seq(i,i=1..5);  gives output 1,2,3,4,5
seq(i,i=5..1);  seems to get ignored in Maple 7.  It does not return an error message.
I was hoping to step back from a large number to a smaller one in stepsof minus one.  The for loop structure allows negative "increments" - so I experimented by putting the decrement value of -1 between the two dots.  I was expecting it to givean error message, so was surprisd when it gavesome output!
eg  seq(i, i=5.-1.2);  gives output of 38, -1
I'm curious as to what is happening here?  Also, has the seq command been upgraded in later versions of Maple?  eg is it possible to do negative decrements?
I have to find the volume of a solid using the disk/washer method and the shell method.  I think I have the first part(disk/washer) right.   I think the shell is off. The problem is "the region in the first quadrant that is bounded above by the curve y = 1/x^1/4, on the left by the line x = 1/16, and below bythe line y = 1 is revolved about the x-axis to generate a solid."    I am having computer problems so any help is appreciated. Thanks
Consider a plot generaged by:
export_plot_options:=font=[TIMES, roman, 30], axis=[thickness=4, location=low], size=[850,850]:
points := [seq([seq(exp(-(x^2+y^2)*(1/100)), x = -10.0 .. 10.0)], y = -10.0 .. 10.0)]:
plots:-listdensityplot(points, export_plot_options);
How can one get rid of white space between the axes and the actual data??
Hi there,
I would like to know whether there is some way to print non-integer axis numbers for a given plot.
Let's say I have an array for an independent variable such as [0.5 1 1.5 2]. I would like Maple to use these values in the corresponding axis instead of printing the array indices [1, 2, 3, 4].
I would like to know how this is done for a surface plot.
Attached is the worksheet where "b" is such a parameter/independent variable: MapleSimulation_test11.mw
Thank you,
jon
I am just starting with Maple 18 on Windows 8.1. I did not like the default color palette for 2D graphs and tried another one. So I edited my maple.ini file, which was in
  Excuse me, I tried to substract in a series expansion. It works for Taylor-type expansion, but not Laurent-type ones
ffff:=1/(t-3);
ggg:=taylor(ffff,t=infinity,3);
coeff(ggg,t,-1);
ffff:=exp(t);
ggg:=taylor(ffff,t=0,3);
coeff(ggg,t,1);
Maple gives me
Error, unable to compute coeff
. My question is, why "coeff" does not work in the first case? how to make it work? Though I can copy the expansion part, assign it to another variable, and "coeff" will work
Excuse me,
  I have the following input
fff:=x1^k;
int(fff,x1=0..x2);
I would like to obtain
1/(k+1)* (x2^(k+1)), k<>-1
but maple gives me just the same integral. Is there any way to get the expression?
Im solving 4 ODE equations with BC. im trying to shoot the initial value but im having this error:
""Error, (in isolate) cannot isolate for a function when it appears with different arguments""
anyone could help me???
shooting92.mw
Shootlib := "E:\\shooting/":
libname := Shootlib, libname:
with(Shoot):
n := 2:
FNS := {F(eta), H(eta), f(eta), g(eta), u(eta), v(eta)}:
ODE := {g(eta)*(diff(g(eta), eta))+B*(f(eta)+g(eta)) = 0, g(eta)*(diff(F(eta), eta))+F(eta)^2+B*(F(eta)-u(eta)) = 0, g(eta)*(diff(H(eta), eta))+H(eta)*(diff(g(eta), eta))+F(eta)*H(eta) = 0, diff(v(eta), eta)+f(eta)*v(eta)-u(eta)^2+B*H(eta)*(F(eta)-u(eta))-M*u(eta) = 0, diff(f(eta), eta) = u(eta), diff(u(eta), eta) = v(eta)};
{g(eta)*(diff(H(eta), eta))+H(eta)*(diff(g(eta), eta))+F(eta)*H(eta) = 0, g(eta)*(diff(g(eta), eta))+0.2e-1*f(eta)+0.2e-1*g(eta) = 0, g(eta)*(diff(F(eta), eta))+F(eta)^2+0.2e-1*F(eta)-0.2e-1*u(eta) = 0, diff(v(eta), eta)+f(eta)*v(eta)-u(eta)^2+0.2e-1*H(eta)*(F(eta)-u(eta))-3*u(eta) = 0, diff(f(eta), eta) = u(eta), diff(u(eta), eta) = v(eta)}
IC := {F(0) = gamma, H(0) = Q, f(0) = 0, g(0) = z, u(0) = 1, v(0) = alpha};
BC := {F(L) = 0, H(L) = n, g(L) = -f(L), u(L) = 0};
{F(6) = 0, H(6) = 2, g(6) = -f(6), u(6) = 0}
infolevel[shoot] := 1:
S := shoot(ODE, IC, BC, FNS, [alpha = 0, gamma = 0, z = -.2, Q = 0])
Download shooting92.mw
I am trying to make a plot3d on my Surface Pro  3 running Windows8.1.
The plot looks like a ghost.  Pale grey.  It looked nice and colourful when I executed the same command on an older computer a few hours ago.  (I know it was exactly the same command because I saved the file on my old computer and then opened in on the Surface Pro 3)
Is there a way to fix this?
plot3d(-x^2+y^2-3*x+2*y+100, x = -5 .. 8, y = -5 .. 5, transparency = 0, lightmodel = light1, glossiness = 1, filled = true, style = wireframeopaque, shading = zhue, view = [-5 .. 10, -5 .. 8, 0 .. 150]);
 OOPS!  Now the problem has corrected itself.
I'm getting worried about all the weird things Maple is doing on this Surface Pro 3.  I'm trying to make up a final exam tonight (the exam is tomorrow).
I have downloaded MaplePlayer on my iPad.   I see that it comes with a number of "pre-recorded" programs that it can run.  Is there a way to have it run a Maple worksheet that I have written?   If so, how do I use this app to open an existing worksheet?
Also, are there any plans for this app on the Android platform any time soon?
I have written a program and at one point I have an assignment statement like BG(i, j) :=1    When ever I run the program, I get a dialog box which asks me to choose between "function definition" and "remember table assignment."  Is there a way to tell the program that I want this to be a table assignment in the code so that I don't always have to answer the question?
I have written a program and I would like to embed a check near the beginning to see if input data was entered correctly.  I have written an "if statement" to check on this and I would like the program to stop execution at this point if the "if statement" criteria are met.   I get an error saying that this command is disabled.   I have tried "stop", "end" and "quit," as I understand that they are all the same.
Dear friends,
Recently I was surprised when discovered the following error in using the function solve. If I run the simlest example from the help system for the first time (or after restarting), the following error occurs:
If I run this example repeatedly, this brings the following:
Previously in earlier versions I used solve many times for very complex computations and have never seen something similar.
Any suggestions are welcomed.
Where u and v are the displacement components in x and y directions respectively.
Hello I wonder if there any good solution for linear manipulation of sytem of equations(like sum, substract mulpiplication and etc. of equations). But main thing I want to find is there any demonstrative solution?
Something like a built-in equation manipulator but which serves system of equations.
First 1374 1375 1376 1377 1378 1379 1380 Last Page 1376 of 2463
