Can we assign a process to a portion of threads thereby limiting it's use on the cpu?  Or assign a processs that continually runs on a portion of the cpu while retaining the bulk processing power for other tasks other worksheets in Maple?
Fogive me here if I lack understanding:  As an example set aside say 1000 threads for the cpu and let one process run on one thread in the background essentially using only 0.1% processing power and leave the other 999...
I have two functions,
f(x) and its derivative...
how could i plot them together in a one single graph??? could you please help me???
Hello folks,
I have to admit I am somewhat new in using maple as well as in this board. However I used the search engine and could not find the answer to my question.
I coded a little program that - among other things - should randomly draw one entry from a set of integers. Thus I use the function choose from the RandomTools package. From other software packages (for example stata) I know that usually one would set a seed for those pseudo random numbers to be...
Can anyone explain the method that was followed in "Box Discretization" scheme in Maple Help?
Am trying to discretize 4th order terms in space..... d^h/dX^4 and third and second order in the same way....
I am computing eigenvalues of a 3X3 square Matrix that contains symbolic elements and many zeros. There are 2 zero eigenvalues and 1 non-zero. I'd like to request Maple to order the eigenvalues in a certain way, with the non-zero eigenvalue first. Oddly, the command LinearAlgebra:-Eigenvectors(A); orders them in a seemingly random way, with the non-zero eigenvalue either first or last, never in the middle. The LinearAlgebra:-Eigenvalues(A); commands seems...
Maple evaluates
> sum(1/z^2, z = 1 .. infinity)
to (1/6)*Pi^2. What do I do when sumation is over all even positive integers? Is there any  closed-form symbolic formula for this case?
Above is the minimal example. What I need is to compute
> sum(2*binomial(m-1, k-1)*binomial(n-1, k-1)/binomial(m+n, m), k = 1 .. infinity)
where k belongs to a set of only even positive integers, not any posint. The second expression evaluates to 2*m*n/((m+n-1...
dsolve command doesn't work :(
it's very important =\
y*(dy/dx) + 2b*y*|y| + x*k^2 = 0
I'm new to Maple and am trying to solve a set of simultaneous equations. The equations have two independent variables x and T (contained within the letters "a" to "l" and "G" in code below) and 5 dependent varaibles X,Y,Z,W,V. Ultimately I want to solve for X...V with various values of x and T, but at the moment I'm struggling to get my code to work for just one x and one T value. The code I have so far is:
> solutions := solve({0 = -a*(h-Y-X-Z-V+W...
Dear guys! My question is: "how can I evaluate x when I fix y for an example equation y:=x+x^2". for each value of x we have a value for y. we can obtain it for example with "eval". but how about in this case?
I have a maple exercise where it ask me to find the limit of a sum, here what's I type
f:= 2*k/(2*k+11);
g:= sum(f,k=1..n);
limit(n^(11/2)*g,n=infinity);
It spit out the answer infinity
but the answer is 10395/64*Pi^(1/2), can anyone tell me what am i doing wrong
   We have four points A, B, C, E, which form a convex polygon in the plane Π, and a point S, which doesn't belong to  Π. The points A, B, C, E, and S form a pyramid. The following distances are measured with some error: |AB|=2.9, |BC|=4.43, |CE|=5.10, |EA|=5.2, |AC|=2.29, |BE|=3.17, |SA|=3.77, |SB|=4.27, |SC|=3.66, and |SE|=4.36. In fact, there doesn't exist a pyramid with exactly these distances. The problem arises: to find the numbers XAB, XBC, XCE,...
Hey there, I am trying to plot R0 vs x with my output of a loop. Just wondering how I go about this and I am not very coding savvy, so my apologies. My code is below.
for Lambda from 40 to 80 do R0 := eval(R[0], {mu = m, delta = del, gamma = g, omega = o, d[1] = dk, d[2] = dc, alpha[1] = ak, alpha[2] = ac, beta[1] = b1, beta[3] = b3}); qq := eval(Y, {mu = m, delta = del, gamma = g, omega = o, d[1] = dk, d[2] = dc, alpha[1] = ak, alpha[2] = ac, beta[1] = b1, beta[3] = b3}...
Can one perform animation using the data file.
I want to animate the graph betweeen two variables say x and y, which I have stored in a data file. Does maple support any such operation?
So i need to plot 4*x-x*y^2 = 5 and (1/3)*x^3+y^2 = 1 between x = -10 .. 10, y = -10 .. 10.
I tried:
> f := 4*x-x*y^2 = 5;
> g := (1/3)*x^3+y^2 = 1;
   > plot({f, g}, x = -10 .. 10, y = -10 .. 10)
What did i do wrong?
I am using Maple 14 full eddition (not classic) to represent some equations. I require Maple to calculate the summ from 1 to n of the odd terms only. Below is what I have developed so far off all terms in the series.
Can anyone assist in changing it to odd terms only?
Kind regards,
John
Australia
First 1894 1895 1896 1897 1898 1899 1900 Last Page 1896 of 2457
