I am trying to do a substitution as shown in the attached document. I know variants of this question have been asked before but dont quiet get what to do. It is problem with algsubs and how it handles denominators I think. Can get substiturion to work for simple fractions but more complicated ones fail. Would appreciate any guidance here.
CR := proc (a, b, c, d) options operator, arrow; (a-c)*(b-d)/((a-d)*(b-c)) end proc
eqns := CR(a, b, c, d)
e1 := CR(b, a, c, d)
(b-c)*(a-d)/((b-d)*(a-c))
simplify(e1, {(a-c)*(b-d)/((a-d)*(b-c)) = lambda})
(a*b-a*c-b*d+c*d)/(a*b-a*d-b*c+c*d)
e1
lambda
lambda
applyrule((a-c)*(b-d)/((a-d)*(b-c)) = lambda, e1)
alias(lambda = (a-c)*(b-d)/((a-d)*(b-c)))
lambda
e1
f := a/b
a/b
f := algsubs(a/b = alpha, f)
alpha
f
alpha
algsubs((a-c)*(b-d)/((a-d)*(b-c)) = lambda, e1)
Error, (in algsubs) cannot compute degree of pattern in a
Download UHG5_substitution.mw
Dear Maple experts,
I want to solve the following problem with Maple. I appreciate if you can help.
n:=1+(2/Pi)*evalf(Int((x*0.187549975)/(x2-10.692), x=0..infinity));
How do you plot a list of values/an array into a surface?
E.g.
t = [seq(0+i*(2*evalf(Pi)*(1/10)), i = 0 .. 10)]
x:=[3,4,2*evalf(Pi), 7.83]:
y:=[2.5,4.3,6,2*evalf(Pi)+2]:
z:=[-2,0.3,1.5,evalf(Pi)]:
plot3d([x[i]*cos(t), x[i]*sin(t), y[i]*cos(t-z[i])],-10..10,-10..10);
  Is there any benchmark of the performance of maple on windows 7 64 bit vs linux, especially in solving generalized eigenvalue problem?
Thank you very much
I use maple for the determination of the symbolic relations between the geometric relations on multibody system.
I would like to create a dll function for the functions that I have determined symbolically.
I have already a paper presenting :
- the transformation Maple --> code C with the package with(CodeGeneration)
- and the transformation code C --> another software.
I would like to directly create a dll function from my maple function with using code C. Is it possible and how ?
Thanks a lot for your help.
Hi all!
I do a small calculation and get a system of 6
nonlinear equations.
And "n" is the degree of the equation is float.
Here are the calculations that lead to the system.
 with(DirectSearch):
 B:=1:
 q:=1:
 l:=1:
 n:=4.7:
 V:=0.05:
 N:=1200:
 kappa:=Vector(N+1,[]):
 theta:=Vector(N+1,[]):
 u:=Vector(N,[]):
 M:=Vector(N,[]):
 Z:=Vector(N,[]):
 M_F:=q*(6*l*(z-l)-z^2/2):
 M_1:=piecewise((z<l), l-z, 0):
 M_2:=piecewise((z<2*l), 2*l-z, 0):
 M_3:=piecewise((z<3*l), 3*l-z, 0):
 M_4:=piecewise((z<4*l), 4*l-z, 0):
 M_5:=piecewise((z<5*l), 5*l-z, 0):
 M_6:=6*l-z:
 M_finish:=(X_1,X_2,X_3,X_4,X_5,X_6,z)->M_1*X_1+M_2*X_2+M_3*X_3+M_4*X_4+M_5*X_5+M_6*X_6+M_F:
 kappa_old:=0:
 theta_old:=0:
 u_old:=0:
 M_old:=0:
 step:=6*l/N:
 u[1]:=0:
 kappa[1]:=0:
 theta[1]:=0:
 for i from 2 to N do
 z:=i*step:
 kappa_new:=kappa_old+B/V*(M_finish(X_1,X_2,X_3,X_4,X_5,X_6,z))^n*step:
 theta_new:=theta_old+1/2*(kappa_old+kappa_new)*step:
 u_new:=u_old+1/2*(theta_old+theta_new)*step:
 Z[i]:=z:
 kappa[i]:=kappa_new:
 theta[i]:=theta_new:
 u[i]:=u_new:
 kappa_old:=kappa_new:
 theta_old:=theta_new:
 u_old:=u_new:
 So,my system:
 u[N/6]=0;
 u[N/3]=0;
 u[N/2]=0;
 u[2*N/3]=0;
 u[5*N/6]=0;
 u[N]=0;
I want to ask advice on how to solve the system.
