If for example
L := [3, 4, 6, 7, 2, 3, 5, 4, 6, 8, 20, 4, 5, 12, 0, 5, 5, 5, 3]:
b := ListTools:-Enumerate(L):
g := plot(CurveFitting:-Spline(b, v), v = 1 .. 19):
gp:=pointplot(b):
display(g,gp)
It is a nice curve but between points at x=12 and x=13 there exists a large dip, and there are a few other smaller...
Hello, I need help in integrating a procedure in Maple 10. I got a numerical solution of a 2nd order ODE as a procedure (using dsolve), and want to integrate it over x=0..1. I tried the recipe from Maple help, but it doesn't go, because I can't separate the solution from the procedure which is a triple - the argument x, the solution itself, and its x-derivative. What should I do? Thanks in advance!
First, here is my code (the last 3 lines are actually a single expression, despite being split over multiple lines below):
with(Statistics):
with(Student):
with(Student[NumericalAnalysis]):
Student[Calculus1][Roots]:
k := 8;
h:=3.1;
Llimit := evalf((size-1)-10*sqrt(2*(size-1)));
Uplimit := evalf((size-1)+10*sqrt(2*(size-1)));
evalf(Int((Int(CDF(Normal(0, 1), h/sqrt((size-1)*(1/x+1/y)))*PDF(RandomVariable
(ChiSquare(size-1...
How do I update  Maple 5 version  files ( or programs)  to the Maple 14  version ? . I mean I've done a lot of programs in the  Maple 5 version many years ago and now ( using   Maple 14 version) I can't visualize my  complete equations and worst my graphics .Could you help me ?
I am trying to export an array of complex numbers to MathML.
I would like the numbers to be formatted a.aa x 10aa + a.aa x 10aa i
Anybody know how to do this?
Regards.
I have this piecewise function:
Mr := theta->piecewise(theta>=0 and theta<=(Pi/(2*p))-(beta/2),0,theta>(Pi/(2*p))-(beta/2) and theta<=(Pi/(2*p))+(beta/2),Br/mu0,theta>(Pi/(2*p))+(beta/2) and theta<=((3*Pi)/(2*p))-(beta/2),0,theta>((3*Pi)/(2*p))-(beta/2) and theta<=((3*Pi)/(2*p))+(beta/2),-Br/mu0,theta>((3*Pi)/(2*p))+(beta/2) and theta<=2*Pi/p,0);
I want to calculate the Fourier serie of this function without giving...
I use a simple for loop below to illustrate. For each loop through the index value I want to add the result of that loop to a list h. This is how I tried to do it but I can't quite get it because the value in h1 gets updated for each step through the for loop.
for i from 1 to 10 do
u[i]:=2*i;
h:=[]; h1:=[u[i],op(h)]
So after the for loop is terminated I want to be left with a list h:= ...
The coefficient of determination also known as R^2 tells how good a fit is. If R^2=1 the fit is perfect an if R^2=0 it's useless. But Maple don't have a native function to calculate R^2. I seached and found this:
http://www.mapleprimes.com/questions/40171-Determining-An-Equations-Accuracy
But it only describe how to calculate R^2 on a
Why does collect only work sometimes?
I will show with a simple example.  I can do this
a := 5*x^2-4*x+3;
                             a := 5 x2  - 4 x + 3
h := exp(x)*a+exp(x);
How to get the polynomial successfully why return error expect a series valuation 1, what do it mean?
l := [12,14,27,35,46,49];
sl := listtoseries(l,x,revogf);
convert(sl,ratpoly);
with(gfun):
gfun['maxdegcoeff'] := 50:
gfun['maxdegeqn'] := 2:
i use number of balls in each basket to get a list, but all functions return fail? where is wrong? and how to use correctly?
l := [0,0,0,2,0,0,0,0,1,1,0,1,0,1,1,0,0,0,0,0,0,1,0,0,1,0,1,1,0,1,1,0,1,0,2,0,0,0,1,0,0,0,0,0,1,1,0,1,1]:
listtoratpoly([1,1,2,3,5,8,13],z);
listtoalgeq(l,y(x));
l := [12,14,27,35,46,49,31];
listtohypergeom(l,z);
guessgf(l,z);
I'm modeling a magnetic field and I don't know how to plot the corresponding vector field:
For each point  M I have the vector B(M) as a list.
Could you explain me how to transform it as a "real vector" first and how to plot these vectors then??
Thanks in advance!
I've got a question about model integration process.
I've tried to solve quite complex mechanical model and this messages have appeared.
Computing initial conditions...
Iterate re-initialization...
done.
Simulating...
CreateDataRecord: using dsolve method=rosenbrock_dae
Generating configuration 1
Integrating configuration...
Re-initializing after event at t=4.94271387307997e-009...
How could we get module which contain this export, for example
I have
m1 := module export a; end module;
 temp := m:-a;
evalb(temp = a);
 # false
evalb(temp = m:-a);
 # true
 but how could I get back the module like this
temp2 := getModule(temp);
temp2;
 # m
evalb(temp2 = m) ;
# true
I'm trying to model a magnetic field with maple.
In order to do that, I compute a (huge) sum and integrals of real and posive numbers.
The problem is that for some points, when I compute the norm of this field I get an imaginary number with a very small imaginary part (egs -2, 27293.1844462+1.42305652280*10^(-84)*I ).
How can I get rid of it?
thx in advance
First 1892 1893 1894 1895 1896 1897 1898 Last Page 1894 of 2457
