where can I look up, how Maple calculate the function MathieuExponent. By how I mean, which algorithm is used by Maple and how is it implemented,
restart:with(MultiSeries):with(plots):
parvalues:={C=2.02,H_liq=8.74,R=22.11,R1=0.0006};
G:=R3*k*(1-R1)/(C*Pec_i);
F1:=1/(R*S+1-S);
F:=F1*(1-R*G*S);
F2:=Pec_i*F;
A1:=Theta0/C=(exp(F2*(1-S))-1)*(H_liq+1/(1-exp(-C/k*F2*(S))));
R3values:= [0,-1,-3,-4]; colours:= [red,blue,green,black]; display([seq(plottools[transform]( unapply([k, subs(parvalues, Pec_i = -20, R3=R3values[i], F2)], (k,S))) (implicitplot(subs(parvalues,Theta0=4,R3=R3values[i...
I need to solve the following system of equations:
eq1 := (vi-vg)/Z0 - (vg-vs)/Z1-(vg-vd)/Z2;
eq2 := vs - [(vg-vs)/Z1 + gm*(vg-vs) + (vd-vs)/r0]*Z3;
eq3 := (vg-vd)/Z2 - gm*(vg-vs) - (vd-vs)/r0 -vd/Z4;
I am expecting the solutions for vg, vs, vd, so the following command was used:
solve({eq1,eq2,eq3},{vg,vs,vd});
but it kept giving me the warning message of:
so...here it is that equation:
du/dt   = d2u/dr2 +  du/r*dr  +  u  +  f(r,t);     r=(0,...,2]; t(0,...,1]
also we have conditions:
u(r,0)=0;
u(0,t)=t2;
u(2,t)=0
I need to find u(r,t) and to graph it
r and t are cylindric coordinates.
f(r,t) is some definite function.
Hey all,
My question is better explained with an example
the algorithm I have here creates a matrix M[j] for each run of j.
I want to be able to export each of these matrices to a different spreadsheet and if possible, set up a naming critiria for each spreadsheet(so that I dont have to enter a name in the dialog box after each run)
Any suggestion will be really appreciated. Thanks
Lovinash
here's the example:
How can I create a vector using a step index, for example, using the function output f:=1/i+1 and alternate it with a zero
 that produces a vector such as,  0,1/2,0,1/3,0,1/4,0,1/5.....?
Every attempt I tried failed.
How can I manipulate the scale of dominion?
As you can observe with the graphic can not be examined.
Gracias
Hi everyone,
I have a 2nd order system which I want to solve. But the solver outputs no results after evaluation, just returns to the prompt. Do you know what I am doing wrong?
deq1:=diff(x[1](t),t$2)=k[1]/abs(x[2](t)-x[1](t))^2;
deq2:=diff(x[2](t),t$2)=k[2]/abs(x[2](t)-x[1](t))^2;
sys_ode:=deq1,deq2;
ICS:=x[1](0)=5, x[2](0)=10, D(x[1])(0)=0.1,D(x[2])(0)=0.2;
dsolve({sys_ode, ICS});
thanks.
Good morning.
I have a problem.
My Foco1 function is slower than Foco and how can i do it faster?, because that takes a long time.
26-05-2011-robot-man.mw
thank your for your answer
I want to search maple files for specific texts within the file.  What software will do this?
I recall some mention before about searching for specific texts in maple documents but I cannot find it.
Hi there,
I got an output
-3*w*beta^2+12*w-16*beta+4+3*beta^2
and would like to bring it in the form
3*beta^2*(1-w)-16*beta+4*(1+3*w).
How do I do that? :)
In fact I don't even manage to collect the factor of 3*beta^2 as follows
I copied a column of figures from Excel and pasted them into an Maple worksheet.  Maple displayed a column vector with the appropriate values.  I set the variable y equal to this vector and was able to verify that, for example, y[3] had the correct value.  However, when I tried to use y[i] after a summation symbol which used i as the index I got the error message "Error, bad index into vector".  The summation expression worked fine when I redefined y by the following:
The original question I posed was whether I could control the output format of a complex array in MathML. I will pose the more general question, how could I customize the MathML output (much like LaTeX output can be customized)?
Regards.
I'm putting together what will eventually be a rather large simulation system that I want to be able to maintain across a reasonably large organization. Do you have any recommendations for Source Code Control/Versioning systems that work with your .msim file format or should I resign our team to exporting/importing code back and forth into Modelica for source control?
First 1889 1890 1891 1892 1893 1894 1895 Last Page 1891 of 2457
