Hi there,
I try to plot several graphics and print them out as follows:
for i from 1 to n do
  p:=polygonplot(...):
  disply(p);
end for:
but nothing is being diplayed. Doing that just once does the job but I need those plots for large n...
Long story short, running a loop that takes random variables and does various statistical things to them.
The loop has to run about 10^7 times with the final value going into an Array but I cant do that because the Statistical stuff such as CumulativeDistributionFunction takes up so much memory that I end up losing the kernel.
But... Today I came across the gc() command. I put this in at the end of my loop (before the end do), and lo and behold I was using virtually zero memory for the loop. Only what was needed to fill an Array.
So Maple and I are not the greatest friends and I need help. I have searched google, this forum and other forums for help to no avail. If somebody would be so kind as to help me with the problems that I am having that would be greatly appreciated.
I think the problems are in the initial and boundary conditions because there are so many recursive statements but I am unsure how to enter these so that I get a favourable result. Without the boundary and initial conditions I do get a general solution.
Dear experts, I defined a certain procedure that I use several times. Is there an option to save it so that I do not have it in each working space? Thanks you a lot!
I would like to use a series of Maple worksheets, written by Professors Malidi Ahamadi and Jean-Jacques Gervais, designed to compute the normal forms of ODEs and PDEs. The code was written for an earlier version of Maple (maybe version 7 or 8) and doesn't run anymore on Maple 13. I would like to make the necessary adaptations to the code to run it on Maple 13. Unfortunately, I am no Maple expert...
When I run the worksheet, the following error message shows:
Dear experts, the results are always displayed in blue. When I type: #StandardDeviation(x) as a comment, you do not see it in the result. when I just write StandardDeviation(R1) he calculates it. But I just want to display StandardDeviation(R1) as a headline of the blue results. How could I do that?
Any reason why the show Numb3rs mostly uses Wolframs Mathematica?  Being a Maple fan I'm a tad bit dissapointed.
There's a whole mathematica website devoted to the show Numb3rs http://www.numb3rs.wolfram.com it's fairly good and still under developement.  Any plans for maple to so something similar?
I installed Maple 13 and Maplesim 2.0 in a brand new computer I ran the robot simulation successfully but as soon as I ran windows updates and the rest of applications it not longer  work. it just gives me a blank windows with the tool bars.
Does anyone encounter this problem? How do you solved it.
I updated my video card with the latest drivers; and follow the instructions in  regards to installing the latest Java
I am trying to do the following sum
with(numtheory):
sum(bigomega(j),j=1..n)
But I get this error message
"Error, invalid input: numtheory:-bigomega expects its 1st argument, x, to be of type integer, but received j."
I have tried
assume(j,'integer');
but this has no effect. I'm a bit puzzled why Bigomega doesn't work in summations as  other Numtheory functions I've used have all worked.
Dear experts, I want to display the results of my Maple Simulation in a new window or pop up. Do you have an idea? Thank you in advance!
Dear experts, I defined a procedure in a simulation that I run in MAPLE. Each time I want to run the simulation I have to click return again and have to wait for some seconds. Is there a more efficient way? Maybe to save the procedure in Maple ? or antother option? Thank you in advance for your help!
Maple 13 help describes at least two ways to invoke classic maple, one, for example, through the Windows start - all programs -> Maple 13 .  But there sure is no classic Maple option there.  Where is Classic Maple?  ..........Edgar
suppose I have two (or more) different matrices, not necessarily with the same number of rows but with the same number of columns.
I know I can use RowSpace in the LinearAlgebra package to obtain the RowSpace of one matrix, but I would like to consider the intersection. Is that possible?
(In fact, I am particularly interested in the vectors in that intersection that only take the values zero and one, or in other words: all non-zero entries of which are equal. Would there be a trick for that?)
Many thanks!
Please help me to Solve the following problem?
3^2^3*3^2^2=?
Hello out there,
Hopefully somebody can help me.
I have a little function lets say: n:= l -> sqrt((C1*l^2)/(l^2-C2^2)+(C3*l^2)/(l^2-C4^2)+(C5*l^2)/(l^2-C6^2)+(C7*l^2)/(l^2-C8^2)+(C9*l^2)/(l^2-C10^2)+1);
(it is a sellmeier equation for the refractive index of quartz
and Maple can also plot it for me:
plot (n(l), l=350...1600)
But now I need the data on which the plot is based to be exported to excel or origin.
First 2132 2133 2134 2135 2136 2137 2138 Last Page 2134 of 2457
