Is there a way to change FPS via options in an animated curve?
Budgie
I have several figures generated by ZeroPolePlot command, I feel the figures are not the size which I expect, so I can make the figures a little bigger or smaller by dragging the edge of them. But for several figures, it is difficult to make them to be just the same size, namely, all the figures' height=200, weidth=200. In one thread, Mr. Robert...
I am using maple x64 to read/ open some large TIF files.   The files are 57 Mb each and I want to open 16 of them.  Maple looses kernal connection twards the end of the calculations each time.  This is anoying. Is there a way to fix this?
If I take the result form y and defign it as y and delete x them maple will calculate 1 more function set.
document setup;
x=read-image (using the actual maple commant)
y=entropy (x...
The orginial equation to solve is : x" + F(x) = sin 4t
initial conditions : x(0) = 0, x'(0) =1;
F(x) = { bx, x>= 0 and ax, x<0}
I need to do three different values for b = 1, a = 4, then b = 64, a = 4, finially  b = 36, a = 25,
Thanks for any insite I am new to the program.
Courtney
I have a simple request that I hope someone can provide, I do not think it would be too much trouble.
I use Maple 12, hence no Maple cloud, but while viewing one of the maple 14 demonstration videos there was a Maplesoft document in the cloud called -  Example: Mortgage calculator by maplesoft, I would like to have a look at it.  Upon using google and the maplesoft application center, I was unable to find such a document. I am guessing it only exists in the maple cloud.
Maple.mw
SORRY IGNORE THE LAST GRAPH AND PLOT IT NOTHING TO DO WITH THIS QUESTION!!
I'm having a few problems with differentiating in Maple. I have a potential function U given by:
U[c] := (1/2)*r^2+M[1]/r[1]+M[2]/r[2];
U[r] := r^2*(M[1]*M[2]-3)/(2*c^2)+((x(tau)+diff(y(tau), tau))^2+(y(tau)-(diff(x(tau), tau)))^2)^2/(8*c^2)+3*(M[1]/r[1]+M[2]/r[2])*((x(tau)+diff(y(tau), tau))^2+(y(tau)-(diff(x(tau), tau)))^2)/(2*c^2)-(M[1]/r[1]+M[2]/r[2])^2/(2*c^2)-M[1]*M[2]*(1/r[1]+(1/r[1]-1/r[2])*(1-3*mu-7*x(tau)-8*(diff(y(tau), tau)))+y(tau)^2*(M[2]/r[1]^3+M[1]/r[2]^3))/(2*c^2);
I try to make a file using the fopen command, and maple keep telling me there is an operator missing:
fprintf(fd,'sous-total=%.2f$ \n total avec taxes=%.2f \n montant arrondi=%.2d$',sous_total,total,arrondi_total);
I used fopen before writing this, this line seems ok, I don't know why maple tell me this.
Can I have your help with this ?
Hi All,
Is using the NAG package the right way to go about creating the delaunay triangulation of a set of points in 3 dimensions. My points all lie on a surface in R^3.
Hi All,
Recently I upgraded to Maple 14 from Maple 13, and I've encountered a strange behavior in Maple 14 that doesn't appear in Maple 13. By the definition of Spherical harmonic functions in Maple,
SphericalY(2*l, -2*l, theta, phi) = SphericalY(2*l, 2*l, theta, phi).
And this is true in Maple 13, however not Maple 14. Can you reproduce this behavior in Maple 14? Or have I done something else that might be causing this?
Thank you for any help you can provide.
Hi there,
I have defined an own type MyType wich is internally just a list ['MyType', A, B] with let's say two lists A,B and the symbol 'MyType' as first element (to identify the type).
Now, if I define
X := MyType('MyType', A, B);
is there a possibility to extract A out of X by something like
X[2]
or even better X[1] (thus skipping the first one)? The only thing I know is op(2, X).
I need to create a new bernoulli distribution such that P(I=1) = q = 1-P(I=-1).
I did U:=Distribution(PDF=(t->piecewise(t=-1,1-q,t=1,q,0))); but Maple gives me back:
module() option Distribution, Continuous; export...   instead of:
module() option Distribution, Discrete; export...  since the distribution is discrete!!
Do you know a way to force U to be a discrete distribution, cause otherwise I get all moments=0.
hi all
is there any (possibly simple) way to distribute a piece of maple software not allowing external user to access the source code ?
Translating to C, compiling and then including as an external function is very awkward procedure.
thanks in advance
I'm trying to solve numerically an ODE system with piecewise. And this piecewise is very important for this task.
This system describes behavior of a pulley with friction. There are some constants: m, c, g, mu and J. Values of this constants are not important.
> sys := m*a(t) = piecewise(a(t) < a0, F0*time, a(t) >= a0, 0), v(t) = diff(x(t), t), a(t) = diff(v(t), t);
> m := 5; F0 := 10; a0 := 5;
> initialconditions := x(0) = 0, v(0) = 0;
First 1909 1910 1911 1912 1913 1914 1915 Last Page 1911 of 2457
