It is well known that  operating in  geometry  package when setting objects symbolically some inconveniences arise. The error occurs if you do not set limits on the parameters. I wrote the procedure for finding center and radius of the circumscribed circle, devoid of drawbacks:
Circumcircle:=proc(a,b,c)
local x1, y1, x2, y2, x3, y3, n;
uses geometry;
x1,y1:=op(a); x2,y2:=op(b); x3,y3:=op(c);
n:=x2*y3-x3*y2+x3*y1-x1*y3+x1*y2-x2*y1;
point(A,a), point(B,b), point(C,c);
if type(n,realcons) then triangle(T,[A,B,C]); circumcircle(cc,T,'centername'=OO);
return [coordinates(OO),radius(cc)]  else assume(n<>0);
simplify([coordinates(OO),radius(cc)]); fi;
At initial startup procedure works correctly:
Circumcircle([x1,y1], [x2,y2], [x3,y3]);
But if you change the arguments of the procedure, an error occurs:
Circumcircle([x1,1], [x2,y2], [x3,y3]);
But if you run the procedure again with the same arguments, the error disappears:
What is the reason?
Circumcircle.mws
Hi, the following Maple code produces an error for the value x=0: 0 instead of 1.
> for x from 0 to 5 do
>print(evalf(sum((-1)^k*x^(2*k)/factorial(2*k), k = 0 .. 10)), evalf(cos(x)))
> end do;
0., 1.
0.5403023059, 0.5403023059
-0.4161468365, -0.4161468365
-0.9899924966, -0.9899924966
-0.6536436057, -0.6536436209
0.2836642141, 0.2836621855
Why such an error?
My solution to obtain the good value is:
> print(evalf(subs(y=x,sum((-1)^k*y^(2*k)/factorial(2*k), k = 0 .. 10))), evalf(cos(x)))
> end do;
                                1., 1.
Pls, I tried solving the system of PDE numerically.... When I did for just 1 plot, the graph was plotted easilyrunning.mw but When I varied some parameters its not coming out.... Also, its not bringing any error so I can't trace out my mistakes....Not_runnin.mw PLS HELP ME OUT with the multiple plots... Attached are my source codes links....
I have trouble in using the function factors. For example, I expect
factor(Pi*(t^2+1), {I});
to output
-Pi*(-t+I)*(t+I)
but instead the result is
Pi*(t^2+1)
This problem does not appear if Pi gets replaced by a general symbol:
factor(pi*(t^2+1), {I});
produces (as I expect it should)
-pi*(-t+I)*(t+I)
The problem seems to be tied to symbols representing constants, as for example replacing Pi by Catalan also results in no factorization being performed. It further seems to be tied to specifying a splitting field, because
factor(Pi*(t^2-1));
results in
Pi*(t-1)*(t+1)
Is this behaviour intended? Probably the reason is that the polynomial does not have algebraic coefficients (as it includes Pi). Indeed,
factor(Pi*(t^2-1),{});
produces the error message
Error, (in factor) expecting a polynomial over an algebraic number field
But why does this error then not appear for the call factor(Pi*(t^2-1))? If this would assume complex coefficients, it should factor using I. Considering coefficients in an algebraic number field, also the original call factor(Pi*(t^2+1), {I}); should raise an error!?
Erik
When using Maximize, is it possible to now what parameter settings that resulted in complex numbers?
KR Fredrik
Maximize(Eq1_new, {R_K*rho*`&sigma;_K`+R_S*`&sigma;_S` >= .38780613588076011954, r_K*rho*`&sigma;_K`+r_S*`&sigma;_S` >= .21290471165685214846, R_K*rho*`&sigma;_K`+R_S*`&sigma;_S` <= .38780613588076011954, r_K*rho*`&sigma;_K`+r_S*`&sigma;_S` <= .21290471165685214846});
Error, (in Optimization:-NLPSolve) complex value encountered
intsolve(int(f1(u)*(x-y), u = a .. b) = (12)*cos(x)+5*x^2-12, f1(x));I try to resolve the integral equation but i received all the time the followinf message error
Error, (in intsolve) invalid input: rhs received {f1(x) = ?}, which is not valid for its 1st argument, expr
I try to use different form but i do not how to resolve the help center do not help to much.
I preciate any help thanks
Which book is the starting point and have examples
Hi.
please, I need some code about stepsize adaptative Runge Kutta method ( any order ) or other methods.
I am trying to produce an animation. Everything seems correct, but the evaluation is taking a very long time. Even after an hour, it still tries to crank out a graph for me. I even tried to truncate the integral!
Here is my code.
z:= x -> 2*(int((sin(2*y)-sin(y))*cos(y*x)*exp(-y^2*t)/y, y = 0 .. 200))/Pi;
animate(plot, [z(x), x = 0 .. 10, y = -.1 .. 2], t = 0 .. 1, frames = 100);
Would could be the problem?
