How do I import/export excel into Maplesim? Also how do I view mpld data files? I tried viewing mpld files using maplesim and maple 14 but it didn't work.
I'm trying to use the convexhull function to plot convex hull of points. Explanation of the functions is here
http://www.maplesoft.com/support/help/Maple/view.aspx?path=simplex/convexhull
The problem is that the convex hull of the plot is always shown in yellow background. Is there a way to change the color?
I can't find any command to evaluate sqrt(any square non-singular matrix) and ln(any square non-singular matrix) or exp(any square non-singular matrix).I searched inside LinearAlgebra and it's subpackages to do this kind of operations on matrices.sqrt,ln & exp produce error when the argument is a matrix(it does not matter if the matrix is the right one or wrong).
I need to find sqrt(g),where g is the 4 by 4 diagonal flat metric tensor:
Dear All
I need your help about one probability and stochastic problem.
Suppose that there is one file with size of s packets.
There is a Poisson process that generates the requests for this file.
Each request will lead to s consecutive requests (packet requests) with constatnt rate r.
It means that requests for file are generated by Poisson process and each file request generate s packet requests with constant rate r.(time between packet request of one file is
Why does this happen to Maple 15?
    `assuming`([sum(k*p*Beta(k, p+1), k = 1 .. infinity)], [p > 1]); eval(%, p = 2)
Is it possible to show with Maple that for any real p>1 the series converges to p/(p-1), e.g.,
    `assuming`([sum(k*p*Beta(k, p+1), k = 1 .. 1000)], [p > 1]): subs(p = 2, %): evalf(%)
How do I show this symbolically? Thanks.
I have a pbs: Suppose 3 vector A, B,C with noted [A:B]:=(list)[ A,B,-A,-B] (i.e a paralelogram);
An endomorphism T such that T(.) where (.)=A,B or C are B,C, and (list)[C,-A,-B,-B]
 and T([x:y])=[T([x]):T([y])] where x,y = A,B or C.
Problem: draw T^{n}[A:B] , i.e its boundary is a fractal figure when n is big.
Hello there,
Im running a fairly big algorithmn with a lot of loops , the memory counter is showing 237.89M and its been running for a long time.
The memory usage has been constant for the last 40min, the time counter still going, and the status bar says 'evaluating'
Is the maple still running fine or has maple's or my computer's limit been reached?
task manager is showing a memory usage of 40% and CPU 12%
I want to use leibniz rule to differentiate the following Integral with variable domain:
A :=(t,x) -> int(Yt^2, x = 0 .. zeta);
Yt and zeta are defined as:
alias(zeta=zeta(t));
Yt:=(t,x)->diff(y(t,x),t);
When I want maple to derive D[1](A(t,x)), its answer is:
2*D[1](Yt)*Yt*Zeta+Yt^2*D[1](Zeta)
Although it uses Leibniz rule correctly, it dose not take Yt as a function of x by mistake. 2*D[1](Yt)*Yt*Zeta should had been derived as int(2*D[1](Yt)*Yt,x=0..zeta).
How can we draw a sequence of segments with a list data of column vector? Thanks
In Arfken(Mathematical methods for physicists,5-th edition,page 483),the asymptotic form of the Hankel function is approximated as
H1(t,s)=
sqrt(2/(Pi*s))*exp(I*(s-t*(Pi/2)-Pi/4))
Is there any simple/direct way in Maple(using HankelH1(),or otherwise) to achieve this?I don't want to assign numerical values to t or s.
I'm using Maple 15.  It seems to me this worked in some previous version...
Consider the Lambert W function, y=LambertW(0,x) ... I want Maple to tell me the asymptotics for it,
something like this:
log(x)-log(log(x))+log(log(x))/log(x)
But I don't get that now.  Is my memory faulty that I got it in the past?
Maple 15:
  asympt(LambertW(0,x),x);
not very useful...
series(LambertW(0,x),x=infinity);
LambertW(0,x)
with(MultiSeries):
LambertW(0,x)
GDQM2.mw
Hi everyone,
I am facing a very complicated system of nonlinear equation. This cannot be solve by using normal fsolve in Maple. Anyone can help me?
Thanks a lot
The results I get from calcultion are usually not in compact forms, so I want to do some simplifying work. And I come up with some questions.
If I write the following expression, the factor command works:
> beta[c]^3/exp(I*omega[c]*tau)-beta[c]^2/(exp(I*omega[c]*tau))^2-2*beta[c]^2+2*beta[c]/exp(I*omega[c]*tau)+beta[c]*exp(I*omega[c]*tau)-1;
> factor(%);
However,when I write the above expressoin as following,  factor doesn't work
Hello everybody,
I would like to assign 349 different variable not already existing (w[i], i from 1 to 349) to 349 expressions from a list. Unfortunately I do not know how to write it. When I try anything like a:=w[33]->listevnouveau[33], it does not work.
With this a, I want to solve this : solve(listedd[33]*w[33]=a,w[33]); which is only possible by assigning variable to the expression.
Regard, Charbo
First 1887 1888 1889 1890 1891 1892 1893 Last Page 1889 of 2457
