Hi there,
Often an expression has more than one output, for example, when simply more solutions exist: sol1, sol2, ...
Then I would get the second solution by %[2]. So far so good.
Anyway sometimes the output is splited in cases, with the { notation. How do I read out a specific case of such a solution?
thx :)
Error, (in LinearAlgebra:-LA_Main:-MatrixInverse) singular matrix
what does this mean?
I have 2 equations that are made up of various powers of 2 different variables. Is there any command to retain only terms of the first order? E.g. no "x^2", "x^{3/2}", etc, just "x"s.
He guys!
I had Maple 11 installed on my Mac, and yesterday upgraded to Maple 15, which was installed in a separate folder. My question is if I now can uninstall Maple 11 from my computer, or will Maple 15 need the files, since it was an upgrade, and no full version?
If I can uninstall it: How do I do it properly? I'm on a Mac with OS X 10.6. Maple 11 is installed in a separate folder in the applications folder. There is no uninstall file however. Is just dragging...
I have just upgraded from Maple 12 to Maple 14.  I opened an old file (Maple 12 format) and when I tried to use display to replot the data - there were capital letters where the fit line should be and the axes were also strange.  Is anyone else having this problem and what should I do about it.  Below is a copy of my info:
[animate, animate3d, animatecurve, arrow, changecoords,
complexplot, complexplot3d, conformal, conformal3d,
I want to assign
D1:=-1/4*int((f*exp(-v*s)*(1+v*s)/v^3),0..infinity);
When I do this, it print f(x), v(x), s(x) in the integral and I don't want that...it should stay as f,v,s. Am I doing something wrong?
a very simple problem, but nevertheless I am really struggling with it and would appreciate any help.
10.0/50.0;
This generates the output:  .20000000
However, I need the output in the format 0.20
I've already tried the numeric formatting dialogue but it didn't change anything.
Any hints?
Andrea
test := proc (value)
  local a, i:
  a := [jack, john, will]:
  for i in a do
    assign('i', value):
  print(a);
test(5);
                       [jack,john,will]
outside of the proc it works like I want it to
a:=[jack,john,will]
for i in a do
  assign('i',5):
I want to solve a series of differential equations, and then plot the results, but I'm having a bit of trouble with evaluating them using dsolve. My code is:
c:=1;
mu:=0.3;
m1:=1-mu;
m2:=mu;
x1:=mu;
x2:=mu-1;
omega1:=1/2(mu(1-mu)-3);
omega:=1+omega1/c^2;
r1:=sqrt((x(t)-x1)^2+y(t)^2);
r2:=sqrt((x(t)-x2)^2+y(t)^2);
A:=diff(y(t),t)*x(t)-diff(x(t),t)*y(t);
rsquared:=x(t)^2+y(t)^2;
with(StringTools):
Length("fc2c-cEImI0Qb1I#YZTdh7JyQ%3t#eUW7W,5,CMjUV/\WHv\rEYNLrBlkETbsy+");
                               61
Length("fc2c-cEImI0Qb1I#YZTdh7JyQ%3t#eUW7W,5,CMjUV/WHvrEYNLrBlkETbsy+");
                               61
I expect the first call to Length to return a value of 63.  The backslashes are being ignored.  Is this a "feature", or is the Length command not behaving as it should?
Is there a simple way to assign a single value to multiple variables?
just as an example, instead of labouriously entering a1:=5: a2:=5: a3:=5  ... a40:=5:
This way I present here doesn't work as I thought.
a:=[seq(a||i,i=1..40)]:
for ii in a do
  ii:=5:
a1;
                 a1
Any suggestions?
Hi Maple experts,
is there a way to tell Maple, that it only gives me the first 10 solutions it finds.
My problem is, that I have an equation
eq := f(x,a,b)=0
with probably millions of solution pairs
(a_0 , b_0).
I use
solve(eq, {a,b} )
Therefore, maple thinks the whole night, fills 2Gb of memory untill I have to interruped the calculation.
Indeed I need only 1 nontrivial solution (a,b)  !
I was wondering whether The Mathematics Survival Kit is now also available for Mac? When I downloaded it for version 14 it was a windows version which I was unable to use because I'm a Mac user... ;-( So I am concerned that when I buy it now for Maple 15 I might get another useless version...
Thanks for the help on my previous question.
I set up my dataset as follows:
points := [[2.612499, 16.24096], [3.437499, 14.21687], [3.437498, 11.22891], [3.437497, 8.192769], [4.262499, 6.361444], [5.224999, 7.662649], [7.974999, 7.51807], [10.175, 8.192769], [10.725, 9.59036], [12.375, 8.289155], [14.1625, 8.626504], [16.0875, 8.578312], [17.7375, 7.469878], [19.9375, 7.469878], [21.5875, 7.469878], [22.6875, 7.180721], [23.65, 8.289155], [24.0625, 9.638553...
I am new to Maple and I have not been able to figure out how to do something that should be very simple.
Using Maple to derive the conditions of a problem, I arrive at the following equation:
3*a(-1/3*b/a)^2+2*b(-1/3*b/a)+c = 0
By hand, I can simplify this equation, but I cannot figure out how to Maple to duplicate my result.
What steps do I need to go through to get the equation in the simplified form:
1/3*(3*a*c-b^2)/a = 0
First 1896 1897 1898 1899 1900 1901 1902 Last Page 1898 of 2457
