I found the page:http://12000.org/my_notes/rankTest/test.htm,
Comparing with MMa&Matlab, Maple is abit slow.
The author guess the reason is Intel MKL.
I searched the help page, http://www.maplesoft.com/support/help/Maple/view.aspx?path=copyright,
found this info:
Intel® MKL Copyright © 1999, 2000-2008 Intel Corporation. All rights reserved.
 Does this means the Intel MKL in maple is a 6 years old product?
Is this important?
I want to know.
I have a simple transfer function like
I want to calculate the amplitude ratio and the phase shift.
Without maple I would set s=I*omega and solve for real and imaginary part to obtain the phase shift and amplitude ratio.
Is there any possibility to do that in Maple more easily?
I have equation, which includes square roots. e.g.:
I know, that sqrt() will only return positive value, therefore when I put some values of a,b and c:
I get only one answer:
3.000000000
My question is how to calculate that second branch of the solution without altering eq. itself? (In my case this equation is derived from somewhere else and it cannot be modified)
When I run a maple program which take a long time (in command line), I have this kind of message every second:
"memory used=43867.3MB, alloc=147.3MB, time=856.28"
Does there exist any way to avoid this display ?
I'm having trouble of converting my y-axis to decibel.  Here is is my script:
loglogplot(1/(1+f), f = 10^(-4) .. 10^4);
Everything is fine except for the y-axis, which is not in dB.
I'm computing a matrix which is a hessian of a quadratic function and it should be symmetric.
Unfortunately, because of the numerical errors, the hessian matrix becomes unsymmetric.
Then, I want to use this matrix as the input for the QPSolve procedure, and I get the error that the matrix is unsymmetric.
To obtain the symmetric matrix, I'm doing the following redundant computation:
A := MTM[triu](B, 1) + Transpose(MTM[triu](B)):
Is there a better solution to this problem?
Hi everyone, I have been trying to plot the Taylor Polynomial approximation with the following code. However, my maple crushes everytime I run it. I indexed some of the variables to get the plot. The code works fine without the index. What did I do wrong?
y := array(1 .. 2);
Digits := 10;
n := 30;
h := .1;
T := 0;
X := 1;
f := (x, t) -> 1/(3*x(t)-t-2);
one := 1/(3*x(t)-t-2);
two := diff(f(x, t), t);
first := diff(x(t), t)
for k to n do
y[1] := subs(t = T(k), x(T(k)) = X(k), one);
y[2] := subs(first = y[1], t = T, x(T(k)) = X(k), two);
X[k+1] := X+sum(y[i]*h^i/factorial(i), i = 1 .. 2);
T[k+1] := T+h
X[n];
data := [seq([T[n], X[n]], n = 0 .. 30)];
p[2] := plot(data, style = point, color = blue);
p[3] := plot(data, style = line, color = blue);
display(p[2],  p[3])
The code without Index (which works fine)
y := array(1 .. 2);
Digits := 10;
n := 30;
h := .1;
T := 1;
X := .1547196278;
one := x(t)^4*e^t-(1/3)*x(t);
first := diff(x(t), t);
for k to n do
y[1] := subs(t = T, x(T) = X, one);
y[2] := subs(first = y[1], t = T, x(T) = X, two);
X := X+sum(y[i]*h^i/factorial(i), i = 1 .. 2);
T := T+h
end do
Today I have a problem with assign that never arised before. I solved a system of equations with two solutions and wanted to assign, e.g. the second one. Does anybody know why "assign" here does not work, even though I often used it before in the same way. (I also tried it with the array-solution, but I received the same problem.
Output:
  {rH = 0., rL = 0., xH = 0.2289428485, xL = 0.2289428485}, {
    rH = 22.70954353, rL = 32.28670872, xH = 0.4250775404,
    xL = 0.4393791233}
    xL = 0.4393791233}
assign {rH = 22.70954353, rL = 32.28670872, xH = 0.4250775404,
  xL = 0.4393791233}
                         rL, rH, xL, xH
I would be very glad, if anybody could help me.
And here is the whole algorithm:
Hi,I'm using Maple 15. When I plot with the command
Aplot:= Plot2D(Q[2 .. 26, 13], Q[2 .. 26, 14], style = point, color = blue, symbol = solidcircle, symbolsize = 16, font = [Arial, Bold, 13], axes = box, axis = [thickness = 1, tickmarks = [5, subticks = 5]]);
There is the report of problem
Error, (in plot/options2d) unexpected axis suboption: thickness = 1
Thank you for helping me.
I have been having problems with using the BodePlot function with units:
R1 := 18.2*10^3*Unit('Omega');
R2 := 10^3*Unit('Omega');
C1 := 470*10^(-12)*Unit('F');
C2 := 4.7*10^(-9)*Unit('F');
# wo is in hertz
wo := 1/sqrt(R1*R2*C1*C2);
# Q is unitless
Q := wo*R1*R2*C2/(R1+R2)
with(DynamicSystems);
sys := TransferFunction(wo^2/(s^2+wo*s/Q+wo^2));
This is the error message I got:
Error, (in Units:-Standard:-+) the units `1` and `Hz` have incompatible dimensions
I think the problem is that the BodePlot function doesn't expect 'wo' to have units.
So I tried to work around the issue by using the loglogplot but it doesn't seem to like
complex function even when I used abs to find the magnitude (with or without units).
 Any workaround is appreciated.
I'm using MAPLE files, and a little to bored to run all commands in it.
Instead of it would be a bit easier to make a package.
Is there any post here how can I do it?
how to derive poincare series from symmetric function in maple
use taylor function need to specify its limit
if we do not know its limit,
how to know whether a function is finite in taylor expression
for example poincare series
1/((1+x)*(1+x^2))
how to display as taylor series without specify the limit of degree
because do not want to approximate poincare series with taylor
want a complete taylor series
goal is to find the polynomials which degree are 1 and 2 in above example
Strings := {"buffalo", "zebra", "aardvark", "aardwolf", "anteater", "antelope", "bumblebee"};
CP := {seq(seq(StringTools:-Take(x, StringTools:-CommonPrefix(x, y)), x in Strings), y in Strings)};
P := table(map(proc (x) options operator, arrow; x = "" end proc, Strings));
for x in CP do for y in `minus`(CP, {x}) do if `and`(StringTools*IsPrefix(y, x), `implies`(assigned(P[x]), StringTools*IsPrefix(P[x], y))) then P[x] := y end if end do end do;
Error, cannot determine if this expression is true or false: StringTools*IsPrefix("a", "")
Hi I tried to apply these command in maple to see hoe cluster graphic after that can work .. but i face this problem ,
I am a begginer in maple working on it for a term paper to demonstrate it is ability to view the cluster analysis .
if u have any benefcial resources I ll be so happy.
thanks very much
First 1375 1376 1377 1378 1379 1380 1381 Last Page 1377 of 2463
