Hi pro, When i use " maple help " in Maple version 12, I care Christoffel command but I have a question for assistant.
Example (I copy and paste from Maple 12 help):
Dear All
I am evaluating innerproducts between a cartesian basis set with an arbirtary operator, and the result is;
ans = <X|a[11]|X> + <X|a[12]|Y> + <X|a[13]|Z> +
           <Y|a[21]|X> + <Y|a[22]|Y> + <Y|a[23]|Z> +
           <Z|a[31]|X> + <Z|a[32|Y> + <Z|a[33]|Z>
I would like to put this into a matrix form (i.e. removing the bras and kets), so that
Let say that I want two have two inputs nods that each should give a random variable and one node
that simply adds them together and plots the result. How could that be accomplished ?!
proc(x) local t;
 t := x*x*x + 0*2;
 if true then sqrt(t); else t^2 end if;
proc(x) local
in maple 13,the result is
proc (x) local t; t := x*x*x; sqrt(t) end proc
not the simplified proc(x) local t; t := x^3 ; sqrt(t) end proc
 (this is in the reference book)
Hello there, I uploaded a Maple-document with all the information. http://d3.myfreefilehosting.com/d1/Tangent%20determination.mw Please have a look, greetings, Jonas F
Ever since I updated to the latest maple13 patch (for OS X - snowleopard) when I try to call maple from the terminal it hangs: |\^/| Maple 13 (APPLE UNIVERSAL OSX) ._|\| |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2009 \ MAPLE / All rights reserved. Maple is a trademark of
I have the data set and  a systems of ODE ( 2 diff. eqn.)
is there any solution for these two equations simultaneously ?
How can I fit the data and evaluate the constants numerically, and how can I plot this ?
 diff(x(t),t)=a*b*[X(t)^2-(Xo+Yo)*X(t)+X(t)*Y(t)]/[b*X(t)+c*Y(t)];
 diff(Y(t),t)=a*c*[Y(t)^2-(Xo+Yo)*Y(t)-X(t)*Y(t)]/[b*X(t)+c*Y(t)];
data set
Hi, I am using this code to verify if my function satisfies positiveness / negativeness under assumed ranges or not. assume(`θ_e`, 'real', 0 <><> true then print(b[1]); break else favorableDF_Exists := 1 end if; := '`θ_e`'
although I manage to solve the following problem step by step, I don't really know how translate it properly into Maple code.
First of all, from the following equation I have to extract the derivatives dx/dy1 and dx/dy2 (because I need them later on):
f(x,y1,y2)=0
(This can be done using the implicit function theorem).
Then, I have to calculate the following derivate and set it equal to zero to get y1 as a function of y2.
dg1(x,y1)/dy1 = 0
I tried to create a gif file out of more then 200 sequantial plots. A gif file was opened yet nothing was saved into it. I was able to create a file from less than 170 frames in the the same manner.
Is there a size limit or a limit on the number of frames that gif can process?
Is there other video like formats availble in Maple?
I use dsolve on a given system of ODE
sol=dsolve({sys_ode,ics},type=numeric,stiff=true);
and when I ask Maple to compute sol(1), I would like also Maple to display all the time points and the values of the solutions at those points that was computed to get to the endpoint=1 (starting from initial values in ics).
Any suggestions!?
Many thanks!
I am trying to construct a vector field based on a large expression. Although I put cos(phi) at the end of the expression, written in 2-D Math, the expression gets automatically simplified to cos phi, without parentheses. That causes the command VectorField not to understand the end of the expression and fail building the vector field.
If instead I define the expression in 1-D math, it works perfectly. Like this:
Dear MaplePrime users,  I have got a very strange problem ( for me surely)  I am not a mathematician , and not a good Maple user :(((  When you can help me in solving this problem with Maple, you  are very appreciated. Thanx.
Problem:
a, b, c, e,   are constants
X, Y, Z, M, N, R  are time dependent  variables,
X(t)=  Xo- M(t);
Y(t)= Yo - R(t) ;
N(t)= M(t) + R(t);
Z(t)= Zo - M(t) - R(t) ;
new defined parameters,  K= b/a = e/c = X / M =  Y/ R
Hi there, I got a set of discrete Data as functions of 4 variables (x1,x2,x3,x4) . I would like to interpolate the data with respect to x2 and then get a continuous function f (x1,x2,x3,x4). Finally I would like to get the partial derivative of f wrt x2. How can I sort this out? x has the range [0,x0]. s is an arbitrary function of x. g is a function of (x1,x2,x3,x4) which is formed from solving the IVP numerically. x0:= 1/2: s:=x->x^2: sol:=(x2,x3,x4)->dsolve({y''(x1)-(x3^2+s(x1)*x4^2)*y(x1)=0,y(x2)=exp(-x2),y'(x2)=1/2},numeric,output=operator,range=0..x0):
I want to find the syntax for below example:
e.g. a=9 and 9 is not a valid entry for parameter a, I want to print an error message like:
Value 9 has been entered for  parameter a is not valid
How can I do this?
First 2114 2115 2116 2117 2118 2119 2120 Last Page 2116 of 2457
