Hi, everybody,
I am a newbie of maple. I used maple to draw some function image, it's work pefectly. For higher quality I want to set a thick line width of axis but I don't know how to do. Help me please.
Best regard.
You would have thought I'd have learnt to make sure I've saved my work by now.
I've spent the last 4 hours or so working on a worksheet on Maple, without saving it once (I know, I know). It started acting slow-- by which I mean it was talking a while to actually type things, as opposed to running calculations-- and then the screen suddenly went grey, froze, and now my cursor turns into an hourglass when I mouseover the window.
It's been this way for the past 10 minutes.
Question: Graph the 4th degree polynomial with realcoefficients whose zeros are x=-2 (a repeated root), x=3 and x=0. Following all the graphing requirements as shown below:
- show the correct shape of the function without distortion or wasted space.
-show all the maxima, minima, and intercepts
-allow to read (x,y) coordinates of all the x and y intercepts and all the maxima and minima on the graph easily and clearly.
-have a...
please help me to draw national emblem of AZERBAIJAN.
    I have this problem and I cannot find a way to perform this search that I want it to.
I have a set consisting of integers and fractions.  What maple code can I use to select only the integers out of this set.
For example:
A:={1,1/2,9,5/2,6/4,8,10,11};
I want to choose only the integers out of this set...so I need to obtain a set with D:= {1,9,8,10,11}.
How do I do so?
I'm teaching numerical analysis with Maple and then I started with fixed iteration method.
When I programed the method which is simple, I got the solution as:
restart:with(Student[NumericalAnalysis]):
f := x->2*tan(x)-x-1;
g := x->arctan((1/2)*x+1/2);   # fixed point method where the solution of x=g(x) is the the solution f(x)=0
x[0] := 0.2; for k from 0 to 20 do x[k+1] := evalf(g(x[k])) end do; this line give the solution
How can I plot on the same graph the Normal,Tangent and Binormal vectors from a Position Vector?
> restart;
> with(DifferentialGeometry):with(LinearAlgebra):with(JetCalculus):with(Tools):with(PDEtools): with(DEtools):
> declare(u(x(t),y(t),t),v(x(t),y(t),t));
u(x(t), y(t), t) will now be displayed as u
x(t) will now be displayed as x
y(t) will now be displayed as y
v(x(t), y(t), t) will now be displayed as v
> PDE_sys:={diff(u(x,y,t...
Was given the equations f(x)=x^3+3x+7 g(x)=tan(x^2+1)
Need to use maple to differentiate each of the following...
A. f(x) * g(x)
B. f(x)/g(x)
C. f( g(x) ) entered as f@g
D. g( f(x) )
How do i differentiate these, normally for its just D(f) but i tried D(f@g), D(f * g) but it doesnt look right. Please help!
THanks
Has anyone had any experience of using an eBook reader such as a Kindle to read/display any of the Maple manuals?
Hi everyone,
I'm having trouble solving a set of pdes and keep encountering the following error:
Error, (in pdsolve/indexlex) invalid input: a string/name list is expected for sort method `string`
I have been trying to find out why I get the error or what the indexlex error is but am stumped... I cannot find anything on the Maplesoft or mapleprimes websites about it.
This is the code I am using which is giving the error:
How do I download and save "MaplePrimes" ?
Thanks for your help!
I am using finite element analysis and have 47008 nodes, so require a 47008 by 47008 matrix.  I wish to create the matrix using a procedure and using if statements to fill in the matrix with the equations (mostly repeating and every element in each row is 0 excpet for 4 or 5).  Anyway, I have tested my solution method on a much smalller matrix and know it works.  My question is if there is a way to create such a large matrix without getting a memory error, and...
I am sure there will be a simple solution to this problem. Basically I am doing some work on Fibonacci numbers and the convergence of fibonacci(n+1)/fibonacci(n). My code basically is looking for the first n that comes within a certain distance of this convergence.
I am looking for the code to print just the first result from my code rather than all n for which it is true which it is doing at the moment.
Is there a specific maple command for this or does anyone have any ideas?
During a spam attack, like mapleprimes is seeing now, all of the posts are all out of whack.
Once these spam posts are deleted the posts and questions keep the same wrong order.  I am suggesting that once a post or question has been cleaned of these spam posts that the question/post revert to it's previous proper position in the order of the date on the last posted action.
Perhaps this is already being looked at?
One more suggestion. ...
First 1907 1908 1909 1910 1911 1912 1913 Last Page 1909 of 2457
