When I am trying to write the data of the following program in a datafile
with(plots)
eq := (diff(G(eta), `$`(eta, 2)))/Pr-2*n*b*eta*G(eta)+(a+(1/2)*b*eta*eta)*(diff(G(eta), eta))
> A := {x=0, y=0}:
> B := {x=0, -y=0};
> {A} union {B};
{{x=0, y=0},{x=0, -y=0}}
How to get Maple to realise that A and B are actually the same so that "{A} union {B}" would return "{{x=0, y=0}}" instead of above?
How to join expressions in the set, for example to convert the set {y=0, x>-1, x<1} to {y=0, -1< x <1}?
Thank you in advance.
when drawing a geometry.line object by using geometry.draw, the default for each axis is -10..10, so that I cannot see in the plot, for example, the line y=11;
How can I extend this range?
Best regards
Ouba
I want to plot a bunch of straight lines with positive slope in one colour, and I want to plot a single line of negative slope in another colour.
I hope my code is self-explanatory:
restart; with (plots):
myEqns:=NULL:
for i from 1 to 5 do;
 myEqns:=myEqns,y-x=i;
myEqns:=[myEqns];
 [y - x = 1, y - x = 2, y - x = 3, y - x = 4, y - x = 5]
implicitplot([op(myEqns), y+x=0], x=-10..10, y=-10..10, colour=[red,blue]);
I am a beginner at Maple. A friend of me has told that Maple can solve analytical solutions.
In other words, I want to combine three equations ( a linear system)  in order to conclude to the final solution.
Has Maple the ability to solve analytically a linear system of 2 or more equations?
Thank you very much in advance.
Kind Regards
Thanos
I'm trying to have Maple work through ideas involving the Fundamental Theorem of Calculus, and am encountering a problem with the programming of Maple.
I begin by defining a function like:
F(x) := int(x^2,x)  (or equivalently, F:= x -> int(x^2,x)  )
Then I ask Maple to evaluate F(2).  I expect to get 8/3 but instead I get this error message:
Error, (in int) integration range or variable must be specified in the second argument, got 2
even if I use a simple x^2+y^2 plot I get these funny gaps at the botom of the plot. I have looked through the FAQ files and can't seem to find a solution to it... is there one ?? from what I have seen so far there does not seem to be an easy solution. with a graph like the type above to change to coords=spherical or cylindrical does not show the same graph due to that change.
I tried to implement an small example sheet for using the RSA algorithmen with small numbers. Unfortunatly, I get confused by my own program and have difficulties to figure out what I am doing wrong. My message can be decoded with both keys, the public and private key what is obviously not correct.
below is my code with some comments:
restart: with (numtheory):
p := 13; # my first prime number
q := 23; # my second one
n := p*q;
I am of interest about using StateSpace(de, invars
How can I plot, say, y1=x+4, 0<x<5 and y2=2x+1, 0<x<10 on the same plot area?
Thank you,
Ozgur
I want to construct a sequence of diffenrential equations with
seq(diff(f[i],x)=k[i]*f[i],i=1..4);
but I get
0 = k[1]*f[1], 0 = k[2]*f[2], 0 = k[3]*f[3], 0 = k[4]*f[4]
Is there anyone can tell me what I have done wrong? Thanks a ton!!
This is my situation, please help me.
Cargando  MathematicalFunctions
Cargando  PDEtools
> with(DEtools);
> restart; m[1] := 1; m[2] := 1; l[1] := 1; l[2] := 1; g := 9.8; w := 1; ec1 := (((1/3)*m[1]+m[2]+w)*l[1]^2+((1/3)*m[2]+w)*l[2]^2+(2*((1/2)*m[2]+w))*l[1]*l[2]*cos(beta(t)))*(diff(alpha(t), t, t))+(((1/3)*m[2]+w)*l[2]^2+((1/2)*m[2]+w)*cos(beta(t)))*(diff(beta(t), t, t))-(2*((1/2)*m[2]+w))*l[1]*l[2]*sin(beta(t))*(diff(alpha(t), t))*(diff(beta(t), t))-((1/2)*m[2...
How to load Maple-NAG connector to execut this example ?
Is it an additional program to install ?
n := 4:
nnz := 11:
la := 22:
lfill := 1:
dtol := 0:
pstrat := "Nag_SparseNsym_CompletePiv":
milu := "Nag_SparseNsym_UnModFact":
a := Vector[row](la,[1.0,1.0,-1.0,2.0,2.0,3.0,-2.0,1.0,-2.0,1.0,1.0],datatype=float[8]):
irow := Vector[row](22,[1,1,2,2,2,3,3,4,4,4,4],datatype=integer[kernelopts('wordsize')/8]):
icol := Vector[row...
I was wondering if someone could assist me with the code for listcontplot.
I've tried the following:
M:=Student[LinearAlgebra]:-RandomMatrix(4,4);
listcontplot(M);
But this does not work.  Is there any way to use listcontplot, listcontplot3d, or any other command to generate something similar to what Excel calls a Surface - contourplot?
First 1905 1906 1907 1908 1909 1910 1911 Last Page 1907 of 2457
