I tried the following code...... un := [0, 0, 0, 0]: un[1] := tanh(k)*tanh(k*n): for i from 2 to 6 do uns[i-1] := eval(un[i-1], t = s): und[i-1] := diff(uns[i-1], s): unp[i-1] := eval(uns[i-1], n = n+1): unm[i-1] := eval(uns[i-1], n = n-1): un[i] := un[i-1]-(int((und[i-1]-(1-uns[i-1])^2)(unp[i-1]-unm[i-1]), s = 0 .. t)): end do:
Dear Experts, I am sorry for theis basic questions but I don´t succeed in solving it. I have to matrix A and B with just one column each and 10 values each. So together 20 values. The 10 values of matrix A I want to plot in a graph (the points shoudl be joined to a lign) and the second matrix B also, but I the same graph. Dou you know a solution for that? Thanks a lot!
hello, i just wanted to know how to find the equation of the tangent line for f(x)=x^4-x^3 at the point x=1.2.  what code would be used?  thank you very much in advance.
Dear experts, I have to optimize a function f with two variables x and y --> f(x,y). The function is not differentiable! Does somebody of you know a link where I could find an algorithmen (the best would be a generic algorithmen) to solve this multivariat optimization problem? Thank you a lot in advance!
Hi there,
I am basically using MapleSim to obtain the equations of motion for mechanical systems and copy
pasting them into a separate Maple document and solvng them numerically. I could work with simple pendulum
and a two link manipulator. But in the case of a four bar mechansism since the system is a closed chain the
number of unknowns ended up being more than the number of equations. In this case, the joint reaction forces
came into play as unknowns. I know MapleSim intelligently does index reduction and solves these equations. But
hello friends
please help me.
I already have an spline equation in maple13. I want use this equation as a signal block mathematical funtion. But maplesim only have standard funtion blocks in this pallet :
Signal Block\Mathematical\Functions
I want to make my Maple12-procedure faster by creating two threads instead of two:
I have an Nx3 Matrix A and each row looks like [integer,integer,*]. Matrix A acts like a function of two variables in the sense that the ordered pairs that you get be selecting the first two entries of each row are all distinct.
I would like a slick way to convert A to a Matrix B for which B[i,j]=* where * is the third entry in the unique row of A that looks like [i,j,*]. We can insert 0 for "blanks."
For example, if
A:=Matrix([[1,3,a],[1,4,d],[1,1,b],[3,3,c],[3,4,a]])
1 3 a
1 4 d
1 1 b
Hi there,
My name is Sasi Bhushan Beera. I am Graduate Student in Mechancal engineering at UB.
I have been working on dynamics of mechanical systems for my research. What I intended to do
was to obtain equations of motion using MapleSim and copy paste them in a seperate document
folder and solve them numerically. Considering the case of a Simple pendulum, I was successful
in doing all this but I had problems with animation of the pendulum.I need some help with the animation
hye.. iam zarith.. i want to ask u whether there are solution to this differentiation of delta f over delta f. please
Hi all, Is there anyway to solve this differential equation in maple? (diff(x^2, x))*(diff(w(x), x))/x^2 = 480*(Int(0.2538690379e-2*l^2/(exp(4.651162791*10^6*l^2+9.302325581*10^6*w(x)-1.600000000*10^9)+1), l = 0. .. infinity)); Initial conditions: w(0) at 0 and w'(0)=0. Thanks
How do I generate a list of equations with Maple procedure. My problem is this, I have a Pile embedded in the soil. L is the length of the pile, it is divided into t equal segments, thus there are t + 1 points along the length of the pile. The point 0 is at the tip, and point t is at the ground surface. Y[m] is the general deflection equation at any point m along the pile. My goal is to generate each equation for each points along the pile, such that I can invoke Maple solve function to solve the problem. Below is my input into Maple.
From format->autoexecute , I wanted to press "clear" but accidentally pressed "clear all" ... now all 200 of my autoexecuted functions (which were very carefully placed and is not easy to remember which ones they were!) have been removed and pressing edit->undo does NOTHING!
I'm so lucky that I save my maple worksheets every time I make big changes (so I have maybe 36 versions of this worksheet!) .... but should maple not be able to "undo" somehting THAT simple!
First 2133 2134 2135 2136 2137 2138 2139 Last Page 2135 of 2457
