Is there a direct command to give the (first) index in a list,
for which the entry coincides with some given value (without
coding a loop, to run through the list)?
PS: when I enter that question I automatically get an info,
that similar questions exists. But clicking on those links do
not give usefull infos, they just lead to a page of old threads
(Page 529 of 569 for the first link ...)
Hi all
I am trying to draw a 3d plot from the data that I have created in excel, how do I import from excel to maple and then draw the 3d plot using array?
below is the link to my dataset in excel
Book1.xls
your help is appreciated
What Should I do to get the correct result-which is obviously not something like my answer.
> assume(a::(AndProp(NonZero, constant, real)));
> about(a);
Originally a, renamed a~:
is assumed to be: AndProp(real,constant,Non(0))
> is(a, constant);
> is(a = 0);
> is(a^2 > 0);
> assume(p::real, 0 < p and p < infinity...
How I can say that an object,say k, is a constant(it may be positive or negative) inside assume()?
assume(k::??should I say)
pls also tell me what kind of help pages I should see for this kind of "type inside assume()" problems.
I'm working on a mecanic's problem and I need to solve a differential equation:
I want to determine x(t) and plot it...
This is the way I do it:
with(Physics):with(combinat):
comn := choose([u, v, mu, nu], 2):
def := seq(seq(seq(Physics[`.`](Dagger(Ket(aa, k)), Ket(bb, m)) = Physics[`.`](Ket(bb, m), Dagger(Ket(aa, k))), `in`(aa, comn[i][1])), `in`(bb, comn[i][2])), i = 1 .. nops(comn)), seq(seq(seq(Dagger(Physics[`.`](Dagger(Ket(aa, k)), Ket(bb, m)) = Physics[`.`](Ket(bb, m), Dagger(Ket(aa, k)))), `in`(aa, comn[i][1])), `in`(bb, comn[i][2])), i = 1 .. nops(comn));
Setup(def):
d1 := Physics[`.`...
I was recently browsing the Wolfram website, in particular the Online Integrator, and was very impressed that they are exposing a part of their product for free public use. I also noticed that they offer the option of submitting previously unknown anti-derivatives to them:
(From the FAQ page, http://integrals.wolfram.com/about/faq/#8)
“If you think you have a...
I have three different matrices, say A(3x6),B(3x6) and C(3x12) with the size of each matrix mentioned within parenthesis. I want to define a fourth matrix D (6x12) so that D=[A,B;C] (in Matlab notation). Can anyone please tell me how to define this D in Maple? Maple help seems not that helpful at least for beginners like me. Thank you in advance.
what is the command to change transfer matrix to state space?
When I enter the Greek Capital letter "Xi" (looking like three uneven horizontal lines) it comes up fine on screen but in print preview there is a space?  Lower case "xi" is fine.  Same thing happens in both Maple 14 and 15.
Hi everyone,
Is there a way that Maple can return a list of variables in a function? For example, if I have something like:
f:=(x,y)->x^2+y^2;
I would like Maple to return:
{x,y}
I found the indets command, but it does not seem to work for functions. For example:
f:=x^2+y^2; indets(f);  returns {x,y} but     f:=(x,y)->x^2+y^2; indets(f);    returns {f}
I am looking for an way to do clifford and geometric algebra calculations with Maple.
Robert Israel helped me to plot  F2 vs k
http://www.mapleprimes.com/questions/120380-Explicate-Plotting
I tried to modify his code to get reults for F2 vs S from equation A1, but i am still facing problems with it
The maple code is
restart:with(MultiSeries):with(plots):
parvalues:={C=2.02,H_liq=8.74,R=22.11,R1=0.0006};...
I encountered the following problem in Maple 14
expr1:=sqrt(a)
assume(a>0)
expr2:=sqrt(a)
additionally(a>1)
subs(a=2,expr1) #gives correct answer of sqrt(2)
subs(a=2,expr2) #does not substitute a=2 in expr2
It seems the last statement with expr2 does not work as expected, I wondered why this behaviour is so, because it does work with expr1. The added assumption does not invalidate the first...
Hi guys,
I am a first time user of Maple. I have a very easy question to ask you people since I am not that great in programming.
Below is a system that I want to evaluate. I just want to know how can I find out expressions of w1 and w2 in terms of u1 and u2 only i.e. w1=f(u1,u2) and w2=f(u1,u2). I don't want other variables like delta or E in expressions of w.
First 1888 1889 1890 1891 1892 1893 1894 Last Page 1890 of 2457
