I am new to Maple and doing a trivial calculation raised a few questions. I tried to calculate the average density of a wire with the following specs:
  • diameter = .40 inches
  • length = 1000 feet
  • weight = 61 pounds
Here's what I have come up with.
with(Units[Standard]):
wirediameter:=.40[inch]:
wirelength:=1000[ft]:
wirevolume:=(wirediameter/2)2 * Pi * wirelength:=
VEH_We.mwDear Community
I try to plot a rather sophisticated function with Bessel functions and several roots of a transcendent equation, but failed. I've specified all parameters, functions, etc. yet I still get an error message. What do I do wrong? I've uploaded the file,  if you could have a look.
Tx in advance, best regards
Andras
I have 3 matrices and I want to generate the group associated does anyone know how to do this without doing it manually?
Why is it that the command
plot( 'dphidx'(x,y,10,5,1/10), x= 0..1, y=0..1)
gives a good plot but I get an error for
evalf(Int(Int( 'dphidx'(x,y,10,5,1/10), x= 0..1) y=0..1))
Error, (in dphidx) cannot determine if this expression is true or false: 99/10 < x and x < 10.
Here's the code for dphidx:
dphidx:=proc(x,y,xj,yj,h) local v; if xj - h<x and x<xj then if yj - h<y and y<yj+h then if y<=yj...
How to find with Maple all symmetric matrices of  size 5, whose entries are 0,1, having only strictly positive eigenvalues?
One of the examples in the Overview of Vector Calculus documentation is int(x^2+y^2),[x,y]=Circle(<0,0>,r) .  I can find no documentation on "Circle"  What does the above expression mean anyway?
Ratch
I made an upgrade from Maple 13 to 14, but a program i wrote with maple 13 (ode event handling) simply is incorrect in maple 14. The events aren't recognized anymore. What is the problem?
Thank You.
I have created a procedure called Tproc with 3 arguments (t,k,b). Now I want to calculate the partial derivatives of this procedure with respect to k and b. Looking at the help page of fdiff, i tried this:
fdiff(Tproc, [2], [2,10,2.5])
but all maple returns is:
I want to solve an ODE but the result is not a polynomial as it should be, it just writes some integrations instead of solving this integrations. I show this problem as:
when I integrate the equation, instead of integrating it just writes integrate of the expression, what is wrong? I'm willing to integrate regard to x. My whole worksheet is uploaded. What should I do? I just right clicked on it and used integration. I'm using maple 13. As you see I want to solve the last ODE (F[0...
When a procedure is called that is nested inside of a module, it returns its own name rather than the value it calculates.  E.g. here is a very simple package:
somePackage := module ()
  export someproc;
  someproc := proc (yr)
    return (2010);
  end proc
end module;
That compiles fine.  But when this is executed:
somePackage[someproc];
The...
I guess someone is kidding with me...
I want unsubscribing of this s... place!
when calculating the following equations
int( exp(t*int( (m/2*(diff(x, t))^2-exp(x)), t)), x)
maple give
-Ei(1, t^2*exp(x))
what is Ei? how to show result normally?
Can anybody please help me I posted this question last week and didnt get the response I was looking for. It is a question about explicit finite difference methods for pricing an option.
I understand the mathematics behind this and everything but I am not able to code it. This is where the probelem lies.
I'm using Maple 14 on OSX 10.5.8.  I have a lot of expressions that look like this:
sum(a[n+2]*x^n*(n+1)*(n+2), n = 1 .. infinity);
(which doesn't seem to be rendering here...so in 1D form)
My problem is the when using default fonts and 100% zoom the plus signs in the subscripts aren't...
I'm hoping that someone can help with this.  Below is an example of what I would like to do (part of a larger application):
> roll := rand(0 .. 1);
> roll();> s0 := %;
> roll();> s1 := %;
With each execution, this will yield values for s0 and s1 that are randomly...
First 1915 1916 1917 1918 1919 1920 1921 Last Page 1917 of 2457
