How would one in Maple solve this, which is an inequality equation in some variables, which can be nonlinear, with constraints on range of each variable. I.e. I want to find conditions on the variables to make the inequality satisfied.
In Mathematica, I use the Reduce command
Clear[x, y];
eq = 1/2 - x + x^2 - y + y^2;
Reduce[{eq > 0, 0 < x < 1 && 0 < y < 1}, {x, y}, Reals]
How would one do the same in Maple? I tried solve, but can't give constraints.
eq:=1/2 -x+x^2-y+y^2:
solve(eq>0 , {x1, x2});
So I need to do the same as in the Mathematica command, but in Maple. I do not want numerical solution, but algebraic as shown above.
Using Maple 18.2 on windows.
x_1 = 1;
x_n = 1/2 (x_n-1 + 3/x_n-1 ) for n>=2
Is there a maple command to check if the above statement is rational, eventhough it is obvious enough?
I tried to evaluate x_2 using subs(n=2, x_n) but keep getting an expression in terms of x_1. Using evalf(x_2), the result was x_2.
I'm very new to maple, so please help :(
Hello people in mapleprimes,
I want to ask a question about modification of expression.
Basically, what I want to do is to change the expression of sqrt((-a)^2) to sqrt(a^2).
The expression I want to modify is this:
aa:=phi[n, j] = a[j, D]-a-sqrt((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j])
I want to change this to
phi[n, j] = a[j, D]-a-sqrt((a[j, D]-a-tau[n, j])^2+4*gamma*f[c, n, j]/L[j])
To do this, I wrote as
subs(sqrt((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j]) = sqrt((a[j, D]-a-tau[n, j])^2+4*gamma*f[c, n, j]/L[j]), phi[n, j] = a[j, D]-a-((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j])^(1/2))
Or, I wrote as
subs(op([2,3,2,1,1],aa)=(a[j, D]-a-tau[n, j])^2,aa)
If there is better ways, please tell me them.
Best wishes.
taro
AoA. Hope you will be fine. I want to factorize 2046 as
2046=2*1023
but maple gives
ifactor(2046)=11*(2*3)*31
PhD (Scholar)
Department of Mathematics
I have the following system I need to solve:
dy(t)/dt = alpha(t)-y(t)
alpha(t)=alpha0*(x(t)-x0)
dx(t)/dt=y(t)-beta(t)
beta(t)=beta0*(x(t)-x0)
 I am trying to get functions of y(t) and x(t), so I can plot y(t), x(t) and alpha(t) as it changes over time.
I have tried using dsolve to no effect.  I define the inital conditions, I define the functions I am looking for and when I press enter dsolve doesn't return anything.  I also know all the constants and defined them as well.
I am trying to simplify the eigenvalues of a 2x2 matrix [[a,b],[c,d]] subject to the condition a,b,c, and d are integers such that a+b = c+d. Why do the following commands not achieve this?
A:=Matrix[[a,b],[c,d]]):
Eigenvalues(A) assuming a::integer,b::integer,c::integer,d::integer,a+b=d+c
How might I achieve what I need?
I'm trying to calculate the time fro my brachistochrone problem.  An object travels from A(0,a) to B(b,0)
a=7 and b=10
I've already found the parametric version:
x(t)=0.5c(t-sin(t)
y(t)=a-0.5c(1-cos(t))
c= 7.039837581
I cant get it right in maple:
restart; a := 7; b := 10; g := 9.81; eq1 := .5*r*(u-sin(u)) = a; eq2 := a-.5*r*(1-cos(u)) = b; sol := fsolve({eq1, eq2}, {r, u}); r0, u0 := op(subs(sol, [r, u])); x := proc (u) options operator, arrow; .5*r0*(u-sin(u)) end proc; y := proc (u) options operator, arrow; a+(-1)*.5*r0*(1-cos(u)) end proc; plot([x(u), y(u), u = 0 .. u0]); Int(sqrt((diff(x(u), u))^2+(diff(y(u), u))^2)/sqrt(-2*g*y(u)), u = 0 .. u0); evalf(%)
I would be grateful if anyone would comment on the compatibility of Maple 18 and MacOS 10.10 (Yosemite).
without specify the characteristic,
what is the default characteristic used in hilbert series?
I have been having trouble converting the default slew rate unit from Unit('m'^2*'kg'/('s'^4*'A'))
to V/us (Volts per microsecond)
I trying to get to a point where I can define the slew rate and the result will be in terms of V/us.
Similarly, how can I change the output result from 1/s to Hz?
Hi there
How can I enter an arbitrary partition on an interval for calculating a Riemann sum by Maple 13?please write the concerning command.
Yegan
Hello everybody,
I will start a course in mastering QM in a MOOC format (Massive Open Online Course).  Up to now, I always do the calculation by hand and sometimes with the LinearAlgebra package.  But now I need to do the calculation more rapidly.  So I decided to learn how to use this package for this course.
The help system give a too generalized way to do it.  Even by looking the example, I didn't find praticle example to it.  So is there a generous person who could take a little bit of hi time to show me how to do it by using an exemple that yo will find attach to this post.
Thank you in advance for your trouble.
Besgt regards.
quantum_mechanics_DIRAC.mw
Mario Lemelin
Maple 18.2 Win 7 and Ubuntu 14.04 - 64 bits
MapleSim 7 Win 7 and Ubuntu 14.04 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
How to write a procedure to find the product of two different primes
Hey all, I am new to the Maple software.
I have a question: how to find sum of all elements in a sequence?
For example , A:=[1,2,3,4]  the stupid way to find the sum is add them together by : A[1]+A[2]+A[3]+A[4]=10
Is there a better way to sum them together?
First 1376 1377 1378 1379 1380 1381 1382 Last Page 1378 of 2463
