I noticed this in Student:-NumericalAnalysis:-Romberg, here are the lines of interest:
The question  is: Why create rtable, apply algorithm, then convert to Matrix at end? Why not replace line 4 below with Matrix command from start? Could not the same thing be done using Matrix from the start?
proc(expr, var, a, b, n)
local f, R, j, k, i, oldDigits;
   4   R := rtable(1 .. n,1 .. n,('storage') = ('triangular')['lower']);  #Why not create Matrix here?
   6   R[1,1] := evalf(1/2*(b-a)*(f(a)+f(b)));
   7   for k from 2 to n do
   8     R[k,1] := 1/2*evalf(R[k-1,1]+(b-a)/(2^(k-2))*add(f(a+(2*i-1)*(b-a)/(2^(k-1))),i = 1 .. 2^(k-2)))
  10   for j from 2 to n do
  11     for k from j to n do
  12       R[k,j] := evalf(4^(j-1)*R[k,j-1]-R[k-1,j-1])/(4^(j-1)-1)
         end do
  13   R := evalf[oldDigits](R);
  14   return convert(R,Matrix,('shape') = ('triangular')['lower']) #Why not use Matrix from the start?
end proc
Maple 18.02
True of False, Explain:
If ∏/2<θ<∏, Then cos θ/2<0
As title , there has 2 balls(A and B) which I can change Quality 、Radius and Position for two dimensions(x and y axis),
A has a velocity and B quiescence , let A strike to B .
As shown below
I did a sample ,but i can't make it accurately .
test.mw
I want to let my sample like the below sample
http://www.mapleprimes.com/questions/202467-How-Does-Maple-Make-A-Rutherford-Scattering-
I noticed, when using
with(LibraryTools);
Browse();
That some procedures have lost all its formating. No line numbers, no spaces in between, very hard to read. For example, dsolve() in maple.mla is like this. While other procs are well formated and easy to read.
Is there a reason for this? And is there a way to fix this in Browse() to be able to read the source? It is impossible to read it like this readlly. Maple 18.02 on windows.
I have couple questions on displaying/printing items I see from ShowContents(LibLocation). Here is an example
with(LibraryTools):
LibLocation:=cat(kernelopts(mapledir),"/lib/maple.mla");
c:=ShowContents(LibLocation):
First quesionNow, when I do
c[1];
then I see
When is "%?.m" there? Is this suppoed to be an actual function one can print?
second question
c[30]; gives
But when I do:
interface(verboseproc=3);
print(AiryBiZeros);
I get listing that ends up calling
proc(n::{algebraic, algebraic .. algebraic})
local fn;
   1   if nargs <> 1 then
   2     error "wrong number of arguments"
   3   fn := traperror(evalf(n));
   4   if type(fn,'numeric') and not type(n,'posint') or type(fn,('numeric') .. ('anything')) and not type(op(1,n),'posint') or type(fn,('anything') .. ('numeric')) and not type(op(2,n),'posint') then
   5     error "expecting positive integers in argument"
       elif type(n,('integer') .. ('integer')) and op(2,n) < op(1,n) then
   6     NULL
   7     ('AiryBiZeros')(n)   <----- Is this C function/compiled that is why it does not show?
       end if
end proc
Which is the same name I printed. So it seems to be another internal procedure with same name? How can I print it as well?
Is there a better way to print Maple procedures/command than what I am doing above so one gets full listing?
I tried Browse(); command in LibraryTools, but found it very cluncky to use (keeps losing listing and screen become blank. Very buggy)
How do I use msolve to solve y^2 + y - 11=0 in Zp for all primes p with 41=< p =<107 ?
Also, using the results make a conjecture describing the primes p for which there are solutions to y^2 + y - 11 = 0 in Zp
This was what I did.
41<=p<=107
msolve(y^2 + y - 11=0, p)
but I received this error, no implementation of msolve matches the arguments in call, msolve(y^2 + y - 11=0, p)
Any help is appreciated. Thanks
if given a prime ideal p, is it possible to find back possible ideal A which output this prime ideal
such that p*A = 0
I have a coefficient matrix A and the constant matrix b.
I want to find the unknowns x_1,x_2,...,x_8. When I put my code and run it in Maple I get an error. Any ideas as to why this is happening? The code I tried is as follows:
with(Student[NumericalAnalysis]):
A := Matrix([[-1, 0, 0, (1/2)*sqrt(2), 1, 0, 0, 0], [0, -1, 0, (1/2)*sqrt(2), 0, 0, 0, 0], [0, 0, -1, 0, 0, 0, 1/2, 0], [0, 0, 0, -(1/2)*sqrt(2), 0, -1, -1/2, 0], [0, 0, 0, 0, -1, 0, 0, 1], [0, 0, 0, 0, 0, 1, 0, 0], [0, 0, 0, -(1/2)*sqrt(2), 0, 0, (1/2)*sqrt(3), 0], [0, 0, 0, 0, 0, 0, -(1/2)*sqrt(3), -1]]);
b := Vector([0, 0, 0, 0, 0, 10000, 0, 0]);
LinearSolve(A, b, maxiterations = 300, method = SOR(1.25), tolerance = 10^(-2));
I also tried it with a SOR variable of 1.5 instead of 1.25, but that gives me the same error.
Is it possible in Maple to select summand with some command?
For example:
eq := a+b = 0;
                           a + b = 0
eq-b;
                             a = -b
How to generalize second line?(in this case I explicitly told to subtract b, but I want to pick b by some command)
And I am not talking about solving, isolation or anything like that in this case. I just want to transfer something from lhs to rhs by selecting it beforehand.
How can one simplify following expression:
After applying 'simplify' command I am getting this:
Powers are not distributed between bases.
How to force Maple simplify it further to
Is it possible to hide the geometry linked to the center of gravity and masses in the implicit geometry and keep only the kinematic joint.
If yes, may you explain how ? For the moment, I only manage to show/hide all the element of the implicit geometry.
I use MapleSim 6.4.
Thank you for your help.
I have a DEplot :
DEplot(sys, [x(t), y(t)], t = 0 .. 30, [[x(0) = 0.8, y(0) = 0]], x = -1.25 .. 1.25, y = -1.25 .. 1.25, numpoints = 300, axes = boxed);
I would like to draw on this plot two circles centered in the origin with different radiuses.
How can I proceed?
How can I plot a vertical line say x = a in Maple 15 worksheet?
I have about a year of experience in Maple, but as we know, we often come accross very simple problems that are difficult to find solutions to. Part of the problem is that I have not used conditional tests within for loops before.
I have a very large matrix, but until I solidify the algorithm, I'm practicing on a small matrix.
I created a 3 by 3 fibonacci matrix A:=<21,5,1|13,3,1|6,2,0>
I am trying to change the 1s to 0s without specific index reference. Here is my psuedocode that I hope to work on after some tips:
  • for i from 1 to 9
    if A[k] = 1 then
    A[k]=0
    end if
    end do
I get an error message saying "unterminated for loop," which is confusing me.
I have 4 retangular equations:
z0:=sqrt(3)+I
z1:=-1+I*sqrt(3)
z2:=-sqrt(3)-I
z3:=1-I*sqrt(3)
on polar form they apear as:
polar(z0)=(2,Pi/6)
polar(z1)=(2,2*Pi/3)
polar(z2)=(2,-5*Pi/6)
polar(z3)=(2,-Pi/3)
I want those polar expressions plottet in a polarplot as points(x,y), how is that possible ?
First 1378 1379 1380 1381 1382 1383 1384 Last Page 1380 of 2463
