Use a change of variables to find the volume of the solid region lying below the surface f(x,y)=(2y-x)^4sqrt(x+y) and above the parallelogram in the xy=plane with vertices (3,5) (2,6) (10,10) and (11,9)
Graph the 'ice cream cone' formed ny the upper half of the sphere x^2+y^2+z^2=16 and the cone z=sqrt(x^2+y^2) using maple, and find the z-coordinates of its center of mass.
Graph the region insde the one-sheeted hyperboloid x^2+y^2-z^2=9 between z=4 and z= -4 using maple and find the volume of this region
Graph the solid common to the cylinders x^2+z^2=4 and y^2+z^2=4 using maple and find the volume of the region common to the cylinders.
I'm suppose to graph the first octant portion of the surface z=4-x^2, 2≤y≤5 using maple and find the volume of the solid over the xy-plane and under the surface.
I use a for loop to step through the operands of an expression and do a calculation on each operand. I am then unable to add up or otherwise access for manipulation the result of the for loop and wondered how this could be done. What I mean is as follows. I have the expression w
w := 2*(1/2/Pi+Q*cos(k*phi))*Q*cos(k*phi)*(exp(-1/2*sigma^2*k^2)-1)*t*(1/2/Pi+Q*cos(k*psi))/(beta^2*(1+beta^2*(1/2/Pi+Q*cos(k*phi))^2))+(1/2/Pi+Q*cos(k*phi))^2*Q*cos(k*psi)*(exp(-1/2*sigma^2*k^2...
How can I see the body of Newton procedure in student package?
fsolve command return equation solutions in { }, for example {x1=5,x2=6} which the x1 and x2 are not numeric variables and can not be to use in the later. How we can use x1 and x2 similar numeric variables, for example after fsolve command we use "printf("%.10f",x1)" or y=sin(x1*x2) commands.
This exponent is a number of order 2011! and Maple operates with such quantities. However, the simpleminded approaches fail:
> for k to 10 do is(`in`(2^k, numtheory[divisors](factorial(2011)))) end do;
Error, (in numtheory:-divisors) object too large
> for k to factorial(2020) do if is((factorial(factorial(2011))/2^k)::posint) then NULL else print(k) end if end do;
Error, (in fact) Cannot allocate memory (size=100728832)
I'm using Maple 11 and pdflatex. I'm trying to export Maple code to latex.  To this end, I've exported my maple file as a latex file and included the maplestd2e package in my tex document. However, from compiling the tex file I only obtain pdf output for those parts of the original maple file that represent output. For example, the following tex-code correctly produces the word 'true':
\mapleresult
\begin{maplelatex}
\mapleinline{inert}{2d}{true}{\[\displaystyle {\it true}\]}
hi
how we can design of experiment through maple?
Maple 11 did a reasonable job of breaking up long output being exported to LaTeX, but it wasn't always
perfect. I had hoped that Maple 15 would do better, but it seems to do worse.
I can't get it to split long output lines into anything reasonable. The latex command is even worse.
I've tried every "export" option I can think of, without success.
Here is an example (see below):
Does anyone know how to induce Maple 15 to export the following Maple result ...
Hey guys. Can you help me with this problem? I'm trying to plug in a snowflake equation in finding the perimeter of a snowflake on the nth step. The function is as follows:
p:=n->(3*(3/4)^k, k=1..n);
I'm trying to find the limit of this equation and it's suppose to give me infinity by using this command:
limit(pn(n), n=infinity);     but it's not quite giving me the limit. The limit is...
hello
I have a large data series and i need to get derivative (numerical derivative) of them. how can Ido it?
First 1899 1900 1901 1902 1903 1904 1905 Last Page 1901 of 2457
