Can anyone explain this?
> A := Matrix(7, 7, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (2, 6) = 0, (2, 7) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0, (3, 6) = 0, (3, 7) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 0, (5, 6...
Mapleprimes has really painfully slowed down in the last day.  What's happened?
After I post this message mapleprimes will refresh and refresh a few times (not that it hasn't done that before) but now that it's slower again, it's quite frustrating, I can't post even check primes for at least 15 minutes after a post.  Back to the old days of primes 2 I guess.  I can't tell if mapleprimes making progress but it seems like were going backwards just as much as we go forwards.
Good afternoon.
I have a problem.
i want ot add the procedure friccion(x1q1(t), x2q1(t), 1) into the dynamic system equation, because the fricction change with the velocity.
I don´t know how can solve that
Please help me o give some ideas.
thank you
30-03-2011-robot-man.mw
My question is very easy I have a^2+b^2*a+b+1 and I want b^2*((a^2)/(b^2)+1/b^2+a)  how could I ask this to maple?
In particular my expression is
Hello.
I can't find a very "basic" tutorial about data file plotting and I have very simple questions.
Assume that we have a file that contains :
0.5 0.2
0.3 0.9
0.4 0.1
0.7 0.6
The first thing to do is to read data. I have no problems for that :
mydata:=readdata("test.txt",2)
Then
mydata=[[0.5,0.2],[0.3,0.9],[0.4,0.1],[0.7,0.6]]
Question n°1
I draw tiles, i want to utilise un plot of an array 2 dimension. But i have had a good solution ?
I input data by hand :
> with(plottools);
> with(plots);
 > a := proc (i, j) options operator, arrow; polygon([[i, j], [i, j+1], [i+1, j+1], [i+1, j]], color = red) end proc; b := proc (i, j) options operator, arrow; polygon([[i, j], [i, j+1], [i+1, j+1], [i+1, j]], color = green) end proc;
Hi everybody,
i'm an italian student, i'd like to create a Maple Library Archive for Maple 11 (a .mla file) with the procedures i want but i don't know how to. Can anyone explain me?
(I want to create a .mla file with some procedures and then recall the library at the initialization of a new worksheet, so that i can use the procedures i defined)
For example, i would like to create a .mla archive with the 2 following procedures:
I'm trying to plot phase analysis for the Friedmann's equation, however when running the protocol and trying to plot these phase analysis, it comes up with error that rho wasn't allowed in the set of options!
Here's the code i'm having difficulty with!?!
> SFsys := proc (lambda, W, ics, T, v, u) local sys, flatF, rho0line, plot0, plotDSp, plotDSm, plotE, flatF_Plot, IC, df1, df2;
sys := eval(DSys, {Lambda = lambda, gamma = W});
> Hello Guys,
Please help me with this problem.
I generate the solutions to an equation and then I place them in a list as for example
> t1 := [((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2+8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), -((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2+8*I*Pi^2*beta*Q...
Hi , I'm Alan GHafur , I'm student in master dagree in Statistic in Irbil / Iraq .I want learn how can slove non linear function in Maple.
thank you for hlep me.
In 2D input it is possible to represnet
diff(f,x) as d/dx f
Is it possible to do
diff(f,x,x) as d^2/(dx)^2 f somehow?
Is it possible that we can add or modify new expressions in the palettes?
There are many ways to enter the second derivative in Maple.  Except for some silly reason I am stuck trying to figure out or find out how to enter it in 2d math form.
d2    f
dx2
Entering it like d^2 (right arrow) f  / (dx^2)  is not the right way to enter it.  What is the right way?
Okay, many questions here, maybe someone can answer one or two of them for me?  Can someone show a few simple multi-thread examples that work starting from version Maple 12 ?  Actually what version does multithreading actually really start working to improve calculation times?
From what I understand the Threads package was introduced in Maple12 so it's almost experimental there.  An example I found using add() and Add() shows a slight...
Why is this software so unintuitive ?!
It can't even plot a vectorfunction, and when i finally found out (wich took a looong time because there is no help to get out there) i discovered my need for having to plot 2 functions in 1 graph wich is impossible !!
This is a ridiculous piece of software that i wouldn't even use, even if i got money for it !
I have fought to make this work because i had 3 small assignments to do, and thought they would be nice...
First 1893 1894 1895 1896 1897 1898 1899 Last Page 1895 of 2457
