I am trying to solve following expression
int(int((1-exp(-5.5/cos(x)))*sin(x), x = 0 .. arctan(300*cos(y)+sqrt(12.25-90000*sin(y)^2))), y = 0 .. Pi)
But I am not getting results.
Please help me!!!
I need to change the color of all elements of a plot by command.
I know that it is possible in interactive mode (see online maple help) but I would like to select the elements of a plot by line command and change color.
I would at first produce the plot with some color and then change only color of elements without reproduce the whole plot.
How can I do it ?
Cannot calculate derivative (gradient) of a procedure returned by dsolve.
Say, I solve the equation:
S1 := dsolve([diff(y(x), x$2)-1.0325*diff(y(x), x)+1.36*y(x)=sin(2*x), y(0)=0, y(1)=1], numeric, y(x), 'output' = listprocedure);
Its solution easily can be retrieved and looks fine:
H:=rhs(S1[2]);
plot(H(t), t = 0..1, thickness = 4);
But when I try to calculate the gradient of H, I receive the error:
H1 := codegen[GRADIENT](H);
Error, (in intrep/statement) unable to translate Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .14817993189456188, (3) = .31785812820433257, (4) = .47163479035679234, (5) = .6130306894371967, (6) = .7460958115245858, (7) = .8741894219027533, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 2, {(1, 1) = .0, (1, 2) = .47692145669848085, (2, 1) = 0.7710429970702501e-1, (2, 2) = .5707930170882397, (3, 1) = .1866916935738028, (3, 2) = .7299040171277492, (4, 1) = .3128649714509215, (4, 2) = .9171936...
Gradient of procedures defined by  ":= proc()" is calculated properly.
When you label a function of curve, this label is put just next to it. Is there a way to move this label to another position of the same curve?
Hello guys
I have a coupled linear differentional equation which are in the 4th order. they are shown in the below:
P:=phi(x):
Q:=psi(x):
eq1:=a11*diff(P,x,x,x,x)+a22*diff(P,x,x)+a33*P+a44*diff(Q,x,x)+a55*Q:
eq2:=a44*diff(P,x,x)+a55*P+a66*diff(Q,x,x)+a77*Q:
eq1:=0:
eq2:=0:
The boundary values for this coupled equation are:
phi(a)=sigma1,phi(-a)=sigma1,diff(P,x)(a)=0,diff(P,x)(-a)=0,psi(a)=sigma2,psi(-a)=sigma2
Now consider:
a11:=6.36463*10^(-10):
a22:=-1.22734*10^(-9):
a33:=3.48604*10^(-10):
a44:=2.94881*10^(-11):
a55:=-5.24135*10^(-11):
a66:=-1.03829*10^(-9):
a77:=4.86344*10^(-10):
when I use dsolve for deriving a good answer in this equation, there are six real roots .How can I solve it with these boundary condition?
I need to extract phi(x) and psi(x) from this coupled equation.
Hello friends!
I 'm a student and I don't know a lot about Maple, so I would be really grateful if anyone could help me.
I want to solve a system of two equations and I have two unknowns, which are k and εα. However I don't know what I am doing wrong and I can't solve it.
I have attached my file.
Thank you very much in advance!agogos_2.mw
Dear people in Mapleprimes,
I have a question about the ordering of monomials in a polynomial.
I hope you will help me understand how Maple works about it.
I inputed the polynomial as is written in black below.
Then, the outcome was blue, which ordering I could understand well: total degree ordering where at first
those who have the order of 6 are collected which are 14 x^3*y^3, 6x*y^5, and then the following was those which
have the order of 5: 21*x^5, -35 x^4*y, 9*x^3*y^2,-15*x^2*y^3, ... and so on.
And, among those who have the same order, lexical ordering was done, that is among 14 x^3*y^3, 6x*y^5, one which
came first was the one with the larger degree about x, and among 21*x^5, -35 x^4*y, 9*x^3*y^2,-15*x^2*y^3,
the first was 21*x^5, the second was -35*x^4*y, and so one, which was the ordering following the exponent about x.
And, then, I calculated Factor(polynomial) mod 7, which meaning I know.
Then, the result was 2*(x*y+2)*(3*y^3+x^2+3x*y)y.
