How to graph a function f(x)=x^2-8x+20. Then use Maple to find all the real and complex zeros?
I have a small Maple program which is manipulating lists which have a habit of becoming too long for maple to handle, which yields the error "
TaiChi.mw
The appendant is a figure I generated in a leisure time a fews days ago. There exist 3 problems, I feel they are a  challenge to me. The third problem is:How to rotate the figure automatically? Like this. Can you give me some advices? Thank you very much! Best Regards!
I am trying to calculate inverse laplace of a 3*3 matrix (answer1 matrix). Find below the maple commands i used.
>with (linear algebra):
A:=<alpha,p11,e11|0,o11,-e11|a,m11,0>
N:=<s,0,0|0,s,0|0,0,s>
k:=N-A
Z:=MatrixInverse(k)
B:=<0,-m11,0>
C:=<1,0,0>
X0:=<isalpha0,ilalpha0,vcalpha0>
answer1:=Z.(X0+(ScalarMultiply(B,uinvalpha/s))+(ScalarMultiply(C,ealpha/s)))
 Hi mates!
Can anybody tell me - is there in maple something like Paskal's begin and end for if-operator?
big thanks in advance)
what I dont understand is the purpose of the second order cone constraint.
The definition is: The first element must be at least as large as the Euclidean
norm of the remaining elements. The euclidean norm for R^3 is the distance from
origo to the point [x,y,z] due to pythagores theorm ie A^2+B^2=C^2 where
C is the distance from origio to the point[x,y,z]
Again for R^3 then we have [x,y,z] then x > the euclidean norm for (y,z) which
means that x> sqrt(y^2+z^2...
i wrote in Maple 14 this procedure:
in result i had error "Unable to parse" inline local k.
But it normally works in Maple 13. Plz tell me about this. I'm a new one in this. Thank you!
Hi, i have a problem with Units; Basically my problem is that if i try to get the square of a variable with units only the value of the unit is squared not the units. For example:
> Z := 5*Unit('ft');
> Z^2 = 25 Units:-Unit('ft')^2
I dont know if my copy paste attemp is clear enough.... but basically the units are not being squared, the ^2 is placed outside the brackets and is not taken into account in further calculations. The result i am looking for is something like this:
I would like to generate a symbolic sum of the first "n" derivatives of a function.
For example, f = 1/(1-x^4)
sum(f^(n),n=0..3)
The response from Maple is not as expected.  The first term is:  -1/(4*(x-1)) and the subsequent terms are less recognizable.
If I use "seq" with the same syntax, I end up with a list that includes the function and the first 3 derivatives.
I have also tried:
sum(diff(f,x$n),n=0..3)
I want to calculate for example MultiInt(x,[x,y]) or MultiInt(y,[x,y]), etc.. in a triangle whose the coordinates of the three nodes are (x1,y1), (x2,y2) and (x3,y3).
Thanks for any help
Kamel
HI,
I wannt to ploting vector form, such as [a_i + b_j + c-_k =0].
This vetor is not matrix form but equation form with direction.
I also express magnitude of vector and direction of vector in plot.
For example, I define a vector, 3*i + 2*j + 1*k = 0, and I want to ploting in 3-Dim with direction.
Waiting everybody advise.
Maple version : MAPLE11
Major : physics
Hi there,
I was woundering if there is a function implemented in Maple11, where I can enter a function and it's domain, and the output is the range. For example:
Entering f(x)=x^2, and the Domain x in (-1,2), I would want Maple to tell me that f(x) is in [0,4).
Is there such a function implemented? I need this quite often, most times on functions from R->R, but also more general for functions from R^n -> R^m. I know that in some cases you could...
I was wondering if there's a simple way to add something like an interpolation loop to a procedure. For example, say I have a function of 2 vars which is expensive to compute, f(x,y). I can use option cache to speed up points which are already computed, but is there an easy way to interpolate between them using ArrayInterpolation? That is, if f varies on scales of order 1, if I have calculated it at 0.1, 0.2, then It can be guessed with a spline at 0.15 accurately enough. What...
The question is to find the area bounded by x = 0, x = 4, y = 0, y = 1/(1 + x6).
I am assuming I am going to use int, but I don't really know where to go from there.
First 1913 1914 1915 1916 1917 1918 1919 Last Page 1915 of 2457
