any of the numerical factors that multiply the successive terms in the expansion of an expression of the form  (x + a)^n,  for integral n,  in accordance with the binomial  theorem. These are any terms of the form
               ∑x^(n-k)*a^k*binomial(n,k)
how to get it.
convert((x+a)^n,Sum,x)
but ,i get a anwer that i don't want
Dear all!
I wrote a program but when I run it I get an error as: " can not evaluate the solution further right of ..., maxfun limit exceeded ". I tried some ways to work around it, for example I tried "maxfun=500000" and more. Also I tried "maxfun=0", but they don't work. How can I solve my problem?
O.K. Isolved this problem myself. We can solve such a problem in two different ways. 1.by adding the expression "method=mebdfi" and 2. by adding expression "'stiff=true'".
1 -√3 - x2 -√2- x2  = 0
Look at this trinomial
32a^4 + 18a^3 - 12a
Write the polynomial as the product of the GCF of all its terms and a polynomial
PLEase explain thanks
From this expression I want to extract only terms with the variable x.
F := (1/2/Pi+Q*cos(k*x))^2*(1/2/Pi+Q*cos(k*y))/(1+beta^2*(1/2/Pi+Q*cos(k*x))^2);
I don't want to manually write it out rather extract the terms programmaticallly. I want to be left with
(1/2/Pi+Q*cos(k*x))^2 / (1+beta^2*(1/2/Pi+Q*cos(k*x))^2)
I have tried the collect fucntion but that did not seem to do it. Any suggestions...
Like in the version 7 where that variable didn't exist.
I'm using the following function for my project,:
printlevel:=2:for Prc from 2 by 1 to 100 do for B from 2 by 0.5 to 100 do (mf(Prc,B)):=(f(Prc))*(m(Prc,B)) end do end do
Is there any way to be able to sort the answers in ascending order? I tried to use sort, but when I put sort(mf(Prc,B)) it gives me a wrong answer and jumps into Prc=101 and B=20.5.
Also is there any way to put a condition for show only real numbers, without complex numbers?
upload2.mw Dear guys!
Pleaes visit the attached file and tell me what should I do. Thanks a lot.
Hi there,
I'm doing a lot of computations with Maple right now (currently the ancient 10 and 12 versions but maybe soon 14).
I would like to do Unit-Tests of my Software as known for instance in JUnit with Java. Is it possible or do I have to use the ASSERT(...) - statements?
Dear Friends:
My original equation is
solve({(1-3*q2)*(1+lamda) = 0, r1*q1-2*r2*XA*(1+lamda) = 0, (1-2*q2)*q2-r2*XA^2 = 0, 1-3*q1+r1*XA = 0}, {XA, q1, q2, lamda})
The answer is
{XA = -1/r1, q1 = 0, q2 = RootOf(r2-r1*_Z+2*_Z^2)/r1, lamda = -1}, {XA = RootOf(-1+9*r2*_Z^2), q1 = 1/3+(1/3)*r1*RootOf(-1+9*r2*_Z^2), q2 = 1/3, lamda = (1/6)*(9*r2*r1*RootOf(-1+9*r2*_Z^2)+r1^2-6*r2)/r2}
Two questions:
1. Actually I want...
let x , y in R , say for example
x=0.1243134710481
y=0.1243234710571
Then we can compare the digits where x and y agree and where they differ.
In the example , x and y agree on the first 4 digits , differ on the next digit, agree of the next 5 digits , differ on the next two digits, and agree on the last digit.
Q: Write a procedure compdigits in maple that given two decimal numbers returns a list stating the number of digits they are...
bestfit1-loop.mw, sn_union2.txt
I've written a program, but it shows an error related to maxfun limit when I run it. Can anyone tell me what the problem is? and how can I solve it? The program and the data file are attached.
Thanks a lot.
Hello all,
This is my first time posting here; I usually find answers to all my questions by searching patiently but I was unsuccessful with this particular issue.
I attend an introduction Maple class and i'm building an animated bike as project. I was already rather comfortable with Maple so i'm trying to show off a little by adding lots of cheesy details to the scene, even if unnecessary. However, some objects such as the sky, which i would like to...
I have this function:
I2:=g->(200*g)/sqrt(0.04+g^2);
plot(I2(g),g=0..1);
plot(I2(g),g=1..0);
Those two plots give the same result.
Is it possible to invert the x axes to start from 1 ?
I also tried this below, but the result is as above.
x:=seq([g,I2(g)],g=1..0,-0.02);
pointplot([x],style=line);
                     gama2 q2 - 2 gama1 XA=0
                    [-1] q1 + [1 - 2 q1] - C=0
              [-1] q2 + [1 - 2 q2] - C + gama2 XA=0
First 1902 1903 1904 1905 1906 1907 1908 Last Page 1904 of 2457