I can understand the ordering among x*y and 2 in x*y+2, and that among 3y^3, x^2 and 3x*y in 3y^3+x^2*3x*y.
But, I can't understand why (x*y+2) comes at the first term, with 3 y^3+x^2+3x*y following it, and with y coming last.
This might be a trivial question. But, I hope you will teach me about this.
Best wishes.
taro
polynomial := 14*x^3*y^3+6*x*y^5+21*x^5-35*x^4*y+9*x^3*y^2-15*x^2*y^3+12*y^4+18*x^2*y-30*x*y^2
`mod`(Factor(polynomial), 7)
2*(x*y+2)*(3*y^3+x^2+3*x*y)*y
Download heck_mod.mw
I am trying to fit an experimental data C[A](t)  vs t, with modelled ODE equation by solving it with numerical method. But the process gives problems here ha code and also find attached maple file.
Input is time =[0, 30, 60, 90, 120, 150, 180, 210, 240]
and output exptal data = [7647.5, 7397.5, 6755, 6252.5, 5860, 5530, 5440, 5107.5, 4857.5]
I want to find k,K[A] parameters;
EXPT_datafittinh_LHHW.mw
For my research at my school, I need to plot the Schrodinger equation using my given wave function. I am having issues though as I am receiving an error telling me that I need to submit my argument in standard or parametric form.
schro := {[4*(x^2-1)*(diff(psi(x, y), x, x))/(x^2-y^2)+2*x*(diff(psi(x, y), x))-(y^2-1)*(diff(psi(x, y), y, y))-2*y*(diff(psi(x, y), y))+(-2/(x+y)-2/(x-y)+1)*psi(x, y)] = energy};
psi := proc (x, y) options operator, arrow; e^((-1)*.5*[2*x+2*y])+e^((-1)*.5*[2*x-2*y]);
plot3d(schro, x= 1..100, y = -1 ..1);
Unfortunately, I am unable to plot my function. I was able to substitute my psi(x,y) function into my schro equation, but I am unable to do much else. I want to plot my function such that my energy is represented in the z-axis as a relationship between x and y which are a specific coordinate system (conical coordintes).
files.mw
From art of problem solving ws: "Jamal wants to save 30 files onto disks, each with 1.44 MB space. 3 of the files take up 0.8 MB, 12 of the files take up 0.7 MB, and the rest take up 0.4 MB. It is not possible to split a file onto 2 different disks. What is the smallest number of disks needed to store all 30 files?"
The answer is 13: 3*[0.4,0.8]+6*[0.7,0.7]+4*[0.4,0.4,0.4]
How to accomplish this in maple? my attempt doesnt work, unsurprisingly...
How do you move plot labels individually? Just click-hold-and-drag does not work.
"A Virtual 3D Solar System": http://www.maplesoft.com/applications/view.aspx?SID=4484&view=html#mapleautobookmark5
How do you color the orbits individually?
I am also not sure how to program a check in the code to determine that dsolve solved the differential equation.
For example
ode:=diff(y(x),x)-a*(x^n-x)*y(x)^3-y(x)^2=0;
sol:=dsolve(ode,y(x));
In this case, sol is () as it could not solve it. When I tried odetest, I get an error
odetest(sol,ode);
Error, invalid input: odetest uses a 2nd argument, ODE, which is missing
What is the correct way to check dsolve was successful that will work for all cases? I am looking for programmable method, no GUI use.
In Maple help on int, it says
"If Maple cannot find a closed form expression for the integral, the function call itself is returned"
But then, what is the correct way to check for this in the code? How do I know that the result returned is the call I made? (it would have been easier if these functions throw an error, or set some status code that one can check for success or failure).
Hello friends;
I uploaded the file. Firstly i solved the 4. order ode. I converted it to trigonometric functions from exponantial.
I have 4 equation and 4 unkowns. I thought , it is sufficient to solve this. As you see , i can not solve the system .
May you help me please where i am doing wrong.
odev4.mw
(PS:i downloaded the file again correctly)
How do you plot different kinds of data simultaneously in one graph? E.g. surfdata and spacecurve?
First 1368 1369 1370 1371 1372 1373 1374 Last Page 1370 of 2463
