When I try to solve a DAE system I got this error:
               Error, (in dsolve/numeric/DAE/applysub) numeric exception: division by zero
Any ideas?
Thanks everybody for help!
Hi to all
I am trying to merge two functions into a single graph. I have discovered the "piecewise" function but however I want to be able to manipulate the variables in both functions and plot a 3D graph to determine the results.
this is what I have so far
Z := proc (t)
if subs(p = 25, (100-p)*(1-exp((-1)*.11*t))/(10.00000000*exp((-1)*.11*t)+1)) < CM and 0 < t then subs(p = 25, (100-p)*(1-exp((-1)*.11*t))/(10.00000000*exp((-1)*.11*t)+1))
of the implicit function 8*x^3+y^3-6*x*y-3=0 with Maple?
How can I save a webpage as a text file? Not the source code. When I save a webpage from I.E. as a text file it seems to strip out a lot of the source code and I end up with a simple text file. Take this wikipedia webpage as an example http://en.wikipedia.org/wiki/List_of_HTTP_headers Now if I use Maple it grabs everything on the page, source code included which I do not want. Is there an easy way or must I create some code in maple (http surgery so to speak) to strip out the excess?
Hello All,
From the list
t1 := [((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2+8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), -((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2+8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), ((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2-8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), -((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2-8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2...
Im new to programming in maple and need some help.
I have this function, lets say it is f= x2 and i have a constant called c (lets say it is 2 for now)
I use the command subs, but this could be wrong.
i write :
subs(x=c,f)
The output the becomes 4, when i would like i to be 22 . Put in other words, how can I get maple NOT to calculate the result?
I am trying to use second quatized operators in the Maple Physics package.  These operators obey the commutation relations:
[psiA(x1),psiB(x2)] = Dirac(x1-x2) and [psiA(x1),psiC(x2)] = 0 for example.  The commutator therefore depends on the arguments of the operators.
Using:
> with(Physics);
> Setup(quantumoperators = {psiA,psiB,psiC},algebrarules={%Commutator(psiA(w),psiB(v)) = Dirac(w-v),%Commutator(psiA(w),psiC(v))=0})
I'm new to Maple and find some aspects of the syntax and UI confusing.  The manual isn't much help.  In the case of "e"...
1) If I type in:    evalf(e^1,10) by just typing the letter e from the keyboard, I get back the letter e.  But if I go into the palette and select the expression e^a, and put it in evalf that way (for a=1) I get back a numerical value for e.  I can see that one of these e's is italicized and one isn't...???
I have been using the pdesolve command to solve the heat conduction equation in an infinitely long cylinder, but now I need to incorporate the convection that occurs at the end surfaces, in the case of a short cylinder.
The following is the code I have been using:
>> PDE := diff(Theta(r, t), r, r)+(diff(Theta(r, t), r))/r = (diff(Theta(r, t), t))/alpha;
>> pdsolve(PDE);
I have tried to add...
The problem is, as said, how can i get a "math output" when having something typed into my package..
An example of this could be:
printf("\Your function is: x^2");
When typing it like this my output becomes x^2, I would like it to become x2 , how can I fix this?
- Slangers
how can i draw a polygon with labeled vertex by numbers which are inside of that polygon§
I have Maple 15.
I used one of the "Assistants" to solve a problem.
It offered me the command line code that would have solved the problem without the Assistant.
I saved that code to a file, and later tried to paste it into a new Worksheet.
It won't execute.  I can't convert it to anything that executes.
I assume Maple is viewing it as text, and not something that is executable.
sol1 := dsolve([diff(x(t),t) = y(t), diff(y(t),t) = -x(t), x(0) = 0, y(0) = 1...
L include kinetic energy
when F = diff( diff( L, dx), t) - diff(L,x)
i need to diff L with respect to dx, however, there is no dx in maple, how to do above equations?
with(DifferentialGeometry):
DGsetup([x],M):
ExteriorDerivative(x^2);
invalid frame: DGframe_data[0][1][2]
how to diff x^2 to get 2*x*dx with above command?
How come that I don't have a Maple Questioner Badge? 2886 people question Maple and I trust it unquestionably?
Even adiban who didn't post anything on this site, has it (as well as 10 other badges and a reputation of 1000).
I have a Pupil badge, which I couldn't get without asking a question - so I've asked at least 1 question.
Let's see if I get it after asking this question.
Alec
First 1890 1891 1892 1893 1894 1895 1896 Last Page 1892 of 2457
