dear community
I have  problems 1): in solving "rational difference equations" in Maple.
what is the code for solving this kind?
2): plotting difference equations
3):openf and printf command" how I make my results in the same folder as a table?"
Help_Lplot.mw
I cannot get the proc Lplot to work in the worksheet above. Will someone please help?
When I type "hypergeom([a+1,b+1],[c+1],z);", Maple switches "[a+1,b+1]" to "[b+1,a+1]" when using the 32-bit command-line interface.  This does not happen when using the graphical java user interface, nor with the 64-bit version...
Why does this happen?
-- Regards,
Franky
I'm having trouble using the Jacobian command for predefined vectors. I have defined several 3x1 matrices, concatenated them to a 12x1 matrix, then when I'm taking the Jacobian I get the following error:
Error, invalid input: VectorCalculus:-Jacobian expects its 1st argument, f, to be of type {Vector(algebraic), list(algebraic)}, but received Matrix(10, 1, {(1, 1) = v[x], (2, 1)...
Can anyone tell me what I'm doing wrong here?
Thanks so much in advance!
I need to find the eigenvalues for a matrix using the power method in Maple 14 . I want to iterate Xn+1=PXn until it has reached a certain degree of accuracy where P is my matrix and X is a column vector.
I have tried:
> while(abs(X1-X0)>0.0000001);
> do
> X1 := X0
> X1 := PT.X0
> end do;
but I get this error: 'Error, unable to parse'
Please could someone help?
upload.mwDear all, Can someone find what my mistake is?
Hi to all,
I would like to know where if I could plot two functions (both are computed by "if statements") on the same graph and could maple read "where" like VB (if ...where...end if)
Your help is appreciated
hi
i have tried Maple help but could not find any answers.
would appreciate some help on how to construct an algorithm for a Pell's equation with D = 29 (x^2 - D*y^2 = 1)
That is x^2 - 29*y^2 = 1.
i know that there is an infinite number of solutions, but would appreciate the first 5.
(x_1, y_1), (x_2, y_2), ... , (x_5, y_5)
many thanx,
antonio
hi. i write a program consists a for loop in which cycle 'i', x[i] and hz[i] is calculated.
now i want to plot hz[i] correspond to each x[i].
this code is working but how to brief them?
hhz := piecewise(x < X[1], hz[1], X[1] < x and x < X[2], hz[2], X[2] < x and x < X[3], hz[3], X[3] < x and x < X[4], hz[4], X[4] < x and x < X[5], hz[5], X[5] < x and x < X[6], hz[6], X[6] < x and x < X[7], hz[7], X[7] < x and x < X[8...
I have the following procedure that generates Sierpinski's triangle:
seirpinski := proc (n)
> local Mat, Vector1, Vector2, Vector3,
> Prob1, Prob2, Q, prob, counter, fractalplot;
> Mat := linalg[matrix]([[.5, 0.], [0., .5]]);
> Vector1 := linalg[vector]([0, 0]);
> Vector2 := linalg[vector]([0, 0.5]);
> Vector3 := linalg[vector]([0.5, 0]);
> Prob1 := .333; Prob2 := .333;
> Q := linalg[vector]([0, 0]);
> writedata("fractaldata", [[Q[1...
I have a vector of points which sample the graph of a spherical function, say f. My definition for the graph of a spherical function is :
points[k] = f(x_k) * x_k     where  x_k \in S^2   .
Right now I use pointplot3d to obtain a rough visualization of my function. However, I'd like a plot that looks like a solid surface, the way plot3d output can look.
Any ideas?
Thanks for any help!
How can I calculate F(6/7) - F(-6/7) to find probability related to central limit theory?
I need to first use the F:=x-->y to define F. What I'm getting is not helping me answer my question. could someone please tell me the steps to find an answer?
I am running MAPLE 12 on WINDOWS XP & recently updated my JAVA and now anytime I try to use HELP, MAPLE hangs.  I have to enter the TASK MGR to terminate MAPLE, because I cannot do anything else.
Anyone have a FIX on this?
Hi I'm Oscar and I'm new on this forum.
I would like to know how does Maple manage Normal random variables when I want to obtain a symbolic expresion like the following (use of Variance to compute symbolically the variance of a combination of normal random variables with its characteristic parameters also symbolically defined)
with(Statistics):
x:=RandomVariable(Normal(Mux,Sigmax)):
y:=RandomVariable(Normal(Muy,Sigmay)):
z:=Variance(x^2+y^2+x*y+c): (1)
Hello people, I have a question about an equation, I have to solve on maple.
So i have
>p:=a+bx+cx^2+dx^3;
>I1:=int(p(x),x=0..1);
>I2:=int(x*p(x),x=0..1);
>I3:int(x^2*p(x),x=0..1);
>I4:int(x^3p(x),x=0..1);
and i have to find a,b,c and d
the only thing i know is that I1=1, I2=0, I3=0,I4=0
can someone can help me. Thank you
First 1914 1915 1916 1917 1918 1919 1920 Last Page 1916 of 2457
