Good Night.
I have problem when i am using ODE, because i have an error : (in plots/odeplot) curve is not fully specified in terms of the ODE solution, found additional unknowns {x3(t)}
I do not know how I can
I need to create a 3d plot, but color the surface depending on the function's sign, say red for positive values, green for negative. How can I do that?
Thank you,
Ozgur
I want to call Maplets from Flash,
1.I have been using TA for some years but we have only recently moved from version 4 to version 6. In versions up to version 5, when a question was edited there was a two stage saving process ie. the question was saved and the question bank was saved. Only after these two saves did assignements containing the question reflect the edits in the question. I have an assignment which depends on a question in TA6 and I have edited saved the question. The assignment does not reflect...
I would like to have an optional input value in my procedure. It could be of type string or numeric value.
Example:
bgp:=proc( x, y, z, optional) local bgp, A;
bgp:=Array(1..2);
bgp1 :=pointplot3d([x, y, z]);
# if the optional value exists:
bgp2 :=textplot3d([x, y, z, optional]);
A:=bgp1;
# and if the optional value exists:
Hello to all,
I have some data and i want to create a 3d columngraph from them but i can't  find a relative command in Maple.. I want something like the "AreaChart" command without the lines connecting the points..One solution is the Pointplot 3d, but if there is a way to do it with columns is much more preferable..!
Thanx!
polar_circle.mw
It is a problem which exists in my mind for a long time. Can any one give me some advices? Thank you!
Best regards!
Hi guys,
I've a simple question, can I run a maple mpl file with options? I mean, instad of
maple file.mpl &
doing
maple file.mpl --option1 value 1 --option2 value2 etc &
If yes, how do I instruct the code about what to do with those options, eg assign them to variable?
salvatore
How to output the solution given by pdsolve as a *.csv or a tab delimited text file?
Maple has got to really work on its help documentation.
Thank you,
with plots
Eq[1] := 5*(diff(f(eta), `$`(eta, 3)))+(m+3)*f(eta)*(diff(f(eta), `$`(eta, 2)))-(2*m+1)*(diff(f(eta), eta))^2-(2*(2*m+1))*h(eta)-(m-2)*eta*(diff(h(eta), eta))
Eq[2] := g(eta)-(diff(h(eta), eta))
Eq[3] := 5*(diff(g(eta), `$`(eta, 2)))/Pr+(m+3)*f(eta)*(diff(g(eta), eta))-5*m*g(eta)*(diff(f(eta), eta))
BCs := [f(0), (D(f))(0), (D(f))(18), g(0)-1, g(18), h(18)]
pars := {Pr = .1, m = 0}
for i to 3 do eq[i] := subs(pars, Eq[i]) end do
I myself have written some programs of math in Maple (e.g. ABC.lib, ABC.ind, ABC.mw).
Who could help me how to upload these programs for everyone using easily without downloading and setup them? Thank you so much!
I wrote some simple functions in Maple 13, called "myproc" file,
and used startup code (edit-->startup code) to initialize it in a worksheet by: read "myproc";
Now I am using Maple 14, it does not work, says, "unable to read", sort of thing.
I have also tried to rename the file to myproc.m and read "myproc.m";
does not work either.
Is there any compatibility problem?
casper
I want to call Maple from Excel, this works so far. Problems in the attached Excel sheet:
- The result of a Maple command (components of a vector) will not be placed into separate cells. How can this be done ?
- To auto-update the solution when changing the input matrix, for each component of the solution vector the complete matrix needs to be recalculated. Surely, there is a better way to do this.
there are several method to provide solve recurrence problems  in Maple,such as define ,rsolve,etc.here ,i meet a problem.
i want to compute the function Gamma(n), if n is a posint ,only given recurrence relation f(z)=(z-1)f(z-1),initial condition,f(0)=1,then i can get the true result with rsolve,of couse,i had made  an ansatz that z is n::posint.yet ,z is not posint? To suppose z  equal to 5/2, (2*n+1)/2 more generally,how can get the answer((2n-1)!!*Pi/2^n).
First 1912 1913 1914 1915 1916 1917 1918 Last Page 1914 of 2457
