I see how to get the solutions of the Schroginger eqn
I have the function r=sqrt(1+(cos(2*theta)) and theta E [0,pi/2] I need to find the arc length of this function using maple 14
so far i have this
with vector (calculus):
ArcLength(sqrt(1+cos(2*theta)), theta=0..pi/2)
I dont know what to do after this
"I" is reserved for square root of -1.  I don't use complex numbers and want to use "I" in my equations.  How do I go about doing this?  I tried to unprotect it with a number of variations of quoting "I".
I'm using document mode with Maple 13 on Apple.
Thanks for your help.
My question is how do i get Maple to simplify every calculation that involves units automatically, right now i have to do this manually for every single one.
For example: This values all come from variables wich have units assigned to them.
Then i hit right click, Units -> Simplify and i get this:
I am using dsolve(..., type = series) to solve differential equations in the form of a power series. I plot these power series with different orders to observe how they converge. I use quite large orders (25 or even 50), and generating these solutions is slow.
I would like to generate power series with order 25, for example, and then truncate it to order 24 directly, instead of having to call dsolve a second time. I was hoping this could be done somehow using convert...
Hi All! I need your help.
I use the Student:-LinearAlgebra:-LynearSystemPlotTutor() and i can print it with:
print(Student:-LinearAlgebra:-LinearSystemPlotTutor);
then i got the:
module ()
local ModuleApply, LinearSystemPlotMaplet, PlotOptionsWrapper, UpdateDisplay, NewMatrix, the_plot, sysML, helpStr, linSysMaplet, M, axisLengthInfo, axisLabelInfo, axisType, axisScaling, plotOptionsReturn;
end module
If i would print the local...
If you type 1/1e6; then you get 0.000001000000000.
If you type 1/1e7; you will get
How can i draw SUN AROUND 9 Planets with ANIMATION...how can help me
http://kayzen.az/uploads/images/5/2/5/5/9/c60fc9723b.gif...i want to draw this Picture in maple.how can help me or give an idea...
I'm under pressure to complete the following plot for a Masters project. I just can't seem to find where the errors are. I'd be very grateful if anyone can help.
x*,y*,zare independent variables
r*(x*,y*,z*):=(x*2+y*2+z*2)0.5:
r(x*,y*,z*,t):=  (r
would you please help me?
I have a big problem in differentiating with maple!
here is my equation.
L := (alpha, beta, theta,alpha(t),beta(t),theta(t))
how can I find diff(L, alpha) ?
L=(1/2)*I[a]*(diff(alpha(t), t))^2+(1/2)*I[b]*(diff(beta(t), t))^2+(1/2)*I[c]*(diff(theta(t), t))^2+(1/2)*m[3]*(b^2*(diff(beta(t), t))^2+(1/4)*C^2*(diff(theta(t), t))^2+b*c*(diff(beta(t), t...
Hi, friends
The physics package was provided a good tool to compute Commutator or anticommutator relations. Here, I met some problems.
Example 1:
      restart: with(Physics):Setup(mathematicanotaion=true):
      Setup (op={p[x],p[y]},p[z]):
      alg:=%commutator(p[z],p[x])=2p[x], %commutator(p[z],p[y])=-2p[y], %commutator(p[x],p[y])= p[z]
Why the "Mean" command of the "Statistics" package gives the correct result with MAPLE 12 and MAPLE 13 and not with MAPLE 14 ?
with(Statistics):
X := RandomVariable(('Uniform')(-1, 1)):
Y := RandomVariable(('Uniform')(-1, 1)):
pdf := simplify(PDF(sqrt(X^2+Y^2), rho)):
R := RandomVariable(Distribution(PDF = unapply(pdf, rho))):
The mean may be computed using (the answer is correct)
int(rho*pdf, rho = 0 .. sqrt(2)):
I'd like to numerically compute integrals of the forms:
int(exp(-t)/((-3+2*exp(-(1/10)*t))*(-3+2*exp(-(9/10)*t))), t = 0 .. infinity); evalf(%)
where there are much more terms in the denominator, e.g.,
Int(e^(-t)/(product(-3+2*exp(-.1*(1-.1)^i*t), i = 0 .. A)), t = 0 .. infinity); evalf(%)
for some positive integer A. Even when I have three terms it takes so long... So how do I compute such integrals numerically with maple; what's the efficient...
Hi everyone
I'm new to the forum, but I hope you can help me with a problem concerning import of pictures to Maple. I'm working with diffraction from a rectangular and circular aperture. I haven't made the experiment yet, but I've thought about taking some pictures of the diffraction pattern and then use Maple to calculate the intensity of the light to make a three dimensional plot (intensity as a function of position).
Right now I just want to import a picture...
First 1906 1907 1908 1909 1910 1911 1912 Last Page 1908 of 2457
