, (2, 3) = 2*H(X)*Y(X), (2, 4) = -2*H(X)*Y(X)^2*Ybar(X), (3, 1) = 2*H(X)*Ybar(X), (3, 2) = 2*H(X)*Y(X), (3, 3) = 2*H(X), (3, 4) = 1-2*H(X)*Ybar(X)*Y(X), (4, 1) = -2*H(X)*Ybar(X)^2*Y(X), (4, 2) = -2*H(X)*Y(X)^2*Ybar(X), (4, 3) = 1-2*H(X)*Ybar(X)*Y(X), (4, 4) = 2*H(X)*Y(X)^2*Ybar(X)^2}))
eqn1 := SumOverRepeatedIndices(Physics:-`*`(d_[mu](Y(Zeta, zetabar, u, v)), e_[1, `~mu`])) = 0
`[Length of output exceeds limit of 1000000]`
eqn2 := SumOverRepeatedIndices(Physics:-`*`(d_[mu](Y(Zeta, zetabar, u, v)), e_[2, `~mu`])) = 0
eqn3 := SumOverRepeatedIndices(Physics:-`*`(d_[mu](Y(Zeta, zetabar, u, v)), e_[4, `~mu`])) = x
(1/2)*(-(diff(Y(Zeta, zetabar, u, v), zetabar))*(Y(X)*Ybar(X)+1)*2^(1/2)+(diff(Y(Zeta, zetabar, u, v), u))*2^(1/2)*(Y(X)-Ybar(X))-(diff(Y(Zeta, zetabar, u, v), v))*2^(1/2)*(Y(X)-Ybar(X)))/((-(Ybar(X)^2+1)*(Y(X)^2+1)/(Y(X)-Ybar(X))^2)^(1/2)*(Y(X)-Ybar(X))) = x
eqn1 := `[Length of output exceeds limit of 1000000]` = 0
algsubs(`[Length of output exceeds limit of 1000000]` = 0, `[Length of output exceeds limit of 1000000]`)
simplify(`[Length of output exceeds limit of 1000000]`)
Download Derive_Eq_4.4.mw
I'm using Maple18, I tried to integrate the function including natural logarithm:
But we get the answer:
Is there any simple way to directly convert the answer to the kind of form we want? I cannot not finish the conversion:
So the toolbox "IntegrationTools" was used, but finally, we couldn't compute the integral:
 However, we can get the correct answer by manually inputting the formula.
Using IntegrationTools is pretty nasty and not very convenient, such as the problem I mentioned.
Does anyone have another solution?
In brief the problem can be stated as follows:
Given dependent variables Qi i=1,...,N and independent variables xi, yi, and zi i=1,...,N
which are related via the following system of N linear equations with parameters P1, P2 and P3 :
Qi = P1xi+P2yi+P3zi   i=1,...,N
How to find the optimal values of  P1, P2 and P3 which satisfy the above system of linear equations subject to the following constraints:
Pi>=0   i=1,2,3
and  P1>=P2P3
 Without the requirement of P1>=P2P3, the problem can be solved with the Non-negative Least Squares Method of Lawson and Hanson.  But with this additional constraint, I am stuck.
Your suggestions are welcome.
I would like to implement a rule for typeseting delayDotProduct in latex exports (in which this expressions appears in plain form). It corresponds to dot products of vectors/matrices with the "." operator. I tried to define
`latex/Typesetting:-delayDotProduct`:=proc(f1,f2,f3)
sprintf("{ {%s}{%s} }",cat(`latex/print`(f1)),cat(`latex/print`(f2)))
which does not do the job.
Edit:
A related question: How can I make
D[1,1](x)(t)
produce x''(t) in latex output?
Given expr:=sin(n*x); and say I want to find its value at n=1,x=Pi/2, I found I can do
subs({n=1,x=Pi/2},expr); eval(%);
or combine into one
eval(subs({n=1,x=Pi/2},expr); ----(1)
But also one can write
eval(expr,{n=1,x=Pi/2}); ----- (2)
So if someone wants to just find value of expression as above, it seems (2) is much simpler than (1) since no need to call subs, it is done automatically. Is there anything else I am overlooking?
Only problem I see in the above, is that subs() uses different order: subs({},expr), while eval is:  eval(expr,{}); The other way around.
It would have been better if the order was the same in the API, to reduce confusion.
ds(t)/dt = a*s(t)*(1 - s(t) - m(t)) - b*s(t)
dm(t)/dt = c*s(t) - d*m(t)
need to find steady state of this system ( finding this simultaneously) in maple
How can you do it?
First 1371 1372 1373 1374 1375 1376 1377 Last Page 1373 of 2463