I wanted to use Newton's method, but I don't know the initial values X_1..X_6.
Tried to set the values X_1..X_6 and to minimize the functional
Fl:=(X_1,X_2,X_3,X_4,X_5,X_6)->(u[N/6])^2+(u[N/3])^2+(u[N/2])^2+(u[2*N/3])^2+(u[5*N/6])^2+(u[N])^2:
with the help with(DirectSearch):
GlobalOptima(Fl);
But I don't know what to do next
Please, advise me how to solve the system! I would be grateful for examples!
Hi there,
I have the following set of equation which I want to solve using Maple's dsolve command:
d[V(t)*C(t)]/dt = G - K *C(t)
dV(t)/dt = alpha - beta
where V is the volume, C is the concentration, and t is the time variable. G, K, alpha and beta are constant parameters of the problem.
The solution for V(t) is easy to find operating the second equation:
V(t) = V_0 + (alpha - beta)*t
But solving for C(t) is a bit harder.
I would like Maple to solve the system, but the result I get does not really make sense to me. My attempt is this: Maple_artificial_kidney.mw
Any thoughts about how to introduce the equations successfully?
Thank you,
jon
Hello everybody,
I am working on a somewhat complicated analytical problem, which includes the evaluation of the following (finite and singularity free) double integral (the stated numerical parameters may vary):
Int(exp(18.1818*(Int((0.579160e-1*sqrt(x)*Ei(1., 0.500000e-4*x)+(1072.23*(.999950-1.*exp(-0.500000e-4*x)))/sqrt(x))/sqrt(x), x = 1. .. eta))-9.10000*eta)/eta, eta = 1. .. 100.)
There are no unevaluated variables inside (all the e's are real exp()s). However, when putting it through evalf(), Maple returns it (after calculating for some time) unevaluated. I have no idea why, as a simple box sum should succeed.
Any input would be appreciated. Best regards,
  K. Reuther
P.S.: Raw expression for further deliberations
is it possible?
i want to prove the injective of new custom operator based on custom logic table according to previous post
and want to see why new custom operator for integers are unordered or sometimes ordered
we have a "little" Multibody Dynamics Project in our University. We try to compute a system with 4 DOF with Lagrange. The problem is that in the end our dsolve give us an error. We checked the whole system like 5 times and searched only for the dsolve problem over 6 hours.
Error from dsolve:
"Error, (in DEtools/convertsys) numeric exception: division by zero"
This error shouldnt be possible because we have no divisions at all in our system or somekind of inifity though arctan or what ever.
Any help would be perfekt.
Thanks a lot
Wackeraf
MultibodyDynamics_Gruppe_aktuell_V3.mw
Dear all;
I need your help to display the value of phi[jj] in the following loop.
phi[1]:=(x,y)->exp(x-y);
for jj from 1 by 1 to 2 do
phi[jj+1]:=(x,y)->int(phi[1](x,s)*phi[jj](s,y),s=y..x);
but the index jj in the integral does not change. I have any idea what is the problem.
Thank you very much for your help.
Is it possible to insert comments within algorithms in Maple T.A. questions? I'd like to add some words or annotations which won't be read by the compiler, to make the code easier to understand.
Alice
Hallo. I'm solving a initial value problem for system of 7 ODE:
dsn := dsolve({expand(maineq[1, 1]), expand(maineq[1, 2]), expand(maineq[1, 3]), expand(maineq[1, 4]), expand(maineq[1, 5]), expand(maineq[1, 6]), expand(maineq[1, 7]), T(0) = .5, u(0) = u0, Y[1](0) = .8, Y[2](0) = .2, Y[3](0) = 0, Y[4](0) = 0, Y[5](0) = 0}, numeric, method = lsode[backfull])
Is there easy way how to plot result?
Is there a way with Maple 18 to place a bracket as shown below to contain two DE's? I am not trying to solve them. Only for note-taking purposes. If there is can you please share how to do it?
DE
I have this kind of expression :
exppr
I would like to keep a sum like and simplify all the expressions of
the type $z+\bar{z}=2Re(Z)$
Thanks for your suggestion
First 1369 1370 1371 1372 1373 1374 1375 Last Page 1371 of 2463