Hi all
How to read a value from keyboard of PC when executing a maple document and assign it to a variable ?
Dear the specialst in programmation, please I need to put a conditon if in this procedure with this form: Can you correct me this code please. Thank you.
aaa:=proc(x,y,f,N)
local bb,
for i= from 1 to N do
bb[i]:=f(x[i],y);
if bb[i]<=2 then y:=3*x[i] else y::=x[i]^2end if ;
end proc
> with(DEtools);
> L := -1.576674; MU := 0; DE13 := {(D(x))(t) = x(t)*(1+4*x(t)*x(t)-y(t)*y(t))+MU*y(t)*(x(t)*x(t)-.43*y(t)*y(t)-L), (D(y))(t) = y(t)*(1+x(t)*x(t)-.5*y(t)*y(t))+MU*x(t)*(x(t)*x(t)-.43*y(t)*y(t)-L)}; DEplot(DE13, [x(t), y(t)], t = 0 .. 20, [[x(0) = 0.1e-1, y(0) = .99], [x(0) = -.1, y(0) = -.9], [x(0) = 1.1, y(0) = 0], [x(0) = 0, y(0) = .2], [x(0) = 0, y(0) = .6], [x(0) = .6, y(0) = 0], [x(0) = .75, y(0) = 1], [x(0) = .1, y(0) = .1], [x(0) = .5, y(0) = 1.0], [x(0) = -.5, y(0) = 1], [x(0) = .5, y(0) = -1], [x(0) = -.5, y(0) = -1], [x(0) = -0.1e-1, y(0) = .99], [x(0) = 0.1e-1, y(0) = -.99], [x(0) = -0.1e-1, y(0) = -.99], [x(0) = .5, y(0) = -1], [x(0) = -.5, y(0) = -1], [x(0) = 0.1e-1, y(0) = .9]], stepsize = 0.1e-1, scene = [x(t), y(t)], title = "phaseplane 3 prime plot", linecolor = black, thickness = 1);
-1.576674
/ / 2 2\
{ D(x)(t) = x(t) \1 + 4 x(t) - y(t) /,
/ 2 2\\
D(y)(t) = y(t) \1 + x(t) - 0.5 y(t) / }
Warning, plot may be incomplete, the following errors(s) were issued:
cannot evaluate the solution further right of .93908020e-1, probably a singularity
cannot evaluate the solution further right of .26367741, probably a singularity
cannot evaluate the solution further right of .23463732, probably a singularity
cannot evaluate the solution further right of 1.7040014, probably a singularity
cannot evaluate the solution further right of .62484768, probably a singularity
what do i need to do so there are no more singularites?
i cant find the error the program is saying i have
> L := -1.576674; MU := 0; DE13 := {D(y)*t = -x(t)*(1-2*x(t)*x(t))+MU*y(t)*(x(t)*x(t)-3*y(t)*y(t)-L), (D(x))(t) = y(t)*(1-y(t)*y(t))+MU*y(t)*(x(t)*x(t)-3*y(t)*y(t)-L)}; DEplot(DE13, [x(t), y(t)], t = -20 .. 20, [[x(0) = 0.1e-1, y(0) = .99], [x(0) = 0.5e-1, y(0) = .95], [x(0) = .1, y(0) = .9], [x(0) = 0.4e-1, y(0) = .96]], stepsize = 0.1e-2, scene = [x(t), y(t)], title = "phaseplane plot", linecolor = black, thickness = 1, number = 1000);
Error, (in DEtools/DEplot/CheckInitial) too few initial conditions: [x(0) = 0.1e-1, y(0) = .99]
it might be hard to read but if someone could help me it would be very appreciated
int(BesselJ(2, r*k)*BesselJ(1, 1500*k), k = 0 .. infinity);
(of course, calculated numerically) against r=0..40 ?
PS. It is possible in Mathematica 9.0.1.0 .
I have a procedure which give an approximate solution for ode.
This our procedure
RKadaptivestepsize := proc (f, a, b, epsilon, N).
It's working ( afther some 3 mistake found by a member in Mapleprime).
Then I would like to compute the error between exact and approximate.
RKadaptivestepsize: compute the approximate solution
analyticsol: analytic solution
## here, I compute the error
for N from 2 by 2 to 500 do
dataerror:= N->evalf(abs(RKadaptivestepsize(f,0,1,epsilon,N)[1+N][2]-(eval(analyticsol, x = 1))));
##  sequence of data error
data[error] := [seq([N, dataerror(N)], N = 2 .. 500, 2)]:
if  data[error][k][2]<=epsilon then
printf("%a  is the number of steps required using 3-step Runge Kutta Method to achieve an  eroor of 1e-6 .", k)
break ;
But its gives an error.: Error, reserved word `error` unexpected
Have any one an idea.
First 1482 1483 1484 1485 1486 1487 1488 Last Page 1484 of 2463
