I was curious if anyone has every seen an english translation of Jordan's Cours d' Analyse. I've read many author comments praising his work and was interested in trying to find a copy in english. Anyone care to comment?
TIm
I'm using maple to optimize a certain problem. I have two matrices, A and B both of size m by n. Now I want to maximize alpha(a scalar) such that Bx>=alpha*Ax for arbitrary x. So I gave maple the following problem: input:=evalm(A&*X): > output:=evalm(B&*X): > for i from 1 to m do > constraint[i]:=output[i]-alpha*input[i]>=0; > od: > Constraints:=seq(constraint[i],i=1..m); > sumconstraint:=add(x[i],i=1..n)>=10; oplos:=NLPSolve(alpha,{Constraints,somconstraint},maximize=true,assume=nonnegative); My problem is that maple sometimes can't come up with an answer and tells me:
Given "(x + y/z)" as input, how do I get the same expression in the form of "(xz+ y)/z". I need to make this conversion, so that I can discard  the denominator and use the numerator "xz +y" as a monomial in Groebner Basis.
I currently run Maple 10. I am a math teacher in a public school. Do you think I will benefit from upgrading to Maple 12? Any cool features?
Does Maplesoft has an online version of Maple's user manuals? I know there are pdf versions. Thanks!
Hi:
I will really appreciate it if I can get some help with evaluating 2500(1+ r/4)^(4*5) with r taking multiples values such as 6, 10 etc.
So far I am aware of the basic eval command... eval(2500(1+r/4)^(4*5),r=6). What I want to do is evaluate this expression for multiple values of r. Thanks in advance!!
-- k
I want to have a solved example of linear programming model in maple software or any other software that has linear programming model
I'm trying to graph nonlinear systems of inequalities.  INEQUAL works only with linear systems.  Someone in this forum suggested IMPLICITPLOT with the option FILLED = TRUE, but this doesn't always give the desired results since that option only gives the area between the curve and the x-axis a solid color.  What I need is the power of OPTIONSFEASIBLE, OPTIONSEXCLUDED, OPTIONSOPEN, and OPTIONSCLOSED (options available with INEQUAL) that will work with nonlinear inequalities.
Alla
I use Maple 11 and I created a procedure (call it MyProcedure), which ends
> display([seq(r||Index, Index=1..NumberOfIterations)],insequence=true);
Futhermore I have a maplet with
> Plotter['PL1']()
> Button['BT1']("Draw", width=90, onclick=Evaluate('PL1'=MyProcedure(.....)))
This works ok. Result is displayed in the plotter. However I would like to add other buttons, which will work with this animation. I mean to use functions like Play, Stop, Next Frame, etc. How can I do this?
I need help in solving the following problem.
1-  w1(.03)+w2(.015)=0
2-  w1(1.9)+w2(1.5)=205,000
Very often I have to insert map(assume,[k,lambda,L,...many others...],real) in order to simplify my expressions.
As a simple example, compare Re(exp(I*k*x)) assuming k::real,x::real; to the result without assuming.
So I'd like a procedure/command that makes Maple assume that every symbol in an expression is real but not the expression itself.
<p>hi,</p>
<p>i tried to write a maple procedure that creates a prefix free tree based on the algorithmen of Shannon-Fano. the theory how the algorithm works is easy but for translating that into a maple procedure causes me headaches.</p>
<p>right now im stuck in the part where i have to split the characters i got until i only have one left. i suppose until that point my procedure might be ok but i how do i continue now? i lack the maple know-how to get further now....and i suppose i did already things wrong because i don't know how to save my nodes</p>
integration {(x + 1) / x dx}
Hello, I'm trying to find a function f(r,r') such that G(r,r')=1/(r-r')+f(r,r'), where r=sqrt((x-x')^2+(y-y')^2+(z-z')^2). I have 6 boundary conditions of the form: G(x,y,a)=0, G(x,y,-a),=0, G(b,y,z)=0, G(-b,y,z)=0, G(x,c,z)=0, G(x,d,z)=0 where a,b,c,d are known constants. How do I do that in maple? Thanks
First 2260 2261 2262 2263 2264 2265 2266 Last Page 2262 of 2457
