                     gama2 q2 - 2 gama1 XA=0
                    [-1] q1 + [1 - 2 q1] - C=0
              [-1] q2 + [1 - 2 q2] - C + gama2 XA=0
Hello everybody,
I have this equation J:
> J := Matrix(2, 6, [[j41, j42, j43, j44, j45, j46], [j51, j52, j53, j54, j55, j56]]);
it's a 2 times 6 matrix made with the results of other equation, each one of those small j's are long analytical terms.
Later I want to generate a Matlab code of J using this:
> Matlab(J, resultname = "j4", output = "file.m", optimize);
I use the optimize code at the end because then I avoid getting...
Is there any way to use the final answer obtained on a previous section/subsection and use it on a different section/subsection on the same file?
Thanks, Jose
Hey all,
 I have created a nested while loop to investigate the Riemann zeta function:
for q to 10 do
 m := 10^(-q);
  for s from 2 to 10 do
   n := 1;
   b := 1;
    while b >= m do
     b := evalf(abs(Zeta(s)-euclid(s, n)));
     n := n+1
  print(m, s, n-1)
 end do
end do
it...
Is there any easy way to browse 3D matrices within maple, other than storing matrices in an array?
How to find the shortest distance between  two points on a cube with Maple? The related twodimensional problem was considered in MaplePrimes, but the thread  seems to be lost. Here are the results of the "shortest distance" search in MP. The results of "shortest distance between two points on a cube" googling do not encourage too.
There was a recent exchange I was a part of on Maple classic versus standard, etc. It disappeared from the list of "recent discussions" so I tried to track it by other means. A keyword search did not immediately return a helpful link, so I thought I would click on my profile and look for my recent comments from the lists there. But I could only find a list of "questions," "answers" and "posts". My contribution there was merely a "comment" and I can't seem to find any list about those...
I don't know why I can not login maplesoft and mapleprimes again. Everytime I login the website, www.maplesoft.com and www.mapleprimes.com, an information returned, as the picuture illustrated.
The only way I may login the website is click on the links in my E-mail box. These links are the questions feedback. It seems that if I login the homepage, then...
I just downloaded Maple 15 and am trying to install on a 64-bit Windows 7 machine.
About halfway through the installation, there is a step where you are either supposed to supply the path to a batch file that will supply the environment variables that will locate Microsoft Visual C compiler, or supply them later as an option. The instructions say that Maple has a default batch file that will do this, but when that option is chosen, nothing shows up in...
I used to be able to view mapleprimes saved webpages (saved as type archive) offline.
Now I cannot.  All the data is in the file it just won't load the answers and comments part of the page offline?  Does mapleprimes have some script that doesn't run now for offline use?  That's terrible.  This means every page I have saved over the last 4 years is useless unless it loads the answers and comments.  Now they are saved in the file but...
How to find the limit
limit(int(abs(sin(f(x))), x = 0 .. T)/T, T = infinity) assuming T::positive;
with Maple in the cases: a) f:=x->x^2; b) f:=x->x*exp(x)?
PS. Or to establish its nonexistence.
To share a maple document, I found this Maple help.
To share worksheet content:
1. In Maple, open the worksheet that contains the content you want to share.
2. If you want to share a worksheet selection, select the text and objects in the worksheet. If you want to share an entire worksheet, you do not need to select any text or objects in the worksheet.
3. Expand the MapleCloud palette.
4. From the drop-down list in the palette, select...
Ive tried this for hours and can't get it to work. Any help would be greatly appreciated. I need to
find a 10 significant figure approximation to the 10th derivative of
evaluated at x = -2.
Ive tried using this maple command:
evalf(subs(x=-2,diff((sin((x^2...
Why do I get different results for these four command? BTW only Result #2 is correct.
> evalf((1/2)*sqrt(3.0), 5);
0.86605
> evalf((1/1)*sqrt(3.0*(1/4)), 5);
0.86603
> evalf((1/1)*sqrt(3/4), 5);
0.86605
> evalf((1/2)*sqrt(3), 5);
0.86605
I have read the answer to a similar question,
I want to wrap a 3d matrixplot histogram around the surface of a cylinder.  How can I do that?
If my matrix is a random 12x12 matrix and I use heights=histogram to plot it
restart;gc();
a:=Matrix(12,12,rand(1..20))
b:=matrixplot(a,heights=histogram,shading=zhue)
and map it onto a surface...
First 1903 1904 1905 1906 1907 1908 1909 Last Page 1905 of 2457
