Why is the max height always 0 in this code? Thanks.
>restart;
>a := proc (t) options operator, arrow; (-1)*.12*t^4+12*t^3-380*t^2+4100*t+220 end proc
printf("%10.10s    %15.15s\n", "Time (hrs)", "Height (meters)");
printf("%10.10s    %15.15s\n", "----------", "---------------");
amax := 0; tmax := 0;
for t to 4 do
alt := a(t);
printf("%6d        %10.0f\n", t, alt...
> define( f , diff( f(x,y) , x ) = f1x(x,y) , diff( f(x,y) , y ) = f1y(x,y) );
produces
> diff( f(x,y) , x );
> diff( f(x,y) , y );
> diff( f(x,x) , x );
f1y(x,x)
So how can I do it correctly?
There are two data txt files:x0-y0.txt and x1-y1.txt,every one has two columns.
So, two functions can be made from the data,named y0=y0(x0) and y1=y1(x1).
I just want (y0-y1)/y0 at the same x coordinate.
Because it's too difficult to get it directly,I choose the curve fit method.
First,I used the command CurveFitting[ThieleInterpolation] to get two functions.
And then pointplot the (y0-y1)/y0 at the same x0 coordinate.
Surprisingly,the plot is discontinued.
Why is it when I read an image a:=ImageTools:-ToGrayscale(ImageTools:-Read("f:/example.bmp")) saved as a bmp saved from the internet and try b:=Threshold(a,0.5,method=above) gives me this error.
Error, (in ImageTools:-Threshold) unable to store 0.107651138030195570e-293+0.522826466871872160e-288*I in a datatype=float[8] rtable
However when I open the bmp in paint and resave the image in either 24 bit 256 color, doesn't really matter, but a format of bmp...
Hello Friends,
I have the equation
Hello-
I am trying to find an analytic solution to a cubic equation of the form ax^3 + cx + d, where a, c, and d are rather complicated coefficients.  If I simply use the solve command, it gives the solutions assuming that the discriminant is negative (that is, one real and two imaginary solutions).  However, I want the solutions in the case that the discriminant is positive (the solutions have a different functional form; it's not the case that the imaginary solutions simply become real...
I'm working on a project, where I need to create some user friendly proc/modules. I need it to ask for the variables e.i.
'Enter equation'
'Define range'
etc. but I have no idea how to do so. Can you describe a method of doing so?
Is there a way to obtain the code for BrownianMotion function in Maple15?
I tried
interface(verboseproc = 2);
readlib(Finance:-BrownianMotion);
print(Finance:-BrownianMotion);
but these only give
module () local ModuleApply, BrownianMotion, BrownianMotion1D; end module
Where do I go from here? Thanks.
With Maple15, how do I get this
sigma^2*(1+(lambda[0]+lambda[1]-2)^2+(1-lambda[0])^2)
from
with(Statistics):
R := 'RandomVariable(Normal(0, sigma))'; a := [`$`('R', 5)]
Variance((1-lambda[0])*a[3]+(lambda[0]+lambda[1]-2)*a[4]+a[5]);
simplify(%, size); collect(%, {sigma, lambda[0], lambda[1]})
In general, how do I simplify an expression when it can be stated as a sum of squares? I suspect I am missing a general simplification technique. Thanks.
Hi All
If we have extensive material in pdf format and we want to tranfer this information to Maple and use it it as the main editor and word proceesor on a go forward basis - Is it possible to copy a pdf document with extensive equations into Maple while maintaining the format particularly of the equations, pictures, drawings and plots? Any copying and pasting I do now garlbles up the equations, plots and pictures of the pages I import to Maple...
I upgraded from maple 11 to maple 15 because of issues with maple 11 and suse 11.4. When I try to run the attached worksheet I get for Fortran(f,optimize),
> Fortran(f, optimize);
Error, (in Print) improper op or subscript selector
maple 11 does not have this problem and returns the optimized code. Did something change between versions that I'm not doing correctly?
i am having a problem with this question
graph the polynomial function F(x)= x^4 - 2.5x^2 + 0.5625
determine x & y intercepts?
find local maximum And minimum of F(x)
please advise
Dear guys! I've written some expressions and then the final equations which I want to solve as below:
> Omega0 := 0.26: H0 := 0.8: q0 := -0.61: j0 := 1: s0 := -0.18: l0 := 2.61:
> f0 := 6*H0^2*(Omega0-2):      f10 := 1:    f20 := (6*H0^2)^(-1)*(-3*Omega0/(4*(1+q0))+1/2):     f30 := (6*H0^2)^(-2)*(-3*Omega0*(3*q0^2+6*q0+j0+2)/(8*(1+q0)^3)+3/4):     f40 := (6*H0^2)^(-3)*(-3*Omega0*(s0*(1+q0...
Is there a way to make the y-axis logarithmic using DEplot?
Use a change of variables to find the volume of the solid region lying below the surface f(x,y)=(2y-x)^4sqrt(x+y) and above the parallelogram in the xy=plane with vertices (3,5) (2,6) (10,10) and (11,9)
First 1898 1899 1900 1901 1902 1903 1904 Last Page 1900 of 2457
