I'm optimizing a procedure so that it can work as fast as possibly can.
How do I find out how long it takes for maple to make a calculation?
I did evalf(3^1000000,1000) or something like that on a laptop.  It was taking a long while so I pressed the interupt (stop hand) button.  Nothing happened, it didn't stop.  It did finish what it was doing but it didn't immediately stop.
Unless it was trying to update the screen with all the numbers I think maple should have just stopped whatever it was doing and give me back control.
1) How to instruct Maple to assign hotkey Cmnd-N (on Mac) to New Worksheet rather to New Document? 2) How to create a new document/worksheet in the new window rather than in the new tab? 3) How to open a already open tab in the separate window?
Is there an equivalent Maple command for the "angle" command in Matlab?
I'm trying to get the phase angle out of a complex number.
I want to be able to do the following in Maple 1) Set up the current value hamiltonian H:=u(c(t))+lambda(t)*(f(k)-c(t)-delta*k) ; 2) Take the foc with respect to c(t) which should give me u'(c(t))=lambda(t) 3) Differentiate with respect to time which should give me u''(c(t))*diff(c(t),t)=diff(lambda(t), t) 4) Divide both sides by u'(c(t))=lambda(t) should give me u''(c(t))*diff(c(t),t) / u'(c(t)) =diff(lambda(t), t) / lambda(t) I have tried to set up the hamiltonian in maple but I find it quite hard for numerous reasons: A) I cannot differentiate a function w.r.t a function i.e
Absolutely amazing. Absolutely every single time I go to Maple to invert a matrix,
the syntax changes. Sometimes it can recognize M:=[[1,3],[2,5]] as a matrix. Then the next time it never will. It requires M:=Matrix([[1,3],[2,5]]); Sometimes it is MatrixInverse(A). Other times it is MatrixInverse[A]. Other times a matrix must be written as <<1,3>|<2,5>>. Sometimes the command is with(LinearAlgebra). Other times with(LinearAlgebra[Generic]). Some of these commands on in the Help menu. Other times they cannot be found.
Hi, I'm trying to find the first few roots of the Bessel function (1st kind) for a few different values of v, but I'm new to Maple and am having some trouble.
This is what I've tried:
u:= v->BesselJ(v,x);
solve({u(0)=0},{x});
                            {x=RootOf(BesselJ(0,_Z))}
evalf(%)
I am brand new to Maple and am having difficulty with the syntax for entering an equation and plotting.
Can anyone assist me with the syntax for the following (the equation syntax and plot syntax):
Given that the slope of a line is -3 and passes through the point (1,4), find the equation of the line in slope- intercept form and plot the line.
I have already worked the problem by hand; x=2.333, y=7 and I need to plot the line through points 1,4.
 I need to get the surface area and volume of a tetrahedron - coords: a=(2,0,0), b=(0,3,0),c=(3,6,-1),d=(1,2,3). Also, it's height starting from point 'd'.
 The second problem is: how to create an animation of a torus that spins around the Oz axis.
How do I do that? Any help appreciated :*
Also g1 and g2 are costants. I need the expression of  T,that solves the equation,  in function of  x1, P, g1, g2 because later I've to use this expression in Fortran. However I find some mistakes in the equation. The correct equation is funz=0
Suppose that I define a unit step function:
u:=t->piecewise(t<0,0,t>=0,1):
How can you periodiclly extend this functions so that it has a period of p ?
Hello, I have found a difference in the handling of an integral between Maple versions 10 and 12. It bothers me since it was working in version 10, but now it gives a numeric exception... I'm not sure whether the replacement is valid or not, so I hope someone can validate it for me. Suppose I have the function definition > f := (x,a,b) -> int( t^(a-1) * (1-t)^(b-1), t=0..x ); As an example, consider > f(2.,3.,.4); This gives -0.8 both in Maple version 10 and 12. However, if I replace the previous statement with > f(x,a,b); > subs( x=2., a=3., b=4., % );
with( plots ):
P := Array(1..51);
P1 := Array(1..51);
P2 := Array(1..51);
P3 := Array(1..51);
R := proc (s) options operator, arrow; 0.6e-1*(arctan(10*s/1.3-3.0)/Pi+1/2) end proc;
y := proc (s) options operator, arrow; evalf((-1)*0.6e-1*(arctan(10*s/1.3-3.0)/Pi+1/2)*cos(6*Pi*s/1.3)) end proc;
z := proc (s) options operator, arrow; evalf(0.6e-1*(arctan(10*s/1.3-3.0)/Pi+1/2)*sin(6*Pi*s/1.3)) end proc;
f := unapply( simplify(sqrt(1-((6*Pi/(2.6)*0.6e-1)*R(s))^2-(D(R))(s)^2)), s ):
for i from 1 to 51 do
for what values of a does the equation:
ax^3+x^2-ax+1
have exactly two distinct real roots?
I've to solve this equation f(T)=0:
f:=T->P*y1*{exp[(0.00662*P*(0.1696-3154.69/T^1.6-(1.58*10^9)/T^4.2))/T]-exp[(0.0022*P*(0.131-5523.13/T^1.6-(3.79*10^9)/T^4.2))/T]}+P*{exp[(0.0022*P*(0.131-5523.13/T^1.6-(3.79*10^9)/T^4.2))/T]}-{x1*g1*1.197*log10(7.74439-1473.686/(T+198.463))*[P-log(7.74439-1473.686/(T+198.463))]*exp[(0.00662*P*(0.1696-3154.69/T^1.6-(1.58*10^9)/T^4.2))/T]}/T-{(1-x1)*g2*0.291*log10[8.07126-1730.63/(T+233.426)]*[P-log10[8.07126-1730.63/(T+233.426)]]*exp[(0.0022*P*(0.131-5523.13/T^1.6-(3.79*10^9)/T^4.2))/T]}/T
First 2258 2259 2260 2261 2262 2263 2264 Last Page 2260 of 2457
